Questions on the appearance of the Z3100 Gloss Enhancer
2008-02-18 by wwodets
I've gone through all the Z3100 posts and found little actually
describing the appearance of the GE.  How would you describe the
appearance in terms of color and gloss level?  Has anyone used this
with the Harman Gloss FB AI?  Used over the entire surface, does the GE
raise or lower the gloss as compared to the straight Harman paper in
unprinted areas?  Compared to other of the gloss papers?  Does it raise
or lower the gloss of the inks?  Is this a high gloss surface, a satin,
etc.?
I know this can be a subjective call, but comments would be welcome.
Many thanks,
Walt
Re: [Digital BW] Questions on the appearance of the Z3100 Gloss Enhancer
2008-02-18 by Harold Jackson
Walt --
  I don't use the Harman paper but I'll give you my experience with other papers using the gloss enhancer on the Z3100.  My preference is for the Moab Photo Luster and Museo Silver Rag papers.  Thus I don't use high gloss papers.  On the luster papers the gloss enhancer I use it to coat the entire paper (not economy mode) and I have seen no evidence of color shifting(metamerism) or bronzing.  The colors are vibrant and lively.  The printer is also very judicious in it's use of gloss enhancer.
  For all of the papers that I have tried since I've owned the printer,my findings are that HP got it right.  The only thing that I would like to see is a better sheet feed mechanism (like the ones that come with the Epson 4800 and 3800).
  I know you wanted some feedback about the Harman paper but I haven't tried it yet.  I've got some coming in so I'll be trying it soon.  I'll be happy to share my results with the group.
2008-02-18 by Tony Sleep
> etc.?
I have seen Z3100 Harman FB AL gloss prints done using black+gray+GO.
Overall they are pretty successful. The GO eliminates 80% of the bronzing
and GD that Vivera black & grey produces on this paper without GO. You
have to look quite closely to see any trace of bronzing, and these prints
are the closest I have yet seen to wet darkroom prints.
If anything tone is a little too neutral. Bromides tended to be either
warm or cold, and the Z3100 samples were just a little sterile for my
taste. They reminded me of the original Seagull Oriental in Dektol in that
respect, which I preferred after selenium toning.
Aside from that, there is still a slight residual sense that the image is
sat on the surface rather than within the emulsion. But they are, as I
say, very close to FB bromides and I doubt most people would notice.
The GO appears pretty much clear. I don't recall any sense of yellowing,
but whether that would change with time I don't know. The coating itself
is very thin and adds a little gloss but without changing the slight
surface texture. The application did not look completely even, even though
it was a full rather than economy/selective coating. Without be able to
pin this down, I remember thinking that the coating looked like a coating
rather than an integral part of the surface. I was told - by the guy who'd
been testing - that they had a few issues with adhesion of the GO on
Harman, but the 2 prints I saw were OK and showed no flaking except at the
cut edge where it had been trimmed after printing.
Overall highly impressive and very promising. But I think it might work
even better with one of the Innova papers - Fibaprint White Gloss,
Warmtone Gloss or Ultra Smooth Gloss White. The surface of the first two
is slightly less glossy than the Harman and a little more 'textured' with
the Ultra Smooth down the middle. I've experimented with this latter paper
(on a B9180) and (aside from an occasional overinking issue) it achieves a
better Dmax than the Harman. Innova tell me the White Gloss and Warmtone
Gloss work better with Vivera but I haven't yet tried the samples I have.
Tony Sleep
http://tonysleep.co.uk
Harold-
Thanks for the comments, but how does the GE *look* on, for example,
the Silver Rag?  Does it raise the gloss of the unprinted paper,
reduce it or not change it?
It is interesting that the Harman Gloss is perceived by many as more
glossy than the Silver Rag.  As with the Exhibition Fiber, I find the
K3 *inks* on SR much glossier than on the Harman--the sparkling and
glitter of the inks takes the surface beyond gloss to something I
have never seen before.  By comparison, the Harman has a soft sheen
that is no more disturbing at odd angles than a gelatin print.
I imagine that the HP inks have a very different surface than the K3s.
Walt
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, Harold Jackson
<harold@...> wrote:
> Walt --
of gloss enhancer.
Tony,
Thanks for the description.  I imagine that the HP inks are looking
very different on the Harman than the K3 inks (with MIS carbon in the
yellow position) that I am using.  These produce no bronzing on the
Harman and only the slightest GD.  So perhaps the GE on the HP is
correcting a problem that I don't see with the K3 inks, at least on
this paper.
The sheet feeding problem on the Z3100 is mentioned often--what is
it?  I use a 4800 and front loading and find it quite convenient.
Walt
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, Tony Sleep
the GE
in
raise
satin,
> > etc.?
black+gray+GO.
bronzing
You
prints
either
my
in that
image is
as I
yellowing,
itself
slight
though
able to
coating
guy who'd
on
at the
work
first two
latter paper
achieves a
Warmtone
have.
> Regards
> Tony Sleep
> this paper.
Bronzing using Vivera black+gray is significant on all gloss papers I've
seen when used withut GO. The same issue doesn't arise with composite B&W
or colour prints at all.
Allegedly awkward, rear sheet feed that takes some practice and yoga to
get right. I've no first-hand experience though. The B9180 was all I could
afford.
Tony Sleep
