coated side of Portfolio Rag?
2008-02-23 by Tyler Boley
anyone know how to identify it? The tongue trick isn't working, and
getting a little gross anyway...
Both side seem the same. No instructions.
Doing a few tests with some samples, odd paper...
Tyler
Re: coated side of Portfolio Rag?
2008-02-23 by john dean
Yea it's bizarre, I can't tell either. The only way I can tell is the
curl of the roll :-) .
j
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Tyler Boley"
> Thanks,
> Tyler
Re: [Digital BW] coated side of Portfolio Rag?
2008-02-23 by Mark Savoia
Doesn't it say VIEW FROM THIS SIDE like slide mounts? Now, if you
would use rolls, YOU would know :)
Mark
http://www.stillrivereditions.com
> Thanks,
> Tyler
well I just walked right into that now didn't I?
gee, come to think of it... maybe I've been printing on the backs of
the rolls and doing the whole thing wrong?!?!
No wonder my dmax sucks
thanks kids, Jimmy set me straight.
T
Re:coated side of Portfolio Rag?
2008-02-24 by Clayton Price
Posted by: "Tyler Boley"
Sat Feb 23, 2008 12:17 pm (PST)
<<<anyone know how to identify it? The tongue trick isn't working, and
getting a little gross anyway...>>>
Hi Tyler,
I discovered that with sheets of Photo Rag, carefully feeling the cut
edges shows that the raised edge side is the coated one. I'm imagining
that the paper started as a roll, and when cut has that slight edge
from the inside surface. Perhaps the same would be true with
Portfolio Rag??
Clay
2008-02-28 by Andrew Darlow
Hi Tyler:
I use the fingernail scratch test. Coated side has more resistance
(sort of like sandpaper). Putting a very small mark with a pencil in
a corner of the non-print side as they come out of the box can also
be helpful.
Hope that helps,
Andrew
Andrew Darlow
Editor, The Imaging Buffet
http://www.imagingbuffet.com
Author, 301 Inkjet Tips and Techniques:
An Essential Printing Resource for Photographers - http://
www.inkjettips.com
> Thanks,
> Tyler
> __._,_.
