Formacote
Formacote
2008-02-26 by Richard Smallfield
my framer just told me that the acid from Formacote eventually leaches through and wrecks the mat and print and that I should use Foamcore - which is not what a framer preiously told me.
Has anyone had experience of Formacote not being archival?
thanks,
Richard
http://smallfield.vze.com
   "Experience is a hard teacher. She gives the test first
   and the lessons afterwards."
   --anon
Re: Formacote
2008-02-28 by Tim Atherton
I happened to be taking a workshop with some conservation scientists,
so I double checked and they confirmed what I thought.
Foam Core/FomeCor isn't recommended as a product for this kind of use
if Preservation is important.
There is a version where the outer barriers/layers are acid free, but
it's not considered terribly effective. But the core is the main
problem. The foam is unstable and usually deteriorates - often within
ten years and also gives off all sorts of crap (technical term...)in
the process.
Is Formacote (Formakote) specifically a NZ product? I couldn't find
much about it. It sounds like a board laminated with similar clay
coated outer barriers as foamcore. But I couldn't find anything on
it's use for preservation or being tested.
Are you just using it for the thickness?
You'd probably be better off just using proper acid free mounting
board and if you need the added thickness for the frame, use proper
Coroplast, which is inert.
tim a
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, Richard
Smallfield <r.smallfield@...> wrote:
> Hi,
> thanks,
> Richard
>    --anon
Re: [Digital BW] Re: Formacote
2008-02-28 by Peter Marquis-Kyle
I suspect that 'Coroplast' might be uncommon in New Zealand, and that
the common local equivalent is 'Corflute'.
Peter Marquis-Kyle
2008-02-28 by Richard Smallfield
Hello Tim,
thanks for your looking into this for me.
In response, I just checked my supplier and all he has is:
http://www.tayles.co.nz/index.php?cPath=4&osCsid=67eeaf6e53c36555eb9fe707f7f2a95d
... Foam Board and Formacote. Which is all anyone in New Zealand seems to use.
I'll keep asking,
Richard
   "The warning message we sent the Russians was a
   calculated ambiguity that would be clearly understood.
   --Alexander Haig
