gold fiber silk grip marks
2008-03-05 by bruce rowell
has anyone experienced discoloring and roller or grip marks verically
in last 1/8 or so of print using epson 1800,marks seem to be in glop. i
have thick paper checked. thanks for any help,bruce
Re: [Digital BW] gold fiber silk grip marks
2008-03-05 by Carl Schofield
Try using wider margins and also use the rear single sheet feeder.
Carl Schofield
http://photos.schophoto.com
> glop. i
2008-03-05 by rowell bruce
thanks carl,that solved the roller marks,but still getting discolor at end of print,prints start getting lighter at end of print with vertical banding,this happens on two separate  epson 1800's and different os systems.thanks again,bruce
  To: DigitalBlackandWhiteThePrint@yahoogroups.com<mailto:DigitalBlackandWhiteThePrint@yahoogroups.com>
  Sent: Wednesday, March 05, 2008 12:43 PM
  Subject: Re: [Digital BW] gold fiber silk grip marks
  Carl Schofield
  http://photos.schophoto.com<http://photos.schophoto.com/>
  > glop. i
2008-03-05 by Eddie Wiseman
Yes...
I'm having the SAME problem with a 1280 and using the "thick" paper setting with MIS UT2 inks..but the problem is NOT the inks as the paber is "scuffed" just outside of the picture area..I believe the problem begins on the bottom left and right sides of the print during the initial "grab" of the paper into the printer..As well..I don't know of a cure..
Eddie
  Carl Schofield
  > glop. i
2008-03-05 by pr_roark
>... vertical banding, ...
I thought I'd must mention that I found gummed up rollers were causing
vertical banding in my 1800 with the glop overcoats.  A sheet of EEM
sprayed with ammonia across the middle and run the printer, followed by
some plain paper, seems to have taken a lot of ink off the rollers and
helped the vertical banding issue I was having.  (No clue as to the
print getting lighter or discolored)
2008-03-06 by ladder_logix
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "pr_roark"
> Paul
> www.PaulRoark.com
With the respect to the print getting lighter or discolored near the end:
I experienced the same problem with gold fiber silk and my 1800.  I
found that by attaching 2" extensions to the paper, using removable
clear tape on the back, and creating a custom paper size (to keep the
image centered on the paper) solved the problem.  The issue appears to
be with the transition of the paper feed rollers from 'front and rear'
to 'front' only.  Although this is not an elegant solution, it does
work for me.  My challenge has been keeping the face of the paper
spotlessly clean while taping on the extensions, where even a tiny
dust mote can ruin a print.
Joe Gaffen
2008-03-10 by Max Dee
no fix available...my experiance is this has a very soft coating
Eddie Wiseman <pahts@...> wrote:          Yes...
Eddie
Carl Schofield
> glop. i
Never miss a thing.   Make Yahoo your homepage.
2008-03-10 by Eddie Wiseman
THX Max..
At least I'm NOT alone..I guess it's just make "wider " margins...
Eddie
  Sent: Monday, March 10, 2008 6:43 PM
  Eddie
  Carl Schofield
  > glop. i
