Thanks, Gary, but I'm talking about _janitorial_ strength ammonia. Big
difference! And that's what Paul (the other one) was using.
Thanks for the vinegar tip... I've never tried that - will try that
next cleaning job I do, thanks.
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Gary Weaver"
<garww@...> wrote:
> Ammonia is a old household item and many of us use it. Always read
the label and warnings. Don't mix with bleech unless you know what
you're doing, etc.. Maybe you are extra sensitive. I buy Clear, with
blue (window) second choice. I also buy sudsy for general cleaning
sometimes.
> I don't really know about roller cleaning, but I do use my white
vinegar when I don't need the strength of ammonia. You can dilute the
ammonia with vinegar or water. I usually do vinegar with water and a
splash of ammonia when cleaning ink.
> gar
> *********** REPLY SEPARATOR ***********
> On 3/17/08 at 1:50 AM Paul Whiting wrote:
> >Hello Paul,
> >Do you find you have to be careful with that ammonia? I (stupidly)
> >took a whiff of it once and it really burned my throat... someone on a
> >forum somewhere suggested I not use it. But you apparently have found
> >a way to use it safely. I'm tempted to try that on my R220 rollers
> >which have trouble grabbing heavy stock.
> >Paul
> >--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "pr_roark"
> ><pr_roark@> wrote:
> >> I found my 1800 rollers had become fouled with all the glop
experiments.
> >> It was resulting in vertical banding and could be what you're
seeing. I
> >> clean rollers by spraying Ace Janitor Strength Smmonia across the
> >> central portion of an EEM sheet and running it through the
printer. I
> >> follow that with several sheets of plain paper. Then I repeat the
> >> process. I found in the first cycle the papers came out with lots of
> >> ink on them. The second cycle was clean. It seemed to work.
> >> Paul
> >> www.PaulRoark.com <http://www.PaulRoark.com>
> >> --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "jvircoe"
> >> <jvircoe@> wrote:
> >> > I am using a linearized version of Paul Roark's QTR profile C-3MK-
> >> > IlfordGoldFB-GL-1PK on A4 Ilfordgold Fibre Silk and MIS
inks/glop. I
> >> > am using MP-PK in the PK position. All other inks as described in
> >> > Paul's published PDF workflow.
> >> > When printing I specify 2880 and Uni-directonal.
> >> > I am achieving a D-Max of 3.15 - fantastic result. Thanks Paul.
> >> > (this was measured with my Colorvision/Printfix Pro spectro on a
> >> > black and white test image available at www.northlight-
> >> > images.co.uk/digital_black_white.html).
> >> > My only problem in an otherwise perfect workflow is that I am
> >> > experiencing very subtle vertical banding (about 3mm in width
> >> > (alternating dark and light bands) on A4 paper) in the same
direction
> >> > as the longest side of the paper. The banding is only visible in
> >> > constant mid-grey sky tones and while subtle is enough to put
me off.
> >> > I have tried adding grain to the sky (using Grain Surgery) but this
> >> > has not made a difference.
> >> > I have checked my nozzle print pattern - no problems there.
> >> > Any other thoughts on what I can try?
> >> > Thanks
> >> > Jim
> >> [Non-text portions of this message have been removed]
> >Please visit the Group Homepage to check the Files, and other
resources as
> >they are often being updated.
> >http://groups.yahoo.com/group/DigitalBlackandWhiteThePrint
> >If you wish to receive no emails or just a daily digest, or you wish to
> >unsubscribe, please edit your Membership preferences by visiting
this same
> >page.
> >Please follow these basic guidelines:
> >- As threads develop, trim off excess portions of earlier messages
to keep
> >them short.
> >- Good manners are required at all time. No personal attacks or flames.
> >Hostile, aggressive or argumentative users may be removed from the
> >membership without notice.
> >- Keep your posts and threads related to the group topic of digital B&W
> >printing. Users who persistently make off-topic posts may be
removed from
> >the membership.
> >- By posting on this forum you agree to abide by the group rules and
> >guidelines, and to abide by the actions and decisions of the group
Owner
> >and Moderators. See "Group Topic, Rules and Guidelines" in the Files
> >section:
> >http://groups.yahoo.com/group/DigitalBlackandWhiteThePrint/files/
> >BY PARTICIPATING IN AND/OR POSTING MESSAGES TO THE DIGITAL BW, THE
PRINT
> >YAHOO! GROUP YOU EXPRESSLY UNDERSTAND AND AGREE THAT THE "OWNER" AND
> >"MODERATORS" OF DIGITAL BW, THE PRINT YAHOO GROUP SHALL NOT BE
LIABLE TO
> >YOU FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, CONSEQUENTIAL OR
> >EXEMPLARY DAMAGES, INCLUDING BUT NOT LIMITED TO, DAMAGES FOR LOSS OF
> >PROFITS, GOODWILL, USE, DATA OR OTHER INTANGIBLE LOSSES (EVEN IF THE
> >"OWNER" AND "MODERATORS" OF DIGITAL BW, THE PRINT YAHOO GROUP HAVE BEEN
> >ADVISED OF THE POSSIBILITY OF SUCH DAMAGES), RESULTING FROM: (i)
THE USE
> >OR THE INABILITY TO USE THE DIGITAL BW, THE PRINT YAHOO GROUP; (ii)
> >UNAUTHORIZED ACCESS TO OR ALTERATION OF YOUR TRANSMISSIONS OR DATA;
(iii)
> >STATEMENTS OR CONDUCT OF ANY THIRD PARTY ON THE DIGITAL BW, THE PRINT
> >YAHOO GROUP; OR (iv) ANY OTHER MATTER RELATING TO THE DIGITAL BW, THE
> >PRINT YAHOO GROUP.
> >Yahoo! Groups Links
