Jack, Roger, Josh,
Thanks for your replies. I'll try to address all of them in one post.
I'm sorry that there seems to be a tone emerging of people taking
sides on an issue that, in my opinion, doesn't exist. I guess I
wasn't clear enough in my response to David, so let me try again: I
don't discount the scientific testing at all. I have quoted Wilhelm
numerous times here. I do feel that my kind of testing also has
validity. I don't see it as some sort of contest. I do not consider
my testing superior or better than scientific testing. Nor do I
consider it inferior. They are just different, apples and oranges,
and both have something to offer. Again, I feel there is a place for
both. Please don't make this a controversial issue.
>Here's the methodology...Would this be a useful test?
I really don't want to be in a position of passing judgement on that.
I am not trying to set myself up as an "expert" by posting my
reports. I do my tests because of an innate curiosity in general and
because I have questions that I'm not finding answers for elsewhere.
So my instinct here is to help you answer the question yourself: Why
do you want to do the test? What is it you want to find out from the
test? Will your test method provide the information you seek? I
think if you can answer those you'll have it.
Basically, my approach is that I do a test because I want to see what
happens. If at some point I find anything that seems significant I
post it here in case someone else might benefit from it. It's that
simple. I'm not trying to be another Wilhelm, I'm not trying to
compete in any way with anyone. 21 months ago I was trying out some
SR and I wondered how fade resistant this new wonder paper was. So,
in the motivation of the moment, I added one of the test prints to my
windowsill collection (there are currently 12 prints there of various
sorts). I happened to look at it the other day and said, "Wow! It's
been 21 months and no sign of anything, that's really good", and so I
posted a report.
>I'm also pretty certain that he does use a "control" sample that
>he keeps in dark storage in order to judge both fading and
>yellowing. Is that correct Clayton?
Well, yes and no. Of course I have some sort of control for
comparison. What I do is place a strip of 4-ply matt board across the
print so that it crosses over different tonal areas (many of my test
prints are ramps) and tape it in place. I place small pencil marks at
the edges to show where the strip is located so I can put it back in
the same place each time after I lift it up for a look. I label the
print with the date, paper name and ink used. Periodically I remove
the cover strip for a look. At some point if I begin to see some sort
of change I make a notation on the back of the print. That's pretty
much it.
>Clayton, have you done any K3 fade testing with any fiber matte
>papers? VFA
Yes, and I have commented on some of them occasionally over the past
few years. I currently have two VFA tests going, a windowsill test
and a torture test. BTW, my comment in my reply to David that a VFA
print showed signs of fading at 10 months was a mistake. That was a
Merlin Smooth print, I grabbed the wrong one - my apology for the
mistake. The windowsill VFA print is only 3 months old.
The torture test is putting an unprotected print, with a cover strip,
out in direct sunlight (S. Florida is sub-tropical and the sunlight is
intense), and I'm logging the amount of hours. Right now it's at 83.2
hours and showing no sign of fading.
As for OBA burn off, at 62 hours I thought I saw some "lessening" of
whiteness, but I'm not really sure. If it has changed, it's
minuscule. Sometimes I think I see it and sometimes I don't. If it
did change, right now after 20 hours more exposure it hasn't
increased. I still can't make up my mind if I'm seeing any change or
not, and I'm looking for it, trying to find some.
I'm not sure what 83 hours of direct sunlight translates to for a
framed-under-glass print on an interior wall, but it's certainly a far
cry from EEM which will turn yellow after two weeks on the kitchen
counter.
Clayton
I-Trak 2.1 http://www.cjcom.net/itrak.htm
