Question about Paul Roark adjustment layer for color inks
2008-03-31 by Roger
I have struggled to get a R220 to work as well with MISPRO color inks
as it has with MIS UTR2 inks.
Profiles from inkjetart.com, Cathy's profiles and PrintFixPro have
all come out with some serious problems as the ICC profiling process
doesn't seem adequate to correct huge the color shifts when using
these pigment inks with a driver that expects very different dye-
based inks.
I was intrigued by this method of using adjustment layers instead of
ICCs and was wondering if Paul or anybody could offer advice for how
to derive my own curves for use with the R220.
http://www.paulroark.com/BW-Info/R260-Color.pdf
I have a PrintFixPro unit.
I also bought an R1800 hoping that would solve my color issues but
the model I got seems to spray ink internally, so I have to have it
replaced. In the meantime, back to the R220.
Best,
Roger
Re: Question about Paul Roark adjustment layer for color inks
2008-03-31 by pr_roark
The color profile I use with the 260 is simply a curves set that
makes a grayscale 21-step test file print as a relatively neutral
print with a ramp that about matches the Gray Gamma ramp. It was just
manually made with the usual iterations and a ColorVision PFP
spectro.  It works well in the neutral range, which of course is how
it was made.  It is less accurate with very saturated colors.
In actual practice, I use it for my color snapshots.  I find that
different shots need the layer at different opacities.   It works
well enough that I have not bothered to do any more serious profiling
or switch to another approach.  I do not represent it as professional
quality profiling -- I'm not making "giclees" with it for the
painters in the gallery.
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Roger"
inks
process
> based inks.
of
how
> Best,
> Roger
2008-04-01 by Roger
Thanks.  I found with the PFP profiles I had some weird color jumps
in the shadows (fog being way too bluish for example) and thought
your method might help keep it realistic.
I downloaded and looked at your curve with the per channel
adjustments.  I also have PFP and your 21 step grayscale wedge (which
is VERY useful!)
You seem to be using it to both linearize and get a neutral grayscale
simultaneously.  Do you have any references on how to do this?  I
don't have a background in manual curve creation.
Say if step 17 (80%) is L26.47 a= 1.98 b= 6.61
I'd want to counter the postive b by increasing the blue channel
somewhat and reduce the a by increasing the green channel, but
overall for this point I also have to either reduce or increase L* to
linearize the curve.  Is there an equation to assist with this?
Otherwise it would seem like an awful lot of trial and error.
Also, on an unrelated note, I'm going back and reprofiling my R220
using UTR2 with glossy media.  By using RPM and checking Microweave
I'm getting much higher dMaxes- increasing from 2.13 to 2.32 on
Kirkland Glossy, getting 2.25 on Silver Rag, 2.15 to 2.36 on Harmon
FB Al, etc.  It also has no microbanding under a loupe which is nice.
Downside is that prints take forever.
Roger
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "pr_roark"
just
how
profiling
professional
> Paul
> www.PaulRoark.com
> inks
have
> process
> > based inks.
> of
> how
but
it
> > Best,
> > Roger
2008-04-01 by pr_roark
Hi Roger,
> ...your 21 step grayscale wedge (which is VERY useful!)
I use 21-step files for most tests.  QTR can handle 51 steps also,
and I wish I had a better one.  I made a vertical one that sometimes
helps, but I found the horizontal, 3-row one in QTR appeared to be
affected by vertically running artifacts.  Even on matte papers the
rollers and perhaps other things do leave their marks, even if
invisible in most situations.  The 51 steps are so close, however,
that they can be affected by the artifacts -- or so my tests suggest.
So, I generally use 21-steps and keep in mind that the curves must
have smooth transitions to avoid a wiggle that is smaller than the
relatively wide 21-step spacing would "see."
> neutral grayscale simultaneously.
Yes, I look at and adjust for L, A & B and the same time.
I'm not sure I've written up much detail.
First, I use Excel to open and graph the PFP text files.  So, open in
Excel, highlight the L column, then go to the top and Insert a
Chart.  Use the Line type.
For L, just take a straight edge and draw a line from the first to
the last dot.  This is what a linear rip will print when linearized.
RGB (like Gray Gamma 2.2) will compress the shadows, so in fact, draw
a line from the paper white to a 95% that would be barely above where
the 100% is.  This line is your guide.
Where a dot of above the line, you'll want to adjust R, G, & B curves
accordingly.
If the points in the Lab A & B measures are neutral, adjust all three
equally.  Nore on the graph how much, so you learn at the next
iteration how much a move by X points changes the output.
You need to be familiar with Lab A & B.  If the print is too yellow,
you'll adjust the blue curve accordingly.  If the point has a perfect
Lab L but has a high Lab A, you'll reduce M and increase C by the
same amount.
You'll get the hang of this after a few iterations.
So, it's a process of printing the 21-step file with the last curve
(which is saved with the iteration number in the name), measuring the
print (after a hair drier is used on it), graphing the results, and
making appropriate adjustments in the curve.
I don't think in L numbers.  I just graph and draw a line for
reference, keeping in mind the final should have the compressed toe.
> a= 1.98 b= 6.61
A=1 is OK.  See where the paper white is and use that for a
reference.  "Neutral" is defined by the paper for Lab A the way I do
things.  These spectros are not very accurate at these very low
readings, so the paper white serves as a calibration point, and I
think you'll see most papers aim for a slightly positive Lab A.
Yes, but confusion can arrise is what is meant by "increasing."
The curves have 2 modes.  The 0 - 100% ink mode is easier to deal
with, but less accurate.  You'll find you're limitted even by the 256
steps of the 0 - 255 luminance mode.
Just keep in mind that moving the blue curve toward the darker side
increases the yellow ink.  So, how people think in complementary
colors probably differs, but I mentally label the curves by theie
complement.  That way "more" ink in the 0 - 100% ink mode means more
yellow is injected when the blue curve (which I think of as yellow)
is moved to a more positive number.
No, green is not opposite of blue.  I make the Lab L, A and B moves
separately just to keep it simple.  To keep L equal I'd increase Blue
2 units and reduce G and R one  unit each.
> ...  Is there an equation to assist with this?
There is trial and error, but you'll find you learn how much to move
each point.  By keeping track of your moves on the graph you've
printed you can see how much to move the next time.  The iterative
process works well, and I think you'll find you learn how much to
move things quickly.
> nice. Downside is that prints take forever.
Yes, I do the same thing.  I'm using an old 2200 with Carbon-6 (with
cheap SuperJet CIS -- working perfectly) and have it on 2880 slow for
ultimate smoothness.  If I were a service bureau I'd probably crank
it up to 1440 HS and hope the customers didn't use a loupe on the
print.  But, given my low volume, I feel better with the perfect
prints, and the speed is very secondary.
Good luck with the profiling.  Once you get the hang of it, you'll
seldom have to do more than a half dozen iterations.  Fortunately,
most papers of the same basic type use the same basic curves.  I have
only one layer for the 260 and use is with all my matte papers.  The
opacity slider on the layer is usually all I need to adjust to
account for paper differences.  I also find I usually want the
saturation increased 25% with the 260.  The MIS pigs simply are not
as high gamut as the Claria inks.
