Best MIS PK for use in R1800
2008-04-04 by Roger
I'm trying to figure out which PK to use in the R1800. Paul shared some advice here: http://www.paulroark.com/BW-Info/3MK-Glossy.pdf "Initially I used MIS K4-PK is in the Red position, and MIS R2 PK is in the Blue position. I will probably change this, as the MP-PK seems to achieve a higher dmax at a lower ink limit than the 4k-PK. The R2-PK was optimized for the R200 printer and has 10% blue pigments in it. I'm having a little trouble deciphering which PK is which. MP PK = ? 4k-PK= K4-PK? I'm wondering what Paul and others settled on for a high Dmax on gloss-type papers with this printer. I have UTR2 PK and MISPRO PK lying around that I used with my R220. I'm finding that the PK I got from the MIS R1800 color ink set is hiting max density too soon and forcing me to drop back from Photo RPM to best photo to avoid density reversals. Unfortunately doing so leaves me with a lower Dmax than I was getting with the R220 and some moderate microbanding.
