R1800 for Paul Roark
2008-04-24 by Nancy Wilson
First, thank you for responding to my query re. printing problems with my R1800. I think I am getting close to resolving issues and awaiting new inks to find out. I now have some questions regarding a previous post where you are identifying inks you use as you are experimenting with the new gloss papers. > I have not had any clogging issues, but, nonetheless, I've set mine > up now with Eboni in C, MK and PK, and cleaning fluid "insulatore" > next to the 3 Eboni positions. > Because I do want to continue to experiment with the glossy papers > and 100% carbon printing, I also have MIS Pro PK in the Y position > and glop in the GO and Blue spots. Another reader responded: "So lineup, from left to right is as follows? --- Normal: Y M C MK PK R B GO You: Pk cln Eb Eb Eb cln GO GO" Here is my question: As the cartridges EB for the PK, MK, and GO are not interchangeable, how do you achieve printing capabilities with MIS PK in the Y position, Eb in the C position and GO in the B position. When I posed that question to Inksupply.com, they had no idea. I assume you must be using a continuous feed system. Are those carts still available? Thank you in advance. Nancy
