Making ICCs with a Flatbed Scanner
2008-05-03 by pr_roark
I've modified my procedure for using QTR's Create ICC with a flatbed
scanner.  I hope it's a little easier to follow.  See
http://www.paulroark.com/BW-Info/Making_B-W_ICCs-1.pdf
For the example in the PDF I used a 2200 with Carbon-6.
If one has a spectro, of course, the job is easier.
The basic procedure for Create ICC is to print a 21-step test strip,
measure the relative densities of the 21 test patches, put the
readings in a text file, and drag and drop the text file to the
Create ICC icon on the Desktop.
This is a very simple way to profile papers and printers with
monotone inksets as long as the inkset is reasonably compatible with
the printer driver's assumptions about ink densities.  This includes
the Eboni-6 and Carbon-6 inksets.
Re: Making ICCs with a Flatbed Scanner
2008-05-03 by steve_wadlington
Thanks Paul,
This is great for us that have too much to assimilate. Even I can
understand this! I was fighting with the Epson scanner input, output
and gamma settings trying to get the q13 linear, it's enough to drive
you crazy.
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "pr_roark"
flatbed
strip,
with
includes
> Paul
> www.PaulRoark.com
2008-05-06 by mbrouphy
Paul, Thanks for responding so positively to my apparent confusion
with your previous process.  I've printed it out and will work with
it tomorrow and report my results tomorrow.
Thanks again, Mike
flatbed
strip,
with
includes
> Paul
> www.PaulRoark.com
2008-05-06 by pr_roark
> See http://www.paulroark.com/BW-Info/Making_B-W_ICCs-1.pdf
I've added an example where a standard 18% Kodak Gray Card is used to
calibrate the scanner.
See http://www.paulroark.com/BW-Info/Making_B-W_ICCs-GrayCard.pdf
I suspect a lot of people have these lying around.
