Just a thought but what is the file structure of your file for QTR
printing? I usually do my image editing in RGB b/w, 16bit, PSD file
format and then when ready to save for QTR printing I convert to
grayscale, 8 bit, and save as a compressed TIF file. The QTR info
says that it will convert if necessary to make the TIF file a
grayscale 8-bit file. Regardless of processing this conversion takes
time and on an older PC this can be important.
Just my thought...Mike
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "djon43"
<djon43@...> wrote:
> I suggest you upgrade to XP. It's been rock-steady for me since the
> beginning...no issues at all with a dozen machines, including the 4
I
> use today.
> With XP a big print might take 5 minutes (I've never timed). Not at
> all frustrating.
> You might also look at RAM (QTR/2200 is happy with as little as
512KB)
> and at free space on C-drive (do disc cleanups).
> --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Tim Atherton"
> <timatherton@> wrote:
> > any ideas anyone? (I've asked on the QTR list with no results...):
> > I'm not sure if this was due to changes in printers or in
versions of
> > QTR, but when I used an Epson 2200, this was never a problem.
> > Then I found that with an Epson 2400, QTR was taking forever to
> > process and/or (I'm not exactly clear on what the actual process
is
> > it goes through...) spool prints
> > Doesn't matter if they are 8x10 or 13x19 - the former just don't
take
> > quite so long. But for a 13x19, I'm talking 30+ minutes
> > I recently got a 3800 and thought maybe it was just the interface
> > with the 2400, but no - I get the same.
> > I've tried various different connections - Firewire, USB,
Network -
> > same for each. I've also fiddled with all sorts of different
Windows
> > settings, but none made a difference.
> > This is compared with using the Epson driver that for the same
print
> > takes maybe 4-5 minutes at most
> > All on the same (somewhat old, but still fairly fast) Windows 2000
> > machine
> > Any ideas or suggestions (as I really like QTR...)
> > thanks
> > tim a
