Hi Mark:
Thanks for your kind words. I agree that it is very difficult to
inspect a full roll, and it is difficult to send one back, let's say,
if you already printed 60% of it and then find a major problem.
I also prefer to brush fine art paper in sheets away from the
printer, and that I've found to be easier to do with sheets.
All the best,
Andrew
Andrew Darlow
Editor, The Imaging Buffet
http://www.imagingbuffet.com
Author, 301 Inkjet Tips and Techniques:
An Essential Printing Resource for Photographers - http://
www.inkjettips.com
On Jun 19, 2008, at 3:28 PM, Mark McCarvill wrote:
> Good article, Andrew.
> Another point in favor of sheets from my experience is that you can
> inspect them more easily for flaws before printing. (By `flaws' I mean
> dark specks or whatever that are engrained in the paper and can't be
> removed by brushing and air-blasting). With rolls you can do this too,
> of course, but you have to feed out the paper and it's a bit of
> hassle. And if you're using two-sided paper as I do, you can't easily
> check the under-side of a roll to see if it's better, but you can do
> so easily with a sheet.
> I've wasted so much time and paper on roll-paper prints that wind up
> with a black speck right in the middle of the sky!
> Mark
> --- In DigitalBlackandWhiteThePrint@yahoogroups.com, Andrew Darlow
> <ad@...> wrote:
> > Hi folks:
> > I recently wrote an article for Adorama's "100 in 100" series about
> > when to use sheets vs. rolls.
> > I've found that some companies are much better than others with
> > regard to providing quality cut sheets. It is not easy for companies
> > to cut paper perfectly square, with minimal shedding and with little
> > to no curl (especially with many fine-art papers).
> > The article can be found here:
> > http://www.adorama.com/Catalog.tpl?op=academy_new&article=061908
> > or
> > http://tinyurl.com/4xbtww
> > All the best,
> > Andrew
> > Andrew Darlow
> > www.inkjettips.com
