C6+ toners
C6+ toners
2008-07-16 by met.graphix
This is more of a speculative question at this point, mainly for Paul I
suppose, or for others with experience with the carbon 6 inkset. I have
just setup a 2200 with the C6 inkset and I run it with QTR . Good
results so far, to the point that  I'm tempted to move it to the 7600
that is currently running a K4+ inkset. However, as much as I like both
the look of the C6 prints and the purist approach behind it, I still
need the flexibility of tone afforded by the K4+ inks for a number of
reasons. I also found that a few images do not print as well on C6 as
they do on K4+. For this I wonder whether the C6 can be made into a 5C+
with 5 carbons + LLC and LM on the 7 inks printers. This, when driven
with a RIP would allow one to print both pure carbon (5C versus 6C
shouldn't make a big difference I suppose) and also get truly neutral
tones when required.
The main question in my mind is compatibility between the Carbon base
and the LC an LM, any major issue there?
Any other possible problem?
Dario
Re: C6+ toners
2008-07-17 by pr_roark
Dario,
Even my old 7500 looks OK at display print size with only 5 carbons
firing.  So, in an k2 printer, you'd almost certainly have the
smoothness you need with only 5K.
I have not loaded a printer with the C6 base carbons in addition to
MIS or Epson LC and LM.  On the other hand, in anticipation of this
very issue, I've had a test tube mix of Epson UC M highly diluted in
the C6, generic base for 2 months, and it looks perfect.  I favor
Epson M over MIS M.  So, diluting UC M with the C6 base is where I
was intending to go with this approach, and so far, I've seen no
evidence of incompatibility.
(Note that MIS warns that the Eboni-6 inks are not compatible with UC
inks, but it's the commercial dilution base that is the problem.  The
C6 base is different.)
While my test tube experiment is not a guarantee that there will be
no problems, I've seen strange results and very fast settling of UC M
and other pigments in some other bases.  In short, my best guess is
that we can buy UC M in 7600 carts and dilute it with C6 base to get
an economical LM.  The usual dilution for LM is 30% M to 70% base.  A
higher dilution would be smoother.
Let us know how it works if you give it a try.
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "met.graphix"
Paul I
have
7600
both
still
of
as
5C+
driven
neutral
base
> Dario
Re: C6+ toners
2008-07-17 by met.graphix
That's great info Paul. As far as the LLC goes, if the proportions
are the same as the M ink I assume we would start with MIS full C and
dilute with the C6 base to something like 15% C to 85% base?
Dario
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "pr_roark"
<pr_roark@...> wrote:
> Dario,
in
UC
The
M
get
A
> Paul
> www.PaulRoark.com
Re: C6+ toners
> Dario
That should work.
Re: C6+ toners
2008-08-02 by Joost Horsten
in
Paul,
An obvious alternative thought is to mix the toners directly with the
gray inks in order to obtain a neutral tone. This would then be very
similar to Cone's neutral K6 inks. It's of course an option just to
purchase these inks, but both in terms of cost saving but also an
interesting journey, I'm interested to understabd if this can be a
feasible DIY project, especially for older, large droplet printers.
As toner one can probably either use a combination of Cyan and
Magenta or your R800 Blue. The key question is if one can expect that
the ratio of toner vs. carbon is the same for all ink shades. If so,
than the mixing and dilution process can be quite simple, rather
similar to you C6 scheme. If not, than both the research and the
dilution process become rather complex.
Any thoughts on this?
Joost
Re: C6+ toners
2008-08-02 by pr_roark
Joost,
> An ... alternative ... is to mix the toners directly with the
We know the "glossy" MIS carbon pigments are compatible with the MIS
color pigs.  They are blended in inksets such as the new UT-14.  The
cyan channel of the UT-14 inkset is a 60/40 carbon/color mix.
See http://www.paulroark.com/BW-Info/UT14.pdf
These inks use the base that is the same as Glop and are, of course,
glossy compatible.
I have not tried an Eboni-MIS color blend in the generic C-6 base.
It might well work.  (The compatibility concern of MIS was the Eboni-
6 base and the UC pigments.)  I'm probably not going to make such an
inkset, however.
Even when the MIS R800 Blue pigment is used instead of magenta you'll
need cyan in the mix.
> The key question is if one can expect that the ratio of
It's not, and it may change for each paper.  That is one of the
compromises of a blended inkset.  Dealing with the need to vary the
toner/carbon ratio is what led me to the variable-tone approach in
the first place.  Software (curves and profiles) allows us to control
the ratio much more easily than having separate mixes.
Then again the ideal cyan/magenta ratio will also vary.  That led to
the 3D inkset.  But at some point the "cost" of perfection in terms
of work exceeds the benefits.  So, I'm back to the simpler variable-
tone approach in the UT-14 inkset.  It's simple and does a very good
job, even if not perfect.
