OT - Network Printer QTR
2008-07-31 by shileshjani
Hello All,
I have recently found a desire (but not a need) to move my 4000 and
2400 printers to the opposite side of the room. I would like to do away
with cable-clutter, and so would like to network the printers through a
print server running on powerline network. Will I be able to run QTR
through such a set-uo?
Thank you.
Shilesh
Re: OT - Network Printer QTR
2008-07-31 by Joost Horsten
Yes.
I have a 2100 that is connected to a printserver and I drive it with
QTR running on my desktop. My network is ethernet based, not
powerlink, but will not make a difference as QTR can not tell what
physical layer is used.
Joost
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "shileshjani"
<janishilesh@...> wrote:
> Hello All,
away
through a
QTR
> Thank you.
> Shilesh
2008-07-31 by Chris Ellis
Hi Shilesh
Have you considered wireless print servers?
I have the same problem and these could represent an easy and fairly
cheap solution  (e.g.
http://www.dabs.com/ProductReviews.aspx?Quicklinx=4CWR&CategorySelectedId=11179&InMerch=1).
 It seems that you can plug a usb printer into the adapter and install
the drivers to the adapter via your computer.  The printer then
appears as a location on your network.  Some apparently have their own
memory so can buffer the print job thus freeing the memory on your
computer more quickly.  It's certainly cheaper than buying a new
computer to run as a server (although you may have one already).
But do they work in practice, especially with larger print jobs?  Are
there any transmission problems resulting in loss of print quality /
increased printing time?
So more of a further question than an answer to yours but perhaps it
will give you some other options.
Cheers
Chris
Re: [Digital BW] Re: OT - Network Printer QTR
2008-08-01 by Marco Brambilla
Hi Chris, all
One work of caution: these do not work with "gdi" (I hope it's the
correct term) laser printers. These are the printers where the rendering
engine is really the driver and not the printer itself.
I am not aware of any non-laser printer that has this limitation, though.
Ciao, Marco
Chris Ellis wrote:
> Hi Shilesh
> <http://www.dabs.com/ProductReviews.aspx?Quicklinx=4CWR&CategorySelectedId=11179&InMerch=1>).
> Cheers
> Chris
