Epson 1400 printer fault
2008-09-09 by alistair_owens
Hi there,
I am interested in purchasing an Epson 1400 currently advertised for
sale. It is well priced but has a fault described as follows:
"This is a brand new printer but im selling because it has a paper
registration error (basically means that it will print perfectly up
until it reaches the last couple of inches of the page and then the
printer will not hold the paper in place while it finishes printing so
the bottom of your page may not be aligned properly.  I've been told
this is a common fault (known as a paper registration error) and can be
fixed easily "
Dies anyone on the board know whether such a fault is in fact common
with these printers and know whether it is indeed fixed easily?
Thanks and regards
Alistair
Re: Epson 1400 printer fault
2008-09-09 by maximalimage
--- In
DigitalBlackandWhiteThePrint@yahoogroups.com, "alistair_owens"
<owens@...> wrote:
> Hi there,
for
up
printing so
told
can be
> fixed easily "
common
> Thanks and regards
> Alistair
Alistair, check out the refurb's ar Epson (free shipping).  I just
bot a 1400 there for $143 and put Jon Cone's K6 CIS in it.  It works
great.
Bill
2008-09-09 by pr_roark
>... Epson 1400 ... paper registration error (basically means
> that it will print perfectly up until it reaches the last couple
> of inches of the page and then the printer will not hold the
> the bottom of your page may not be aligned properly...
>... common fault (known as a paper registration error) and
> can be fixed easily ...
Common but not easily fixed might be more accurate.
The problem seems to be that at the very bottom of the page printers
rely on the exit rollers for paper tranport.  These exit rollers are
often -- if not always -- not up to the job. The printers with
the "vertical" (relative to the paper) head alignment have more of a
problem because the distance between the main rollers and exit
rollers is greater.  The trough where the head runs used to be very
narrow.  Now it's grown to about 1 3/4 inch due to the space some of
the new or vertically positioned heads need.  In the older printers
we could totally disable the exit rollers to avoid pizza wheel marks
and not have any effect on the print, at least if you didn't tell the
driver to center the 8x10 image on letter size paper.  You can't do
this on the printers with these large gaps between rollers.  I've
noticed the problem on not only the cheaper printers, including the
1400, but also the 1800.
The bottom line is that on a number of newer printers a 9 x 7 inch
print on letter size paper may be the maximum that will really be
good.
Have you noticed that if you simply print an 8 x 10 image on letter
size paper, and do not tell the driver to center it, the bottom
margin will be larger than the top?  There is a reason for this.
I don't know if the problem can be fixed.  Epson either has to put
more serious exit rolers on printer (messing up the glossy prints) or
go back to the narrow, horizontally placed heads (slowing up the
printing speed -- and Epson's sales).
It's possible some of these printers are built worse than others and
show more of the defect, but I think it's a design problem with many
Epson printers.
The solution is to have very substantial bottom margins if you want
to avoid microbanding there.  In fact, the 1.5 pl printers seem to
also have a slight problem at the top of the page.  It seems to be
less of a problem (narrower), but the paper transport is so critical
that having both sets of rollers engaged is where the best printing
occurs.
Re: [Digital BW] Re: Epson 1400 printer fault
2008-09-09 by Michael King
Just to add that the 1900 has the same problem.
Its a design compromise issue, not a build quality problem.
At least when both rollers are engaged the print quality on these 1.5pl
printers is excellent.
Just need to use a bit longer paper than before. I am using A3+ cut in half.
Mike
2008/9/9 pr_roark <pr_roark@...>
> good.
> Epson printers.
> occurs.
> Paul
> www.PaulRoark.com <http://www.paulroark.com/>
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "pr_roark"
Thank you Paul so much for your comprehensive reply and also Michael
for your added comments regarding the 1900.
On this basis I think I may just look around for a couple of 1800's
to play with.
Thanks again.
Alistair
2008-09-09 by Phil
maximalimage wrote:
> --- In
> <owens@...> wrote:
>> Hi there,
> for
> up
> the
> printing so
> told
> can be
>> fixed easily "
> common
>> Thanks and regards
>> Alistair
> great.
> Bill
> - By posting on this forum you agree to abide by the group rules and guidelines, and to abide by the actions and decisions of the group Owner and Moderators. See "Group Topic, Rules and Guidelines" in the Files section:
> BY PARTICIPATING IN AND/OR POSTING MESSAGES TO THE DIGITAL BW, THE PRINT YAHOO! GROUP YOU EXPRESSLY UNDERSTAND AND AGREE THAT THE "OWNER" AND "MODERATORS" OF DIGITAL BW, THE PRINT YAHOO GROUP SHALL NOT BE LIABLE TO YOU FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, CONSEQUENTIAL OR EXEMPLARY DAMAGES, INCLUDING BUT NOT LIMITED TO, DAMAGES FOR LOSS OF PROFITS, GOODWILL, USE, DATA OR OTHER INTANGIBLE LOSSES (EVEN IF THE  "OWNER" AND "MODERATORS" OF DIGITAL BW, THE PRINT YAHOO GROUP HAVE BEEN ADVISED OF THE POSSIBILITY OF SUCH DAMAGES), RESULTING FROM: (i) THE USE OR THE INABILITY TO USE THE DIGITAL BW, THE PRINT YAHOO GROUP; (ii) UNAUTHORIZED ACCESS TO OR ALTERATION OF YOUR TRANSMISSIONS OR DATA; (iii) STATEMENTS OR CONDUCT OF ANY THIRD PARTY ON THE DIGITAL BW, THE PRINT YAHOO GROUP; OR (iv) ANY OTHER MATTER RELATING TO THE DIGITAL BW, THE PRINT YAHOO GROUP.
