Scan Resolution for a 4X5 Black and White Negatives
2008-09-21 by ag000002002
I wish to scan some of my old work and print approximately 12" X 15"
prints on an Epson Photo 2200.  I can get a drum scan locally at 100
dpi, 200 dpi and 300 dpi.  Would someone please explain how to
determine what I need?  Does it depend on the printer or are the ones
available all about the same?   Soon, I may purchase one of the new
Epson printers, for example the Epson Photo 2400.  Since the scans are
expensive, I would like to scan them today with the newer printers in
mind.  Thanks in advance.
Andrew.
Re: Scan Resolution for a 4X5 Black and White Negatives
2008-09-22 by blueto49
Andrew,
When talking to service bureaus or other companies to have negatives
scanned they generally are giving you an output resolution at the size
you want to print at. (make sure you are talking the same size finished
print!) What you really want to know is the input resolution, which is
the dpi of at the size of the negative.
In either case 100 output res would not be acceptable. 200 or 300 dpi
might be okay. I prefer 600 myself.
A 300 dpi output scan for a 12X15 would be equal to a 900dpi input scan
of the neg.
Some feel that 2000 to 2500dpi at the negative size is adequate to
capture all of the detail on the film. This would be 667 to 833 dpi
output res for a 12X15. I have done 2400 dpi sans with my old Howtek
but the file sizes go into the hundreds of MB which I generally down
sample prior to printing, but I still have the high res file if I ever
want to print larger.
I would suggest getting your own scanner so that you have creative
control at this critical step.
Best,
Martin
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "ag000002002"
> Andrew.
2008-09-22 by ag000002002
You are right, those were the output resolutions.
For a 12x18 print, the service bureau offers:
100 dpi (1200x1800) which is a 6 MB file;
200 dpi (2400x3600) which is a 25 MB file; and
300 dpi (3600x5400) which is a 56 mb file.
I am wondering whether these desktop printers I mentioned (Epson Photo
2200 and 2400) can use all the information in the big files?
A.
Re: [Digital BW] Re: Scan Resolution for a 4X5 Black and White Negatives
2008-09-22 by Bill Morse
I would try to avoid "service bureaus" that talk in those terms. They really
aren't telling you what you need to know. For an inkjet print you want
240-600 DPI at print size; but you also should be asking yourself (and they
should definately be asking you!) what is the largest print you can forsee
making of this image, and you should be assuring yourself of adequate file
size to print that largest size.
Decide on the largest print size, and what resolution you want at that size,
and size times resolution will get you the total file size in pixels; make
sure whoever scans the film gives you at least that much.
But just as important is the quality of the scan. Make sure that whoever
does your scanning understands your needs as the photographer, and will work
to meet them.
Bill
> A.
Bill Morse
Wm. Morse Editions
http://www.MorseEditions.com/
RE: [Digital BW] Re: Scan Resolution for a 4X5 Black and White Negatives
2008-09-22 by don.swanson
The Epson 2200/2400/3600 printers can use all of the information
in a 56mb file. That is the resolution that I use for my 2200.
[mailto:DigitalBlackandWhiteThePrint@yahoogroups.com]On Behalf Of
ag000002002
Sent: Sunday, September 21, 2008 6:23 PM
Subject: [Digital BW] Re: Scan Resolution for a 4X5 Black and White
Negatives
A.
2008-09-22 by steveabrink
4X5 Black and White Negatives can hold a tremendous amount of
information --on the order of 2000+ ppi optical to capture all the
potential data.  Yes, it takes tremendous data storage but you can
downsample for printing at 360 ppi.
SteveB
> Andrew.
2008-09-22 by Ernst Dinkla
Yes, it looks like they scan the 4x5 at 1200 PPI in best
case. One wonders if that actually is done on a drum scanner
then.
Met vriendelijke groeten, Ernst
|  Dinkla Grafische Techniek  |
|     www.pigment-print.com    |
|             ( unvollendet )            |
2008-09-22 by Roger
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "steveabrink"
> potential data.
Isn't that true for any film and why we have 4000dpi desktop scanners
for 35mm?
I'll agree that a 16 bit 4000dpi scan of 4x5 inch film is ridiculously
large.
2008-09-22 by Bruce Watson
> SteveB
I've studied this for a number of years now. Listened to lots of
arguments on the various lists and groups. Asked a bunch of questions
and gotten all kinds of answers. What it all boils down to is that there
are three basic schools of thought about scanning resolution. Which you
believe determines what your favorite scanning resolutions are and what
your limits are.
The first school thinks that you should scan at max resolution of the
machine no matter what. Then you down sample to your output size. This
act of downsizing also downsizes any scanning noise along with it.
The second school thinks that you should scan at "average grain size"
for the particular film in question. So films like Velvia they scan at
5000 spi or so, and films like Tri-X at 3600 spi or so. Another part of
this group thinks it's not so much "average grain size" as it is to scan
at a solid output resolution (like 300 ppi) at full print size, which
ends up mostly being in this school for better or worse.
The third school thinks that you should scan considerably under "average
grain size" to capture just the image information and none of the film
grain. So they scan around half the resolution of the second school.
Which you believe is sort of like picking a religion. As a drum scanner
operator I've made the time to do some testing making prints. It doesn't
matter what the file looks like on your monitor because the object of
the exercise is making prints, yes? So I made a bunch of scans at
different resolutions, printed sections of the resulting files and put
them all up on my proofing wall under the same lights to compare.
My conclusion was that the second school was more fitting for my own
work -- no lower than 300 ppi output resolution at full print size.
Clearly YMMV and you should do your own testing to find out what really
works for you.
Bruce Watson
2008-09-22 by john dean
Bruce,
I pretty much agree with your conclusions. However, I find color
transparencies to scan at the higher ppi resolutions MUCH smoother
than film does, like say Tri X or even color neg film, especially very
fast color film.
I also think this varies with the particular scanner. On my old
Howteks I actually see smoother less grainy rendition when scanning
the same output of 4x5 at 2000 ppi vs 4000 ppi. That is evaluating the
print from those scans as well as the file on screen. A lot depends on
how large you have to go with the print of course and how much
sharpening you have to do.
I noticed on the DPL software on an Aztek drum scanner( which I
personally don't have) that they have recommended settings that
actually scan negs at lower ppi than one would want for a particular
file size when printing at 360 dpi or so. In other words upsampling a
smaller file size scan actually was used in that case to achieve a 360
dpi print resolution.
I think the quality of the software used, the quality and age of the
scanner used, and the type of film all play a role but.. my overall
impression is that I never scan anything with higher scanner ppi than
I am going to need for a particular print size. In the end, I think
you have to get to know the qualities of your own equipment.
John
> works for you.
> Bruce Watson
2008-09-23 by Bruce Watson
john dean wrote:
> Bruce,
> fast color film.
Not surprising. Graininess is directly related to density. With
trannies, the density is in the shadows. The highlights of trannies
therefore have the much less graininess (smallest dye clouds and the
loosest spacing of the dye clouds) than the shadows by definition. So
they darn well better scan smoother!
Two different apertures. You trade away a little sharpness to gain a
little smoothness when you increase aperture size. The 2000 spi scan is
indeed a little smoother. This is one of the differences between school
two and school three, and why school three has such strong adherents.
Yes, I've heard this several times from DPL users. There are many paths
to the waterfall, and this is the path that Aztek is pushing. I don't
know if it's right or wrong for Howtek hardware / software or for any
particular piece of film, but it sounds like my school three (low rez
scanning) which again many people support.
I've also heard from a few Howtek operators that they routinely open up
one aperture size from what the scanner normally computes for them. The
reason seems to be that the Howtek scanners (optics, circuits, firmware,
software, or some combination) creates a scan file that is what one guy
called "crunchy" (his word, not mine) which I interpret to be a high
level of local contrast. This in turn shows up graininess fairly well.
The larger aperture lets more light reflect onto the edges of the grain
clumps / dye clouds and therefore makes the edges less visible and the
grain clumps look a little smaller (like moving from a condenser
enlarger to a diffuser enlarger in the darkroom IIRC). Some operators do
this routinely, some do it when they think it's necessary, and some
won't do it at all.
Just to be clear I should point out that this applies to all drum
scanners regardless of make, not just Howteks. I don't mean to imply
that there is anything inherently wrong with a Howtek scanner, it's just
the scanner that John is talking about here. Aztek who makes the Howtek
scanners is one of the last three drum scanner manufacturers left
standing so they certainly are doing something right!
> John
Absolutely. There are way too many variables here, just in the machines,
not to add the software, film, photographers' exposure workflows,
processing, etc. and the vagaries of scanner operators (oh yes, I'll
admit to that!) to give a definitive answer to any of these kinds of
questions. So all I'm trying to do is point the OP in the direction in
which the truth for the OP probably lies. Hopefully. Maybe.
Bruce Watson
2008-09-23 by john dean
That's very useful Bruce, regarding the opening up of the aperture to
reduce grain. There is a Gain setting with Silverfast that I'm using
but I never use it.
One thing that I have noticed routinely with the Howtek when scanning
black and white film is that with my unit the scans are a bit over
sharpened at 4000 ppi, making them apper more grainy,esp 35mm tri-x. I
add a tad of gaussian blur and it is smoothed out. Increasing the
aperture in Silverfast would probably be a better method. I'll try it!
Thanks.
John
2008-09-23 by Tyler Boley
John, I believe we have the same setup? Give it a try with those 4000
ppi scans, sometimes even open 2. How helpful it is depends on the
image and grain. I just do several scans as long as the neg is
mounted, with different settings...
With small film though, I stick to native aperture.
Tyler aka "crunchy"
http://www.custom-digital.com/
> but I never use it.
> Thanks.
> John
2008-09-23 by E Neilsen
And now try and offer "noise reduction help" across the board when many
"professional users" think sRGB is a great color space for all work, Don't
You".
Many aspects are so image dependant. Isn't the new digital paradigm fun ; )
Eric
Eric Neilsen Photo
4101 Commerce Street, Suite 9
Dallas, TX 75226
214 827-8301
SKype ejprinter
Bruce Watson
_,___
From chruchy, is it not always easier to make soft than the other way
'round?
Eric
Eric Neilsen Photo
Dallas, TX 75226
214 827-8301
SKype ejprinter
  _____
[mailto:DigitalBlackandWhiteThePrint@yahoogroups.com] On Behalf Of Tyler
Boley
Sent: Monday, September 22, 2008 10:20 PM
Negatives
Tyler aka "crunchy"
http://www.custom- <http://www.custom-digital.com/> digital.com/
> but I never use it.
> Thanks.
> John
yes, though I'm not sure there's a software move that is the same as opening the aperture,
assuming anyone wants that.
On the other hand, some of the work I've done lately indicates that darkroom paper looks
less crunchy (sorry Bruce) not because edges are less defined or sharp, but that light
scatters within the top layers of the materials and acts almost like a very very slight fog
filter. Edges remain extremely sharp, but have less contrast. A drum scan of same looks
very harsh by comparison, viewing up too close.
So this concept of softening harsh scans with any sort of blurring may be flawed,
assuming traditional materials are the desired look. Problematic assumption.
Tyler
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "E Neilsen" <e.neilsen2@...>
> 'round?
> Eric
> Eric Neilsen Photo
> Dallas, TX 75226
> 214 827-8301
> SKype ejprinter
>   _____
> Boley
> Negatives
> Tyler aka "crunchy"
> > but I never use it.
> > Thanks.
> > John
2008-09-23 by john castronovo
If this is a real fluid mounted drum scan, there should be no difference
at all in the cost for these resolutions, so there's no reason not to go
for the 300 ppi scan. As others have mentioned, the ultimate quality of
the scan has far more to do with many factors not related to resolution
and those things are what you should be shopping for. Buying scans by
resolution is like buying a car by horsepower or an audio system by
watts.
2008-09-23 by Berel Lutsky
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Roger"
> > potential data.
> for 35mm?
> large.
Whatever "school of thought" one belongs to it is never a good idea to
scan beyond the optical scan capabilities of what ever scanner you are
using - many of the maximum settings for flatbed scanners involve
interpolated information which can degrade the quality of your image -
whether you do use the maximum optical scanning capabilities of your
scanner - should depend more upon the intended final use for the image
- ie what size(s) of  output you are considering  - at this point it
is the quality of the optics of your scanner that will become
important - and there is a difference - especially in flatbed scanners
used for 4 x 5 negatives  - a consumer grade scanner that offers a lot
of dpi - with poor optics will yield a lot of pixels and overall poor
image quality -  for 4x5 on a good scanner 16 bit at 1200 dpi will be
more than enough resolution for a very very large print - 600 dpi will
probably be more than enough for a 16 x 20 in most cases.
2008-09-23 by Bill Morse
Hi Berel
While I agree with the first part of your post (don't exceed the
capabilities of your scanner), I don't believe that prints at 150 DPI (What
you get from a 4x5 scanned at 600 dpi, then printed to 16x20) will give you
"more than enough" resolution- more like just barely enough, if you are
lucky. Of course, YMMV.
Bill
Bill Morse
Wm. Morse Editions
2008-09-24 by Peter De Smidt
> using -
Except Sandy King, a very experience photographer and printer, does
exactly that.  On his Creo Eversmart he's found that if he scans at a
very high interpolated resolution that this scan is better once it's
resized back down to the optical resolution of his scanner than if he
scans directly at the optical resolution.  The key here is to not follow
dogma.  Try things for yourself and see what you get.
2008-09-24 by Bill Morse
Hi Peter-
Yes, there are always tricks or serendipities that improve a particular
image or even a particular piece of equipment or software 9in the eyes of a
particular observer). That doesn't mean it qualifies as good practice,
generally.
That said, "never say never" is always good advice (except when it isn't
Bill
> > using -
Bill Morse
Wm. Morse Editions
2008-09-24 by Ernst Dinkla
>> using -
Many scanner drivers will skip steps when a lower resolution
is selected. While the true optical resolution may not be
more than 2500 PPI you still need to use say 6400 SPI to get
that 2500 PPI. If you select 3200 SPI and the scanner skips
steps the optical resolution will drop further and some
other quality aspects are also affected. What in fact
happens with high SPI numbers is multi-sampling that can
also reduce noise and by that extend the dynamic range.
Selecting an odd resolution like 3350 could force the driver
to 6400 SPI and downsample that scan to 3350 PPI giving you
2500 PPI true optical resolution. A trick. And the result
depends much on the downsampling routine in the driver. So
selecting the highest SPI number of your scanner and
downsampling to the true optical resolutopn with a good
routine in other software isn't a bad idea. Anti-aliasing no
needed then I guess as it didn't resolve the detail at that
highest SPI setting anyway. Anti-aliasing would be needed
for downsampling below the true optical resolution.
|             ( unvollendet )            |
