Using roll paper for Epson 3800
2008-11-11 by SteveZ
I've been wanting to try Epson Somerset Velvet paper with my 3800. My plan is to purchase a 24" x 50' roll and cut the paper to 17" widths along the long end. This would decrease my paper costs vis-a-vis Epson Velvet Fine Art and allow me to utilize non textured paper fine art velvet paper. Has anyone here ever tried doing this?
2008-11-11 by cdtobie
On Nov 11, 2008, at 12:00:19 PM, SteveZ <blizzie12@...> wrote: I've been wanting to try Epson Somerset Velvet paper with my 3800. My plan is to purchase a 24" x 50' roll and cut the paper to 17" widths along the long end. This would decrease my paper costs vis-a-vis Epson Velvet Fine Art and allow me to utilize non textured paper fine art velvet paper. Has anyone here ever tried doing this? I've "sheeted" a lot of roll paper for use in any number of different printers. How easy and effective it is depends on what type of machine or manual device you use to do the measuring and cutting. It used to be much easier with the older Encad plotters; they had very simple controls for running the paper fast forward or back, micro forward or back, and then cutting when you reached the right spot. I'd attach a steel ruler and get easy measurements and precision cuts. I probably should have kept one simply for cutting purposes. Newer printers tend to want to be smarter than you are, and not let you do things easily and manually. -- C. David Tobie WW Product Technology Manager Digital Imaging & Home Theater Datacolor CDTobie@... www.datacolor.com/spyder3 [Non-text portions of this message have been removed]
2008-11-11 by edwweaver
Steve, I've been using the 16" wide rolls of Epson Premium Luster to create 37" pano's on my 3800. No problem. I just made a simple support to keep the material feeding smoothly. Ed Weaver --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "SteveZ" <blizzie12@...> wrote:
> > I've been wanting to try Epson Somerset Velvet paper with my 3800. My > plan is to purchase a 24" x 50' roll and cut the paper to 17" widths > along the long end. This would decrease my paper costs vis-a-vis Epson > Velvet Fine Art and allow me to utilize non textured paper fine art > velvet paper. Has anyone here ever tried doing this? >
Thanks, David. I was hoping to simply roll out the paper on a flat surface to a 17" length then VERY carefully, using a t-square or ruler, cut with an xacto knife. I would then feed the 17"x 24" sheet of paper into the rear tray (a la velvet fine art). Not sure how practical this is but in theory it sounds like it can be done. --- In DigitalBlackandWhiteThePrint@yahoogroups.com, cdtobie <CDTobie@...> wrote:
> > > On Nov 11, 2008, at 12:00:19 PM, SteveZ <blizzie12@...> wrote: > > I've been wanting to try Epson Somerset Velvet paper with my 3800. My > plan is to purchase a 24" x 50' roll and cut the paper to 17" widths > along the long end. This would decrease my paper costs vis-a-vis Epson > Velvet Fine Art and allow me to utilize non textured paper fine art > velvet paper. Has anyone here ever tried doing this? > I've "sheeted" a lot of roll paper for use in any number of different > printers. How easy and effective it is depends on what type of machine > or manual device you use to do the measuring and cutting. It used to > be much easier with the older Encad plotters; they had very simple > controls for running the paper fast forward or back, micro forward or > back, and then cutting when you reached the right spot. I'd attach a > steel ruler and get easy measurements and precision cuts. I probably > should have kept one simply for cutting purposes. Newer printers tend > to want to be smarter than you are, and not let you do things easily > and manually. > -- > C. David Tobie > WW Product Technology Manager > Digital Imaging & Home Theater > Datacolor > CDTobie@... > www.datacolor.com/spyder3 > > > [Non-text portions of this message have been removed] >
On Nov 11, 2008, at 4:53:46 PM, SteveZ <blizzie12@...> wrote: Thanks, David. I was hoping to simply roll out the paper on a flat surface to a 17" length then VERY carefully, using a t-square or ruler, cut with an xacto knife. I would then feed the 17"x 24" sheet of paper into the rear tray (a la velvet fine art). Not sure how practical this is but in theory it sounds like it can be done. That, plus some type of "deroller" would do the trick... if manually. -- C. David Tobie WW Product Technology Manager Digital Imaging & Home Theater Datacolor CDTobie@... www.datacolor.com/spyder3 [Non-text portions of this message have been removed]
2008-11-12 by steveabrink
If you can live with VFA in 17x22 in. sheets, you can get 25 sheets through Provantage for $90. SteveB --- In DigitalBlackandWhiteThePrint@yahoogroups.com, cdtobie <CDTobie@...> wrote: > > > On Nov 11, 2008, at 4:53:46 PM, SteveZ <blizzie12@...> wrote: > > Thanks, David. I was hoping to simply roll out the paper on a flat > surface to a 17" length then VERY carefully, using a t-square or > ruler, cut with an xacto knife. I would then feed the 17"x 24" sheet > of paper into the rear tray (a la velvet fine art). Not sure how > practical this is but in theory it sounds like it can be done. > That, plus some type of "deroller" would do the trick... if manually.
