RGB vs. Monochrome
2008-11-12 by Stephen Kobrin
Every once in a while, I forget to change the mode to monochrome after I convert to B&W in PS3. After layers are added, it is impossible to convert from RGB without flattening the file. Question: does it make a difference whether you work on a B&W file in RGB or monochrome? 99 times out of 100 I catch the problem before I print and send a monochrome file to my 2400 in ABW mode. Thanks, Steve
