jim kitchen schreef:
> On 4/1/09 3:00 AM, "Ernst Dinkla" <edinkla@...> wrote:
> Is there any theoretical difference possible in calibration quality...
> Dear Ernst,
> Now that I understand your question, I do not know how you do it, but you
> must have a wee bit more patience than I, or better eyes that I, to tweak a
> monitor manually with the tools nearby, compared to a software package that
> will do this exercise for you...
> The software I happen to own continuously iterates through each calibration
> step, before moving to the next calibration step, setting the monitor's
> white point, luminance, gamma, and black point targets until the software's
> tight differential limits are reached and, or the monitor cannot physically
> reach the required software limit resulting from the monitor's limited
> ability or age.
> I surely know that I could not do that manually, with any degree of accuracy
> at all, nor would I ever believe that my eyes would allow me to see the
> incremental differences, and accept the differential settings, because I
> believe my eyes would adjust to the screen conditions, and room lighting
> conditions; accordingly, during the calibration process.
> I also know that if I tried to calibrate the monitor manually, while
> comparing the calibration result to the finished print, I would probably be
> calibrating the monitor up to, and including the monitor's warranty end
> date, during my first attempt... :)
> I admire your tenacity...
> jim k
Jim,
Because you admire my tenacity I will now try to explain to you what
today's "manual" monitor calibration does.
There's a puck on your monitor that measures, there's software that
shows a bar with the desired value in the middle for every step:
contrast, Kelvin number and brightness. Values that you select before
the monitor calibration begins. If the selected value is reached, the
software gives the positive signal, a green icon.
Of course adding a bell sound may be a good idea for people with bad
eyes :-)
End of one line of sarcasm
You move on to the next step and shift the RGB values to
get the desired K value (Like David wrote after selecting a Kelvin
default of the monitor that comes close), here you
just check 6500K and the shifting number that becomes 6500K after some
tweaking, then Brightness and its green icon. You walk back to the first
as the last settings shift the firsts a bit and adjust them a little so
all three get the positive signal. Tenacity and eye strain are not the
terms I think off when the monitor is calibrated.
What you may have in mind is software like Prove It! that used the grey
field next to the black and white line grid, etc etc. You still could
verify part of the values with the puck but it certainly asked for at
least half an hour dedicated attention. Written by Joseph Holmes and
quite sophisticated for its time. He knew very well what was required
for calibration and profiling but the equipment wasn't like it is now. I
used that till three years ago together with a Spectrocam + the software
of the Spectrocam that gave me the absolute numbers for for example
viewing light correlation.
This is all about calibration, setting the monitor to a selected standard
For the monitor profile creation we all use a puck and it does the job
automagically. That isn't the part we are discussing here.
There are members on this list that can afford a NEC, Eizo, Samsung XL,
LaCie model.
There are members on this list who for very good reasons (budget) buy
monitors that are cheaper and try to find calibration/profiling
solutions that deliver equal or at least adequate quality for Photoshop
editing. And that is possible within 1 Delta E as can be seen on the
web pages I mentioned before.
To simply declare DDC's automatic interfacing of the monitor's hardware
and calibration puck as the only reliable method isn't in the interest
of many on this list. Your information on the "manual" methods like
given above isn't a service to them either.
I understand David's interests but I have not seen a flaw in the
information he gave on this subject.
BTW, I'm not using David's products. Not for printer profiling either.
Met vriendelijke groeten, Ernst
New: Dinkla Canvas Wrap Actions
| Dinkla Grafische Techniek |
| www.pigment-print.com |
| ( unvollendet ) |
