Advise Needed: Does Upgrade From C88+ to Stylus 1400 Make Sense?
2009-04-04 by dpbreger
I currently print with a Stylus C88+ using the MIS EZN inkset. I find it easy to use and affordable if I refill the cartridges. Generally print on Photo Rag. I'm not unhappy with the prints - except for large, uniform areas - but wonder if print quality would improve if I switched to the 1400, perhaps using the UT-14 or some other inkset. There is little discussion these days on this forum about the C88+ and imagine most users have moved on to something else (better?). Any suggestions or shared experiences would be apprecitated. Thanks. Paul
2009-04-05 by pr_roark
"dpbreger" <dpbreger@...> wrote: > I currently print with a Stylus C88+ using the MIS EZN inkset. > I find it easy to use and affordable if I refill the cartridges. > Generally print on Photo Rag. > > I'm not unhappy with the prints - except for large, uniform areas > - but wonder if print quality would improve if I switched to the > 1400, perhaps using the UT-14 or some other inkset. Yes, it would. The 1400's very small drop size makes a difference. It also is a hextone printer that is supported by a number of inksets and workflows, and the larger size of print is also nice. Nothing is going to be as easy as the C88+ with the "EZ" inkset, but it's simplicity also limits its quality and flexibility. > There is little discussion these days on this forum about the > C88+ and imagine most users have moved on to something else > (better?). "Better" is all relative to the intended uses. For my daughter at college, the ability to set up a C88+ with a cheap CIS and the EZ version of Carbon-6 -- and have it go all year with no refills or maintenance needed -- makes it the best as well as cheapest printer there is for that use. But for me, the 1400 is much better. Paul www.PaulRoark.com
2009-04-05 by dpbreger
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "pr_roark" <pr_roark@...> wrote: > > "dpbreger" <dpbreger@> wrote: > > > I currently print with a Stylus C88+ using the MIS EZN inkset. > > I find it easy to use and affordable if I refill the cartridges. > > Generally print on Photo Rag. > > > > I'm not unhappy with the prints - except for large, uniform areas > > - but wonder if print quality would improve if I switched to the > > 1400, perhaps using the UT-14 or some other inkset. > > Yes, it would. The 1400's very small drop size makes a difference. It also is a hextone printer that is supported by a number of inksets and workflows, and the larger size of print is also nice. Nothing is going to be as easy as the C88+ with the "EZ" inkset, but it's simplicity also limits its quality and flexibility. > > > There is little discussion these days on this forum about the > > C88+ and imagine most users have moved on to something else > > (better?). > > "Better" is all relative to the intended uses. For my daughter at college, the ability to set up a C88+ with a cheap CIS and the EZ version of Carbon-6 -- and have it go all year with no refills or maintenance needed -- makes it the best as well as cheapest printer there is for that use. But for me, the 1400 is much better. > > Paul > www.PaulRoark.com > Thanks Paul. I guess I'll need to research the different inkset possibilities. Any suggestions here? Would I go wrong using the UT14 rather than an Eboni-6 workflow? I understand the differences in their compositions but have no idea as to the appearances of the final prints. Paul B.
"dpbreger" <dpbreger@...> wrote: > >...I'll need to research the different inkset possibilities... > Would I go wrong using the UT14 rather than an Eboni-6 workflow? Keeping in mind that one can change inksets, I think it might make sense to start with UT14 (http://www.paulroark.com/BW-Info/UT14.pdf)because of its flexibility. You can print on either matte or glossy papers without changing inks and with a variety of tones. So, you'll be able to see what your preferences are. I'm currently using what I call my NC2 inkset (http://www.paulroark.com/BW-Info/UT14.pdf), but it's not something that MIS sells as a single inkset and requires QTR -- which I recommend all enthusiasts learn how to use -- including how to linearize -- at some point. I've also used Eboni-6 (http://www.paulroark.com/BW-Info/Eboni-6.pdf) in the 1400. Being a monotone, 100% carbon mix, it's very easy to use and very lightfast, but it's limited in tone and paper choices. The Carbon-6 version of it is about the same, less expensive, but you have to mix it yourself. Paul www.PaulRoark.com
