black and white profiles doesn't show up in Lightroom
2009-04-21 by Jacob
2009-04-21 by Jacob
I had successfully used black and white profiles created with QTR-Create-ICC.exe printing from Photoshop CS4 on Vista 64 PC. Now I'm trying to do same same from Lightroom 2.3 64 but when I open list of profiles and check "show monitor profiles" I don't see my bw profiles. Color profiles created with eye-one match3 are visible. Any ideas what's wrong? Thanks, Jacob
2009-04-21 by Myron Gochnauer
> >>I had successfully used black and white profiles created with QTR- > Create-ICC.exe printing from Photoshop CS4 on Vista 64 PC. > > Now I'm trying to do same same from Lightroom 2.3 64 but when I open > list of profiles and check "show monitor profiles" I don't see my bw > profiles. Lightroom 2: Print / Print Job / Color Management / Other / ... check the ones you want to appear. Is that what you're doing? It works for me when I add profiles, although I am working on a Mac. Myron [Non-text portions of this message have been removed]
2009-04-21 by evanmc
Jacob, I have exactly the same problem, and have not yet found a solution. Every other ICC I install works just fine, but not the black and white ones. (Lightroom 2.3 and Vista 64, same as you) I've had this problem since lightroom 2.0, so it doesn't seem to be a 2.3 bug. -Evan- --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Jacob" <flashinet@...> wrote:
> > I had successfully used black and white profiles created with QTR-Create-ICC.exe printing from Photoshop CS4 on Vista 64 PC. > > Now I'm trying to do same same from Lightroom 2.3 64 but when I open list of profiles and check "show monitor profiles" I don't see my bw profiles. > > Color profiles created with eye-one match3 are visible. > > Any ideas what's wrong? > > Thanks, Jacob >
2009-04-21 by George Pappas
The problem could be due to the fact that Lightroom does not have a B&W colorspace even when you do B&W conversion. Everything stays in the specified RGB colorspace. I don't know how it would map to a B&W output profile.. Regards, George
From: DigitalBlackandWhiteThePrint@yahoogroups.com [mailto:DigitalBlackandWhiteThePrint@yahoogroups.com] On Behalf Of evanmc Sent: Tuesday, April 21, 2009 11:34 AM To: DigitalBlackandWhiteThePrint@yahoogroups.com Subject: [Digital BW] Re: black and white profiles doesn't show up in Lightroom Jacob, I have exactly the same problem, and have not yet found a solution. Every other ICC I install works just fine, but not the black and white ones. (Lightroom 2.3 and Vista 64, same as you) I've had this problem since lightroom 2.0, so it doesn't seem to be a 2.3 bug. -Evan- --- In DigitalBlackandWhiteThePrint@yahoogroups.com <mailto:DigitalBlackandWhiteThePrint%40yahoogroups.com> , "Jacob" <flashinet@...> wrote: > > I had successfully used black and white profiles created with QTR-Create-ICC.exe printing from Photoshop CS4 on Vista 64 PC. > > Now I'm trying to do same same from Lightroom 2.3 64 but when I open list of profiles and check "show monitor profiles" I don't see my bw profiles. > > Color profiles created with eye-one match3 are visible. > > Any ideas what's wrong? > > Thanks, Jacob > [Non-text portions of this message have been removed]
2009-04-21 by Tyler Boley
pretty sure that's the deal. If you still have your measurement text files, frop them on "QTR-Create-ICC-RGB" instead and see if Lightroom sees the resulting rgb profiles. Tyler http://www.custom-digital.com/ --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "George Pappas" <george@...> wrote:
> > The problem could be due to the fact that Lightroom does not have a B&W > colorspace even when you do B&W conversion. Everything stays in the > specified RGB colorspace. I don't know how it would map to a B&W output > profile.. > > > > Regards, > > George > > > > From: DigitalBlackandWhiteThePrint@yahoogroups.com > [mailto:DigitalBlackandWhiteThePrint@yahoogroups.com] On Behalf Of evanmc > Sent: Tuesday, April 21, 2009 11:34 AM > To: DigitalBlackandWhiteThePrint@yahoogroups.com > Subject: [Digital BW] Re: black and white profiles doesn't show up in > Lightroom > > > > > > > > > Jacob, > > I have exactly the same problem, and have not yet found a solution. Every > other ICC I install works just fine, but not the black and white ones. > (Lightroom 2.3 and Vista 64, same as you) > > I've had this problem since lightroom 2.0, so it doesn't seem to be a 2.3 > bug. > > -Evan- > > --- In DigitalBlackandWhiteThePrint@yahoogroups.com > <mailto:DigitalBlackandWhiteThePrint%40yahoogroups.com> , "Jacob" > <flashinet@> wrote: > > > > I had successfully used black and white profiles created with > QTR-Create-ICC.exe printing from Photoshop CS4 on Vista 64 PC. > > > > Now I'm trying to do same same from Lightroom 2.3 64 but when I open list > of profiles and check "show monitor profiles" I don't see my bw profiles. > > > > Color profiles created with eye-one match3 are visible. > > > > Any ideas what's wrong? > > > > Thanks, Jacob > > > > > > > > [Non-text portions of this message have been removed] >
2009-04-22 by Jacob
Yes, it worked. Does it mean that "QTR-Create-ICC.exe" automatically converts image from RGB to grayscale mode? Does anybody try to create profile for ABW with profilemaker? Did it work for Lightroom? --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Tyler Boley" <tyler@...> wrote:
> > pretty sure that's the deal. If you still have your measurement text files, frop them on "QTR-Create-ICC-RGB" instead and see if Lightroom sees the resulting rgb profiles. > Tyler > http://www.custom-digital.com/ >
2009-04-22 by Tyler Boley
profilemaker will make profiles that Lightroom can utilize, since it makes RGB profiles. QTR Create ICC tools are the sole single channel luminance correction only profile making tools out there. Your profilemaker profile may also do some decent luminance correction, but it will be primarily mapping one rgb color space to another, much of that work unnecessary to the task at hand since ABW will turn it to sigle channel anyway. In fact, I've seen mixed info on various version's of Adobe, Epson, and OS, that may limit the ability to even select an rgb profile on the way out to the ABW driver ... Regarding the conversion question, selection of any single channel profile in the conversion chain converts the file from rgb to grayscale, no matter what the driver selections down the line are. So yes, a normal non-rgb created qtr profile conversion changes the file to grayscale. The QTR rgb tools create an actual rgb profile however, not single channel grayscale, but no color remapping is done to best match one color sapce to another in this instance, it simply creates an rgb profile with 3 equal channels, with the desired luminance correction and preview, for workflows that require an rgb data path, and think Qimage is like this as well? Hope that helps. Tyler http://www.custom-digital.com --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Jacob" <flashinet@...> wrote:
> > Yes, it worked. > Does it mean that "QTR-Create-ICC.exe" automatically converts image from RGB to grayscale mode? > Does anybody try to create profile for ABW with profilemaker? Did it work for Lightroom? > > > > --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Tyler Boley" <tyler@> wrote: > > > > pretty sure that's the deal. If you still have your measurement text files, frop them on "QTR-Create-ICC-RGB" instead and see if Lightroom sees the resulting rgb profiles. > > Tyler > > http://www.custom-digital.com/ > > >
2009-04-22 by Ernst Dinkla
Jacob schreef: > Yes, it worked. > Does it mean that "QTR-Create-ICC.exe" automatically converts image from RGB to grayscale mode? > Does anybody try to create profile for ABW with profilemaker? Did it work for Lightroom? As I understand it: No, but it will convert both greyscale and neutral R=G=B to a changed tonal curve neutral R=G=B image and depending on the printer driver used the driver will accept the R=G=B data as it is (ABW mode) or convert it on the fly to greyscale (QTR driver) and in both cases make a B&W print. With the greyscale ICC profile in for example Photoshop the same happens for both types but the outcome is then a changed tonal curve greyscale image that will be converted to R=G=B data or not in the last step, again depending on what the printer driver likes to have. -- Met vriendelijke groeten, Ernst New: Dinkla Canvas Wrap Actions | Dinkla Grafische Techniek | | www.pigment-print.com | | ( unvollendet ) |
Tyler Boley schreef: > with the desired luminance correction and preview, for workflows that require an rgb data path, and think Qimage is like this as well? Correct Qimage only knows an RGB path. But it will convert greyscale data to neutral R=G=B on the fly like QTR does the opposite on the fly. That is what probably all the drivers do that do not know more paths like some RIPs have. With QTR ICC profiles the greyscale or the RGB version I prefer to do the conversion in Photoshop instead of Qimage, Roy once discussed it with Mike Chaney of Qimage and the man Marty?of LCMS that Qimage uses for its color management, so the RGB type profile should work but I have seen shifts that were not normal. Printing from Picture Window Pro with QTR profiles was even worse. I'm not familiar with Lightroom but I would advise to test it thoroughly too by comparing targets printed through PS and LR. As I understand it Lightroom has Prophoto as its basic color space, a 1.8 Gamma type. Whether everything goes through an extra conversion as a result of that is something I'm curious about. If so16 bit may be a better choice than 8 bit. There were some rudimentary CM controls on the printing output in early versions like BPC missing or automatically applied. I have no complaints about Qimage's CM of color but with less often used B&W CM workflows there just isn't enough discussion to get it on the rails, might be the same for Lightroom. -- Met vriendelijke groeten, Ernst New: Dinkla Canvas Wrap Actions | Dinkla Grafische Techniek | | www.pigment-print.com | | ( unvollendet ) |
2009-04-23 by john dean
Why is one printing out of Lightroom in the first place, as apposed to the Q-Image interface? john
2009-04-23 by Tyler Boley
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "john dean" <deanwork2003@...> wrote: > > Why is one printing out of Lightroom in the first place, as apposed to the Q-Image interface? > > john > becoming the norm, problematic in some ways, but many are simply getting on board... Tyler
