hate to post again but I need help
2009-06-15 by Frank Jay
This question has been out for two days, and because I am antsy to get an answer I am posting again, usually I have a lot of patience as I Know this is all volunteer help,   I really need to print color by the end of the week and either will fix this problem or pay someone to print for me.
excuse this and thanks in advance for any help I can get.
from K3 back to color equals dark prints
Posted by: "Frank Jay" frankjay02@...   frankjay02
Sat Jun 13, 2009 5:49 pm (PDT)
Hello,
I have not printed in several months. Today  I switched out my K3 inks in my R1800, which I was told I could do when I bought the K3 inks and after running about a dozen prints thru the printer, it still prints dark and off color. I would think it was my monitor but my R1400 prints on the money. I calibrate about every six weeks. I printed some prints while upping the brightness factor in +30  increments in PS3, but the colors were still off and dark.  I have run three cleanings/nozzle checks.
   Is there anything I can do to remedy this, or am I stuck.
   Also. Am I allowed to sell items here. I have about a hundred and fifty dollars worth of inks, cartridges and chips for the R1800, which I would sell at a deep discount.
thanks a lot for any help offered.
Frank
Re: hate to post again but I need help
2009-06-16 by shileshjani
Frank,
I am not sure I understand what you have done. R1800 is not a K3 printer. If you have been using 3rd party inks, one option is to install the Epson original inks, and if you get good nozzle checks, print with a well known paper for which you have a good profile. Using Epson paper will help diagnose your problem.
Can you share which inks you are switching to and from?
Shilesh
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, Frank Jay <frankjay02@...> wrote:
> Hello,
> Frank
RE: [Digital BW] hate to post again but I need help
2009-06-16 by Mike Kirwan
The only thing I can think of is the K3 inks have not fully flushed out of
the system. Cannot remember what positions the K3 inks occupy, but you might
want to run a number of prints that large patched of the ink colors that may
be contaminated. Also if my memory serves me correctly there are some
"flushing" images that you can download.
I has a problem with yellow and magenta inks on my R1800 and used Corel Draw
to make an image that had large yellow and magenta bars, printed about 8
times and the problem was gone.
My guess is running a nozzle & cleaning check a few times is not enough to
clear the contaminated lines
Hope this helps
Mike
  _____
[mailto:DigitalBlackandWhiteThePrint@yahoogroups.com] On Behalf Of Frank Jay
Sent: Monday, June 15, 2009 4:49 PM
Subject: [Digital BW] hate to post again but I need help
Posted by: "Frank Jay" frankjay02@yahoo. <mailto:frankjay02%40yahoo.com> com
frankjay02
Hello,
Frank
2009-06-16 by Clayton Jones
Hello Frank,
This forum is known for having lots of people willing to help others (after all, that's the purpose of it), so the most likely reason you have not received a reply is that nobody had an answer for your question (and forum members usually refrain from clogging up the board with messages that say "Sorry I don't Know").  I'm offering this reply now just so you won't think you're being ignored.  Sorry I can't be of any help, I have no experience with the problem you described.
Clayton
I-Trak 2.1   http://www.cjcom.net/itrak.htm
2009-06-16 by Roger
You can use QTR to do a "calibration" print and see what all the ink channels are doing (i.e. does the gloss channel look dirty, etc?)
If you have a Spyder3Print I can share some measurements with you for what the patches should look like.
You can also use QTR to print from just one channel- print a bunch of papers to get rid of any leftover ink.
Out of curiosity, how did you get K3 inks to work in a R1800?
Roger
In DigitalBlackandWhiteThePrint@yahoogroups.com, "Clayton Jones" <cj@...> wrote:
> Hello Frank,
> Regards,
> Clayton
2009-06-17 by Gary Gervin
Frank,
I think Shilesh is on to something.  I have an R2400, got one of the first to come out.  But I almost went with the R1800.  I recall some reviews at Photo-i being very helpful.  The thing is, the ink formulations in the R1800 aren't the same as in the R2400.  I believe I recall discussions about the color gamut being different, and color patches on the Photo-i reviews clearly showing minor but significant differences between them.  In fact, I think the OEM R1800 carts use different colors than the R2400 altogether.  Do I correctly remember blue and red carts rather than cyan and magenta?  Perhaps you or someone else who has an R1800 can correct me on that.  If I do remember correctly about color gamut and different color carts altogether, there's no way that K3 inks will work simply and straightforwardly in an R1800.
The real issue is probably not that the inks will harm the R1800.  The real problem is that the OEM Epson R1800 printer driver is going to be set up to expect different colors in different locations than you presently have with K3 inks in the printer.  Since the R1800 had only one black and the K3 ink by definition has 3, I'd guess darker prints would be expected.  You have to remember the colors the R1800 print come from mixing colors, and if you add extra shades of black into positions that expect something else, the resultant color would be both "off" and darker than expected.  It sounds like that's what you are experiencing.
If you are really committed to using K3 inks in the R1800, I suspect QuadTone Rip is the only way to go.  QTR will completely replace the Epson printer driver and allow you to use whatever ink combos you want (as long as they don't hurt your printer).  But...  that means making your own profiles for paper and ink combinations, since I'd suspect few others are doing what you're trying to do, so you probably can't borrow others' work to get where you're going.
I'm going to go out on a limb.  I'd guess that since you are posting to this group, and are using K3 inks in an R1800, you are trying to get better B&W prints out of your printer than it will do natively.  I strongly suspect that if you keep at it, you may get decent results with QTR and the K3's if you work hard enough.  But maybe not perfect.  The K3's rely on some color, mostly photo magenta and photo cyan, being mixed in with the black inks to make a neutral black.  I have tried black-only printing with the K3's in the R2400, and I can assure you that Epson's OEM black has a decidedly green cast to it.  Without the extra colors mixed in their proper proportion, you won't get neutral black and greys.
Instead of going to all that work for maybe inferior results, perhaps you should look at either Jon Cone's inks or the any of the ink Paul Roark has helped develop.  It would be way easier, and you'd get better results.  Although I have an R2400 that the K3's work fine in  (and I have learned to print well using them), I am finding I like Jon Cone's SE inks better still.  I have no reason to think I'd dislike Roark's formulations.  Think about it before working too hard on making the K3's work in an R1800.
That's my 4 cents worth.
Gary Gervin
> This question has been out for two days, and because I am antsy to get an answer I am posting again,�usually I have a lot�of patience as I Know�this is all volunteer help, � I really need to print color by the end of the week and either will fix this problem or pay someone to print for me.
> Posted by: "Frank Jay" frankjay02@... � frankjay02
> Sat Jun�13,�2009 5:49�pm (PDT)
> Hello,
> I have not printed in several months. Today �I switched out my K3 inks in my R1800, which I was told I could do when I bought the K3 inks and after running about a dozen prints thru the printer, it still prints dark and off color. I would think it was my monitor but my R1400 prints on the money. I calibrate about every six weeks. I printed some prints while upping the brightness factor in +30� increments in PS3, but the colors were still off and dark.� I have run three cleanings/nozzle checks.
> �� Is there anything I can do to remedy this, or am I stuck.
> �� Also. Am I allowed to sell items here. I have about a hundred and fifty dollars worth of inks, cartridges and chips for the R1800, which I would sell at a deep discount.
> Frank
2009-06-17 by Frank K
Hello folks, thanks for the help
  I called the inks K3 beccuase being I used 3 black inks purchased from MIS in the R1800 in the photo black, matte black and GLOP slots I figured that was what they were called..
   I have done the following before posting here:
1. printed a dozen color 8x10's
2. run three nozzle checks/head cleaning
3. used Epson papers luster, gloss and matte on all prints
4. Unchedck gloss to see if the problem was in the GLOP...no change
5. Checked gloos to double check and no change from no GLOP
6. Used matte paper.
7. Used regular artiss water color paper.
I am not sure how to print one channell in QTR...I thought QTR was for BO printing
I WILL try the following
1. Print large swatches of primary colors to see what one is the darkest
2. Will look for flushing cartridges
  Any additonal help will be appreciated. I am stuck.
thanks
Frank
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Roger" <rsmith02@...> wrote:
> Roger
2009-06-18 by rgrbrrtt
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Frank K" <frankjay02@...> wrote:
> thanks
> Frank
Frank,
As I understand it, you are trying to print colour having changed the inks in your R1800. You have listed lots of things you have done but you have not said what printer profiles you are using. If you have changed the inks then you will almost certainly need a custom profile - don't be surprised if the generic Epson profiles give "off" colours.
Roger
