MIS clear base
2009-09-14 by baecht1
Paul or anyone else, Have you used the MIS clear base for mixing your own grayscale set. Is it any good Dennis
2009-09-14 by pr_roark
"baecht1" <dbaecht@...> wrote: > > Paul or anyone else, Have you used the MIS clear base for > mixing your own grayscale set. Is it any good The MIS glop is close to if not identical to the base used for the UT B&W inks -- glossy compatible with the binder included in the base. MIS glop is a fine base for that purpose. The base I use for the Eboni-6 inkset is not, as far as I know, sold separately by MIS. The open source C6 base I've come up with is the best alternative to it. (See http://www.paulroark.com/BW-Info/Ink-Mixing.pdf) The base MIS has in the past sold as the UC or clear base has never been used by me for a B&W inkset. I've tested it on both glossy and matte paper for the various inksets I've made, and I've found its performance quite weak. Diluted it makes a good flushing fluid, but I do not recommend it for mixing inks. Hope this helps. Paul www.PaulRoark.com
Works for me, all I have to get is the Edwal wetting agent. I'm going to see how this 2200 does, if it doesn't make me happy I'm going to get a 1800 or 1400 and go from there. Dennis --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "pr_roark" <pr_roark@...> wrote:
> > "baecht1" <dbaecht@> wrote: > > > > Paul or anyone else, Have you used the MIS clear base for > > mixing your own grayscale set. Is it any good > > The MIS glop is close to if not identical to the base used for the UT B&W inks -- glossy compatible with the binder included in the base. MIS glop is a fine base for that purpose. > > The base I use for the Eboni-6 inkset is not, as far as I know, sold separately by MIS. The open source C6 base I've come up with is the best alternative to it. (See http://www.paulroark.com/BW-Info/Ink-Mixing.pdf) > > The base MIS has in the past sold as the UC or clear base has never been used by me for a B&W inkset. I've tested it on both glossy and matte paper for the various inksets I've made, and I've found its performance quite weak. Diluted it makes a good flushing fluid, but I do not recommend it for mixing inks. > > Hope this helps. > > Paul > www.PaulRoark.com >
