"baecht1" <dbaecht@...> wrote:
> When printing BO does the 2200 use the light black.
No, I don't think it does.
> Can I use Ebony diluted 50% to get close to the same thing.
LK is about 30% PK. If you want to use a dilute Eboni, try 18% Eboni. The density graphs are not totally parallel for Eboni 18% and LK. So, QTR profiles that are based on LK may need re-linearizing (at least) if 18% Eboni is used instead of LK.
The dilute Eboni will not, of course, be glossy compatible, and it will be slightly more neutral than LK.
