[mailto:DigitalBlackandWhiteThePrint@yahoogroups.com] On Behalf Of Terry
Sent: Friday, November 27, 2009 6:43 PM
Subject: [Digital BW] Re: Maximum Usable Black vs. Dmax - What's the Big
Deal?
--- In DigitalBlackandWhit
eThePrint@yahoogroups.com, "pr_roark" <paul.roark@...> wrote:
> "Terry" <TerryGls@> wrote:
> > Paul, if I understand, looking at the 100% QTR Ink Separation Page for
Epson Ultra Premium Luster printed with my R1800 at 2880, uni-directional my
"max visual PK black" is at the 60% ink limit.
> > So, are you suggesting I use 60% for my PK Ink Limit?...then for Black
Boost 65 or 70%?
> If the actual dmax is at 70 but the slope of the curve is very low between
60 and 70 -- that is, they are barely separated -- then I'd use 60 as the K
limit and put 70 in the black boost box. (Note that there may be other
factors like pizza wheel issues, but I'm not considering that at the
moment.)
Paul, You mention "actual Dmax" . I think I'm understanding part of your
point except in one area of "visual PK max black" or "actual Dmax." My 100%
Ink Sep Page print out for the PK ink shows actual densitometer readings as
follows: 60%-2.05, 65%-2.11, 70%-2.2, 75%-2.28, 80%-2.34, 85%-2.4, 90%-2.40,
95%-2.51, and 100%-2.53.
As mentioned before the 60% square visually looks as black as the 65%, 70%
all the way to 100%..
So, if I follow your point and set the PK Ink Limit to 60% and Black Boost
to 70%, my measured density will be 2.2 but not near the 2.53 Dmax black
possible "in theory."
> One thing I've noticed when I use the boost is that when the relative
densities are based on the lower K limit, here 60, the resulting
partitioning gives a more linear pre-linearization curve.
> In general, I also tend not to set the limits of the midtones all >the way
to their max density either.
>I use a loupe to see when the bleed starts to become an issue, and I >also
don't want there to be too much ink particularly on glossy >papers.
What do you mean by "bleed" and what are you looking for with the loupe?
Thanks, Terry
Frankly, my glossy printing is now black only with HP PK on a 1400. Drier
glossy printing results in fewer pizza wheel issues and reflective
artifacts, though the HP PK prints do still show some bronzing.
> > I've been linearizing using ChartThrob ...
> I've never used it. So, my comments relate only to QTR.
> Paul
> www.PaulRoark.com
