4000 Banding
2009-12-29 by shileshjani
I have not had any response to the following at the wide-format forum. Anyone here can help with my banding problem? Shilesh The bands are darker than surrounding tone, and are spaced approximately 2.5 mm apart. Anyone know how to solve this? --- In EpsonWideFormat@yahoogroups.com, "shileshjani" <shileshjani@...> wrote: > > My 4000 is now 4 years old, with fairly light use duty. It has been more-or-less reliable. A few months back I changed the inks over to a custom mix based on IS inks, with GLOP in the Y position. I use QTR to drive the printer, which has the latest firmware updates. > > It has recently developed banding visible in all individual channels. I can reduce banding (but not eliminate) by using 2880 setting in QTR. I have done a number of cleaning cycles, etc, to no avail. I can also reduce the banding somewhat by setting the custom paper thickness to "1", which makes it 100 microns. But the paper I use is EEF, which is thicker (300 micron). When I use paper thickness setting using the utility, the "1" setting shows the least gap, and it gets worse with higher numbers.
> > The paper feed utility has not been much use. > > Can anyone help? Thank you. > > Shilesh >
