Problem with Messy borders using QTR
2009-12-30 by nigglefish
I have an Epson TX650 loaded with MIS Eboni and UT14-PKN and dilutions of these made using Paul Roark's base (the one with Edwal LFN for 1.5pl printers). The TX650 is the current entry-level 6 Claria ink 1.5pl printer in Australia (it's a PX650 in the UK) similar in stats to the R260. I am printing on Photo Rag 188 and a very cheap matte inkjet paper for experiments.
The problem I have is that whenever I print using QTR and Printing Model R260-MIS (to which I have added some profiles) I get blobs and streaks of ink in the borders (which are about 1.5cm) around the image I am printing. They can take the form of 1mm ink strains along the top or bottom edges of the paper, as if part of the edge had been very lightly dipped in ink, horizontal streaks within the first 1cm of the top or bottom edge of the paper (these look like the head or some rollers have streaked ink from the previous stains), and sometimes little dense drops of ink on the right hand margin. The images themselves are always perfect with no marks on them, but there are always some messy ink blotches somewhere in the border.
Some of the ink will get on rollers and effect later sheets. Aside from this left over mess though I never seem to have a problem when I use the Epson driver to print images. I have tried adjusting the Ink Limit (Shadows) to -50 in QTR's Advanced Adjustments, rolling the paper around a paper roll and using a thinner paper, but I always have some messy ink in the borders when using QTR.
Is my ink too thin? Too thick? Are my refillable cartridges no good? Is my Ink Limit in my QTR curves (40 with a Black Boost of 50) too high for the printer? Am I using QTR incorrectly? Am I just missing something? Any help or ideas would be appreciated!
Cheers, Nigel.
Re: [Digital BW] Problem with Messy borders using QTR
2009-12-30 by Michael King
So I think what is happening is that the ends of the paper that are not held
by the rollers (like all the small printers) tend to bend up and touch the
head and yes your inks are maybe a bit thin and there is some ink sitting
under the head.
Try the following;
1) Bend the paper before you put it into the printer so the ends are are
bend away from the printing surface and or
2) Print an image that's at least 5cm (2.5inch) from front edge and back
edge.
Either or both of these should help.
Mike
2009/12/30 nigglefish <nigglefish@...>
> experiments.
> when using QTR.
> Cheers, Nigel.
BTW this paper curling problem (towards the coated side) occurs with nearly
all matte papers I've used.
Obviously something to do with the coating, which is why many good quality
matte papers are coated on both sides, the best equally coated on both sides
(like Epson Ultrasmooth) to reduce/stop curling, not to allow you to print
on both sides.
Don't know why the coating causes curling, maybe someone in the paper
business can explain.
Mike
2009/12/30 Michael King <drmrking@...>
> held by the rollers (like all the small printers) tend to bend up and touch
> the head and yes your inks are maybe a bit thin and there is some ink
> sitting under the head.
> Try the following;
> edge.
> Mike
>> experiments.
>> when using QTR.
>> Cheers, Nigel.
2010-01-03 by nigglefish
Thanks for all the advice Mike,
I finally found a process that works for me so I thought I would share it for anyone else who might have the same problems.
By rolling the page over the cardboard roll from the inside of some paper-towels I put a reverse bend into the paper. I am careful not to roll it too far as it can crease the paper halfway if you let it double up on the roll, but I do aim for quite a strong reverse roll.
This eliminates the ink at the start and end of the page but only seems to increase the amount of splotches down the left-hand side of the page which look like big ink drops about 5mm round and line up all down the side of the page. I finally managed to get rid of these by setting the Resolution to 1400x1400 and the Speed to Uni-directional in QTR. I guess it was the second setting that did it.
Anyway, I am now making great prints so thanks again Mike!
Nigel.
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, Michael King <drmrking@...> wrote:
> on both sides.
> Mike
> > Try the following;
> > edge.
> > Mike
> >> experiments.
> >> when using QTR.
> >> Cheers, Nigel.
Re: Problem with Messy borders using QTR
2010-01-03 by Silvio
Good day to all,
As a confirmed lurker, I hesitate to interrupt this board, but I will
ask your forgivness this time.
As I have had the same problem ( streaking and rorschach like ink blob
on a 4880 Epson ) and trying all kinds of solution, none of which I
will waste your time with explaning here as nothing worked.
So I gave in and called epson tech support. Short story shorter they
suggested setting my platen width to "wider" from the front panel of
my 4880.
Done and done!
Do reset it each time you turn the unit on as it will not retain the
"W" setting after a power down.
Silvio
Re: [Digital BW] Re: Problem with Messy borders using QTR
2010-01-03 by Mark Savoia
By setting the platen wider is only a bandaid. You must have dirt on your head surface. Having the platen set to wide just keeps the head farther from the paper so it has less of a chance of touching. So what are the solutions you tried that are not worth explaining? Did you physically wipe the head clean by hand?
I think you can also setup a custom paper with a wide gap and it will remain wide when you turn the printer off.
Mark
http://www.stillrivereditions.com
On Jan 3, 2010, at 1:14 PM, Silvio wrote:
> Good day to all,
> my 4880.
> Done and done!
> Sent from my iPhone
> Silvio
> - By posting on this forum you agree to abide by the group rules and guidelines, and to abide by the actions and decisions of the group Owner and Moderators. See „Group Topic, Rules and Guidelines‰ in the Files section:
> BY PARTICIPATING IN AND/OR POSTING MESSAGES TO THE DIGITAL BW, THE PRINT YAHOO! GROUP YOU EXPRESSLY UNDERSTAND AND AGREE THAT THE „OWNER‰ AND „MODERATORS‰ OF DIGITAL BW, THE PRINT YAHOO GROUP SHALL NOT BE LIABLE TO YOU FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, CONSEQUENTIAL OR EXEMPLARY DAMAGES, INCLUDING BUT NOT LIMITED TO, DAMAGES FOR LOSS OF PROFITS, GOODWILL, USE, DATA OR OTHER INTANGIBLE LOSSES (EVEN IF THE  „OWNER‰ AND „MODERATORS‰ OF DIGITAL BW, THE PRINT YAHOO GROUP HAVE BEEN ADVISED OF THE POSSIBILITY OF SUCH DAMAGES), RESULTING FROM: (i) THE USE OR THE INABILITY TO USE THE DIGITAL BW, THE PRINT YAHOO GROUP; (ii) UNAUTHORIZED ACCESS TO OR ALTERATION OF YOUR TRANSMISSIONS OR DATA; (iii) STATEMENTS OR CONDUCT OF ANY THIRD PARTY ON THE DIGITAL BW, THE PRINT YAHOO GROUP; OR (iv) ANY OTHER MATTER RELATING TO THE DIGITAL BW, THE PRINT YAHOO GROUP.
