Diagnose Epson 4000 Problem - Help
2010-02-12 by shileshjani
I have a Pro 4000 printer that is having a number of problems. But right now I need help with one specific issue:
When I print the paper thickess page from "cutom paper" setup, none of the series of 2 lines are anywhere near congruent. The smallest gap is at line #1, and even here it is about 2 mm apart. Any idea what is up with this?
Thank you.
Shilesh
Re: Diagnose Epson 4000 Problem - Help
2010-02-13 by Jarvis
> Thank you.
> Shilesh
When was the last time you updated the Firmware of the printer?
Jarvis
2010-02-14 by shileshjani
Hello Jarvis,
The firmware was updated a few months back. Do you think this is the problem, and is there a way of reverting to the older version?
Shilesh
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Jarvis" <jarvo@...> wrote:
> > Thank you.
> > Shilesh
> Jarvis
2010-02-14 by Jarvis
> Shilesh
This response is totally "Un-scientific", just my experience. A couple of years ago I did a firmware update and a driver update to my printer. At that point I had lost all of my paper preferences, including some of the Epson & my own ICC profiles. I kept the Firmware update, which is still Version 101564, but I went back to my previous installed driver which was Version 5.30. I also have the latest Paper Feed Utility, but all paper adjustments are made in the Epson driver with no problems. So my advice is to stay with the driver at works/worked best and update everything else.
With that said, I'm on an XP SP3 machine. Now the new driver I was going to install was to accommodate Vista, and the latest seems to be for Windows 7. I'm pretty sure the same is true on the Mac side where new drivers are to accommodate Snow Leopard. If you need the new driver because of an OS X upgrade, you should check out the Yahoo Epson 4000 forum,  http://tech.groups.yahoo.com/group/Epson4000/. Really good info & help there.
Jarvis
