Cone Color Inks for Epson 3800-K3 or Vivid
2010-03-12 by doggo@att.net
I have been printing a fairly large variety of papers on my 3800 for a couple of years and have never had a single problem that was not user induced. I have been seriously considering moving to the Cone inks and refillable cartridges. Cone also offers the Vivid ink in at attempt to provide that newer gamut from the inks of the 3880.
     The Cone website says that it is unknown whether the Vivid inks will work with the Epson drive and further that new profiles would be required, which could be created by the ColorMunki, also avalable at the Cone site.
     I'm pretty sure that I will buy the Cone color inks for the 3800, but I am greatly intrigued at the idea of the increased gamut if I buy the Vivid inks. Of course, buying the system and then immediately shelling out another $400-to whatever for profiling is a bit of a puzzler. In short, is going for the Vivid colors worth it?
     Does anybody have any experience or information about use of the Vivid inks (designed for the 3880) on a 3800? Any information would be greatly appreciated.
     Thanks In Advance
doggo
Re: [Digital BW] Cone Color Inks for Epson 3800-K3 or Vivid
2010-03-12 by Walker Blackwell
I've use the vivid CC inks in a 9600 no problem. There is no reason in
my mind why it wouldn't work in the 3800. You're paying 30% of the
cost of Epson inks. In the long run it's worth an extra 400 bucks on
profiling hardware.
Walker
> the Cone site.
> Thanks In Advance
> doggo
Walker Blackwell
802.821.4451
www.walkerblackwell.com
aim: greendirtblues
wblackwell@...
Re: Cone Color Inks for Epson 3800-K3 or Vivid
2010-03-13 by jhd622005
I read on the http://people.csail.mit.edu/ericchan/dp/Epson3800/index.html
webpage the 3800 cannot use the newer 3880 Epson inks.
I would call the Cone office to be sure. The 3880 has a new print head and uses a different algorithim.
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "doggo@..." <doggo@...> wrote:
>      Thanks In Advance
> doggo
2010-03-13 by rogerbarrett_hps
I don't know about using the Epson vivid inks in a 3800, but I am happily using the Conecolor vivid types with their refillable cartridges in my 3800.
I went for the vivid inks on the assumption that I was more likely to get a colour gamut that matched the standard K3 gamut. I know from doing hundreds of profiles for other people (my small business) that third party inks seldom give the same colour gamut as OEM inks. I was told by the people at Inkjet Mall that their vivid inks are OK in the 3800 so went ahead and did it.
In the event my initial assumption was confirmed. I have found that the colour gamut of the Conecolor vivid set is marginally smaller than I was achieving with the standard K3 set. This is after a bit of fiddling to optimise driver settings and with careful profiling.
The biggest difference that I found is in the Dmax with PK. I believe this is because the Epson PK has black dye added to the pigment, whereas the Conecolor is pure pigment. (I'm sure someone will put me right on this if I'm wrong.) With MK I find that Conecolor is a bit better than K3, again after optimising and profiling.
I should say that the prints I am producing with the Conecolor are visually very similar to the K3 prints, although a side-by-side comparison does show the slightly smaller gamut. The difference is not big enough to send me running back to Epson inks - except maybe the PK....
Roger
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "jhd622005" <jhd622005@...> wrote:
> --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "doggo@" <doggo@> wrote:
> >      Thanks In Advance
> > doggo
Re: [Digital BW] Re: Cone Color Inks for Epson 3800-K3 or Vivid
2010-03-13 by Walker Blackwell
You are right. Vivid will not work using ABW in the 3800. Nor will
Cone Color (K3 or Vivid K3) work with ABW. ABW is tuned very
specifically to epson ink formulations. That said, there is no reason
why CC Vivid ink won't actually make it through 3800 print heads. Cone
ink does a better job at not clogging (in my opinion) than epson ink.
If you want to do BW printing, use QuadtoneRIP. This is a more custom
higher quality driver than ABW anyway.
Walker
> at the Cone site.
> > Thanks In Advance
> > doggo
Walker Blackwell
802.821.4451
aim: greendirtblues
wblackwell@googlewave.com
2010-03-13 by piezobw
The 3800 can use the inks from the 3880 but not the carts.
ConeColor ink is encapsulated fine pigment with a very narrow band distribution of particle sizes that can easily pass through any of the Epson print heads, including those designed solely for dye inks.
The only issue is as Walker points out - color management. The ConeColor inks while designed to work with Epson ICC workflow, are not color compatible when moved from one color range printer family to another. The Epson RGB workflow is very specific. You can alter what the printer is using - but you need to employ ICC or some other workflow in order to make it work. Not so different that using monochromatic inks in a color printer...
We sell the Vivid inks into the 1400 by example. But, we provide more than 40 ICC profiles to make that possible. Without the ICCs - the customer gets weird color. With the ICCs, the 1400 become a little fine art printmaking system. WE provide the ICCs because at sub $200 printers, no one should be investing in $400 color management packages in order to print pigment.
We do have customers running K7 shades 4&5 to replace Epson Lk and LLK respectively. The density match for these is nearly exact. Some customers are using the Neutral shades 1,4,5 to help with their color management on fine art papers. All our shade 4&5 inks are gloss compatible - but the only sets which are fully gloss compatible are Selenium K7 and WarmNeutral K7 which are both triple-encapsulated pigments from shade 2-7. MPS Black is our triple encapsulated photo black. There is enough encapsulation of K7 1 to prevent it from clogging (that is what encapsulation does), but not enough to make it glossy compatible.
There is new very dense Piezography photo black which has greater dMax than MPS Black 1 - and has a very warm base undertone. But it's so warm that it can not replace Epson Photo Black without ICCs. I use this ink for my backlit process because it's fully opaque.
The short is that if we can remove the color inks from any Epson printer and run monochromatic ink sets - it falls in line that we can put any color scheme into a printer as well. The issues are not mechanical (unless low quality inks are used), but rather a color management issue pertaining to the OEM printer driver. There really is and never has been a limit to what one can imagine as a preferred ink set. The only limitations are imposed by the OEM in an effort to thwart the use of non-OEM inks.
Best regards,
Jon Cone
> >      Thanks In Advance
> > doggo
2010-03-13 by Mark Savoia
Jon, where is this new very dense black? Is it on your website someplace? What if compared to Piezotone blacks? dMax better, worst? Can it not be used by us because you stated it is opaque?
Mark
http://www.stillrivereditions.com
I would also note that for anyone using a rip (say colorburst) and not
using Epson's default screening (Epson's default screening will add
color ink overlay into the netrual to compensate for the brown/green K
ink that Epson sells) you can buy 4 selenium inks from Jon Cone to
replace your PK MK LK LLK. Then, when you build your custom CMYK
profile, the setup will use more pure K ink when printing neutrals in
color images. This cuts matamerism way down and generally gives you a
superior profile for printing neutral images with small areas of full
color (one of the hardest printing procedures, and something today's
profilers still can't handle very well with mixed Ks like Epson). The
3800/3880 (with it's 6 droplet sizes) are uniquelly up to this task.
Also, this method will give you a more stable (neutral) starting point
for building QuadtoneRIP profiles for your color inks.
This really only works best with the newest head tech starting on the
3800/4880/3880/9880
I tried this on the 9600 back in the day, but it was touch and go. I
think Epson developed the brown K ink originally because they were
limited in nozzles. The only way to get a line/dot-free BW print was
to mix brown/green K ink with other colors to up the amount of nozzles
needed to make a neutral print with "high enough" physical resolution.
I could get a semi-satisfactory neutral K print from the 9600 using
2880dpi and Smooth Diffusion dither form Studioprint. But this was
about it. They probably still do this to make it harder for others to
replicate their ink overlays, but that is just my cynicism bubbling up.
Walker
2010-03-13 by Terry Ritz
Very interesting.
Walker, could this approach be undertaken using ICC profiling tools, say a
Colormunki?
Terry.
> 3800/4880/3880/9880
> Walker
> page.
> them short.
> Hostile, aggressive or argumentative users may be removed from the membership
> without notice.
> printing. Users who persistently make off-topic posts may be removed from the
> membership.
> guidelines, and to abide by the actions and decisions of the group Owner and
> Moderators. See „Group Topic, Rules and Guidelines‰ in the Files section:
> YAHOO! GROUP YOU EXPRESSLY UNDERSTAND AND AGREE THAT THE „OWNER‰ AND
> „MODERATORS‰ OF DIGITAL BW, THE PRINT YAHOO GROUP SHALL NOT BE LIABLE TO YOU
> FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, CONSEQUENTIAL OR EXEMPLARY
> DAMAGES, INCLUDING BUT NOT LIMITED TO, DAMAGES FOR LOSS OF PROFITS, GOODWILL,
> USE, DATA OR OTHER INTANGIBLE LOSSES (EVEN IF THE  „OWNER‰ AND „MODERATORS‰ OF
> DIGITAL BW, THE PRINT YAHOO GROUP HAVE BEEN ADVISED OF THE POSSIBILITY OF SUCH
> DAMAGES), RESULTING FROM: (i) THE USE OR THE INABILITY TO USE THE DIGITAL BW,
> THE PRINT YAHOO GROUP; (ii) UNAUTHORIZED ACCESS TO OR ALTERATION OF YOUR
> TRANSMISSIONS OR DATA; (iii) STATEMENTS OR CONDUCT OF ANY THIRD PARTY ON THE
> DIGITAL BW, THE PRINT YAHOO GROUP; OR (iv) ANY OTHER MATTER RELATING TO THE
> DIGITAL BW, THE PRINT YAHOO GROUP.
Walter, how do you find gloss differential & bronzing? The 3800 colour
samples I received about a year ago seemed to have a lot of gloss
differential.
Terry.
> profiling hardware.
> Walker
Sorry, I re-read your post more carefully. A standard ICC profile for the
3800 will dither colour ink into K since it expects a brown/green Epson K.
Still, using Jon's Selenium for PK, MK, LK and LLK would make it an easier
job to create QTR profiles in a 17", dual purpose printer scenario.
Jon, would a gloss overcoat be required in this scenario?
Terry.
On 13/03/10 11:53 AM, "Terry Ritz" <t.ritz@...> wrote:
> Very interesting.
> Colormunki?
> Terry.
>> 3800/4880/3880/9880
>> Walker
I can also confirm what Roger states after profiling well over 80
papers with both CCK3 and CCvK3. While the CC K3 has slightly less
gamut than Epson k3 (and less dmax with PK) the vivid M (and C for
that matter) make up the difference. In general, fine art
photographers aren't printing at the edges of their gamut anyway.
Especially us BW folks.
Walker
> profiling.
> the PK....
> Roger
2010-03-14 by piezobw
I like to use the overcoat because it erases all gloss differential between the image and the paper - and that adds realism to the print for being a photograph as we once recalled. I don't like how ABW looks on a sheet. It sits on it. I prefer there be no difference between ink and paper if its going to be glossy. That's how a darkroom print looks and that's how I designed use of Peizography Gloss Optimizer - as a total sheet overcoat. The ABWs I saw on silver rag at SPE looked a bit inkjetty to me. Just an opinion.
But, if you're asking whether my shades 4&5 need GO to appear glossy. No they do not.
Jon
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, Terry Ritz <t.ritz@...> wrote:
> Terry.
> > Very interesting.
> > Colormunki?
> > Terry.
> >> 3800/4880/3880/9880
> >> Walker
Yes. Epson PK has dye. And yes it makes a great photo black as a result.  :)
Jon
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "rogerbarrett_hps" <roger@...> wrote:
> Roger
> --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "jhd622005" <jhd622005@> wrote:
> > >      Thanks In Advance
> > > doggo
It's in my own studio. It's not really a matte black formulation and I have not tried printing matte with it. I am really into glossy Piezography printing lately.
If you would like, I can send you 8oz to play around with.
Jon
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, Mark Savoia <mark@...> wrote:
> Mark
Yes, but no gain really.
I think Walker's suggestions in using Piezography inks with ConeColor inks is improving on things and the way to go, than the other way around.
Jon
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, Mark Sonners <mark@...> wrote:
> Jon,
> Can ConeColor PK be substituted for MPS gloss compatible shade 1? Or
> can ConeColor MK be substituted for K7 sepia shade 1?  Just thought
> I'd ask.
> Mark
> > Best regards,
> > Jon Cone
> > index.html
> > > --- In DigitalBlackandWhiteThePrint@...m, "doggo@"
> > 3880.
> > > > Thanks In Advance
> > > > doggo
Mark,
I just dug up my Suntest notes on the three inks: Epson Photo Black, Piezography MPS Photo Black, and my new Photo Black (still un-named).
After 100 Megalux
Epson PK  start:  7.5 -0.1 -1.3  end:   9.4 -0.1 -1.7
MPS PK    start: 12.6 -0.3 -2.4  end:  12.1 -0.6 -2.8
new PK    start:  8.9 -0.8 -3.5  end:   6.6 -0.7 -3.0
I believe (right now at least), that we are the only ink manufacturer encapsulating dye molecules. We need less dye than Epson PK. We use more pigment than Epson PK. It makes quite a difference.
Email me off list for which printer you wish to test it in.
Jon
> Mark
2010-03-14 by Mark Sonners
Jon,
I'd ask.
Mark
> Best regards,
> Jon Cone
> index.html
> 3880.
> > > Thanks In Advance
> > > doggo
