R1800-3MK & MIS cleaning fluid
2010-03-14 by bobtail75
Have any of you had excperience of using refillable carts filled with the MIS cleaning fluid instead of colour inks? I only use the 1800 for b/w printing.I love the 3MK set-up, especially now that Canson, Moab & Innova papers are available here.The Canson & Innova look very good. Also discovered that the Moab Entrada paper is available in 13" rolls, so next project is some big panoramas.
Chris.
UK/ Devon
Re: R1800-3MK & MIS cleaning fluid
2010-03-15 by Paul
Hello Christ,
I've had that exact setup for over two years and have been quite happy with it. I use the MIS carts with their cleaning fluid, in the color positions, and Eboni carbon in the MK, PK, and GLOP positions. I like the results, and it's simple and very economical. There've been some criticisms of the "grain" in the middle-gray tones but when I think of a similar size print in a film/silver print I don't worry about it.
Am using Premier Art Fine Art Hot Press 205 paper and have printed 5x7's, 8 1/2 x 11's, and 13 x 19's - only problem has been that occasionally a sheet of paper feeds right through without printing. But usually running through a sheet of water color paper sprayed with alcohol does the trick and/or cleaning the large rubber wheel at the far right of the paper entry.
Anything else I can help you with?
Oh, one more thing... I've submitted some test prints to Aardenburg Imaging & Resources for longevity testing, see my combination third one down: http://www.aardenburg-imaging.com/index.html I do a fair amount of historic building documentation and these prints are now acceptable as equal to or better than darkroom prints. But with Aardenburg's stamp of approval in a month or so (I hope!) I'll have more argument in my favor.
Regards.
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "bobtail75" <cperfect594@...> wrote:
> Chris.
> UK/ Devon
2010-03-15 by Paul
Oos.. make that "Hello Chris"! Didn't mean to deify you... sorry!
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Paul" <paulmwhiting@...> wrote:
> Hello Christ,
> Regards.
> Paul
> --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "bobtail75" <cperfect594@> wrote:
> > Chris.
> > UK/ Devon
2010-03-15 by bobtail75
Thank you, Paul.
I will try the cleaner cart setup. I am using refillable carts thatcome from www.marrutt.com, here in the UK, but have just bought a pint of MIS Eboni & another of the cleaner, so that should keep me going for the forseeable future.
I look forward to seeing the Aardenberg results.
I have had no feed problems with my 1800 on Art Papers if I use the rear single sheet feed slot.
regards,
Chris.
> Hello Christ,
> Regards.
> Paul
> > Chris.
> > UK/ Devon
2010-03-15 by Paul
You're welcome, Chris, and thanks for the link to marrutt.com... that's a new one for me, I'll have to explore it.
I've used the rear slot too, with some luck. Maybe I should try it again... but I can't do 5x7's there, the width adjustment slider doesn't go that small.
Best of luck,
> Thank you, Paul.
> regards,
> Chris.
> --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Paul" <paulmwhiting@> wrote:
> > Hello Christ,
> > Regards.
> > Paul
> > > Chris.
> > > UK/ Devon
2010-03-15 by bgrahamuk
Hi Chris,
Did you buy your MIS Eboni from within the UK or did you order directly from the States ?
It was the shipping costs that put me off so I opted for the Image Specialists pigment ink.
Best Regards,
Bill
> Thank you, Paul.
> regards,
> Chris.
> > Hello Christ,
> > Regards.
> > Paul
> > > Chris.
> > > UK/ Devon
2010-03-17 by bobtail75
Bill,
I originally bought a set of 3 MIS cartridges and paid the duty etc. I then got the refillables from Marrutt with some of their R8 MK ink which they supply for the 1800
I have now bought a 'pint' of the MIS Eboni & cleaner fluid. The initial outlay is ,I hope, cancelled out by the benefit of quantity.However the Marrutt /Lyson MK gives very good tones.
I have also just discovered that my 1800 has been 'eating' my black ink and dumping it in the waste tank !! I have installed an external waste tank, & it is horrifyibg to see just how much goes there, & & mainly black.
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "bgrahamuk" <enquiries@...> wrote:
> Hi Chris,
> Best Regards,
> Bill
> > Thank you, Paul.
> > regards,
> > Chris.
> > > Hello Christ,
> > > Regards.
> > > Paul
> > > > Chris.
> > > > UK/ Devon
