Beginners questions
Beginners questions
2010-03-16 by Lew Schwartz
Is there any hope? I'm a bw film photographer who needs to learn to scan
properly & then move into Photoshop & start printing. Every book I find is
about color or converting digital to bw with a zillion things I don't
believe I have to know. So are there on line or print resources that can
lead me sanely from my negs (which I'm not about to give up) to a decent
digital print?
Re: [Digital BW] Beginners questions
2010-03-16 by Dave
On Mar 15, 2010, at 9:43 PM, Lew Schwartz wrote:
> Is there any hope?
Sure. Get a copy of this book - it'll get you started:
Mastering Digital Black & White: A Photographer's Guide to High
Quality Black-and-White Imaging and Printing (Digital Process and
Print) by Amadou Diallo
http://www.amazon.com/Mastering-Digital-Black-Black-White/dp/1598633759/ref=sr_1_1?ie=UTF8&s=books&qid=1268714427&sr=8-1
All best,
Dave
http://davereichertphoto.com/
2010-03-16 by Dave
> > Is there any hope?
An added note - there's not much at all about scanning, but the book's
a good overview of the process after the scan is made.
Good luck!
Re: Beginners questions
2010-03-16 by asp.artist
Also, Hybridphoto.com
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, Dave <cowcreekroad@...> wrote:
> > > Is there any hope?
> Good luck!
2010-03-16 by pr_roark
Lew Schwartz <lew1716@...> wrote:
> ... to scan properly
What film sizes do you use?
For me, probably the best single investment I made in digital was the Nikon 8000 medium format film scanner.  Someday I'll get around to re-scanning all the images I used a flatbed for, but that's a lot of lost time.
Yes, it's worth paying your dues to get the real thing.
> start printing.
Lots of options there, and this is the place to learn about them.
2010-03-16 by Jason Randolph
>digital print?
Check out "From Camera to Print" at www.luminous-landscape.com.  It's a
multiple-hour tutorial that steps you through taking your images from the
camera and making fine art matted and framed prints.  There is a chapter
dedicated specifically to scanning negatives.  Definitely worth the money
for the tutorial.
Re: [Digital BW] Re: Beginners questions
2010-03-16 by Lew
I shoot mostly 35mm, some mf, and an even smaller amount of view camera formats. I already have the same scanner.
A perverse thought I keep having is that it might be possible to bleach the silver out of a neg & redevelop with something that can be scanned easily. Has anyone done this? A few of my scans are really terrible.
Date: Tue, 16 Mar 2010 14:42:49
Subject: [Digital BW] Re: Beginners questions
> start printing.
2010-03-16 by Lew
Will do. Thanks.
Date: Tue, 16 Mar 2010 05:20:29
>digital print?
for the tutorial.
"Lew" <lew1716@...> wrote:
> ... I already have the [Nikon 8000 medium format film scanner]...
The main thing I find needed for that scanner and its driver are to scan the B&W negative as a grayscale positive.  That way you can avoid clipping the ends via the histogram adjustment.
I also scan with no grain reduction and also with grain reduction if there is a plain sky.  It's easy to combine the 2 in PS if the negative has not been moved (or even if it has with CS4's align layers).  I do also find the glass carrier is needed for some negatives.  I suppose the best is to use fluid, but I have not gone that far.  I do notice that if the recommended Photo Flo was use, Newton's rings might show up.  I suspect it's the glycol in the Photo Flo.  Half the normal amount of some other wetting agent would be recommended.
I went to Tech Pan to avoid the grain problems.  Digital does show grain, and it is a problem with my older Tmax 100 MF negatives.  If I ever go back to Tmax 100 (not likely) I'd look at a staining developer system, but I doubt it'd be worth the negatives -- so to speak.  Even with it's grain, I prefer my Tmax 100 negs to the T400 CN negs I have.
2010-03-16 by Lew
The main & perhaps impossible problem I face is years & years of Tri-X & HP5 in D76 & related soups.
Date: Tue, 16 Mar 2010 17:37:28
2010-03-16 by Dave
If you've shot mostly 35, why not embrace the grain rather than fight
it?
IMO, grain is what makes 35mm, 35mm.
I don't think you'll find any magic in any of the books that takes care of that.  I find applying various noise-type filters to a duplicate layer below the main one and then selectively erasing the parts that need softening in the top layer is about as good as it gets in terms of lessening the grain.
Of course, with plain "blue" skies you can use gradients to replace most  of the original grainy sky.  Very careful selection of the sky is one of the more labor intensive parts of working up a landscape image that has that type of problem.
2010-03-16 by Lew
Yes, but the grain and/or noise introduced by the scan seems to be way more noticeable than in a wet print from the same negative. Also, I'm not interested in re interpreting my negs. I want the inkjet prints to look as much like the wet prints as possible.
Date: Tue, 16 Mar 2010 12:21:49
Subject: Re: [Digital BW] Re: Beginners questions
it?
2010-03-16 by Dana Myers
> it?
I'll take that a step further and say that, for me, the distinctive look
of a capture on silver is something reproduce accurately throughout
scanning and printing.  Every one has their own desire, though; for
decades, many shot on silver because that's all there was but really
wanted the smooth grainless look of digital :-)
Dana  K6JQ
2010-03-16 by David Kachel
Scan one full paper size larger than the maximum size you will print, and at double the dpi you intend to use. Then downsize the image and dpi before printing and you will minimize the grain.
As for getting from digital what you got from analog, that is a lot like a new cello player trying to get the sounds he used to get with a violin; perhaps possible, but not very fruitful.
David Kachel
2010-03-16 by Dave
Indeed, the grain is more noticeable in a scanned image. I suspect it
has something to do with the directional nature of a scanner's light
source. If you're used to printing with a diffusion head, you'll have
a difficult time reproducing the same effect from a scan. It's a
little easier if you worked with a condenser head, and it's a walk in
the park if your normal mode of printing was with a point light
source...
  As Paul said, there are ways of minimizing grain, but there's no
simple solution. It's going to take a lot of experimentation. I've
spent a lot of time trying to get some negatives to scan with less
grain, and in some cases I've not been able to pull it off. In large
part, my success or failure has been dependent on the subject matter.
2010-03-16 by Mark Savoia
Then flatbed scan the print.
Mark
http://www.stillrivereditions.com
> possible.
2010-03-16 by Sam McCandless
I have a lot of small-format B&W prints (w/o neg's) to re-print and am
thinking about getting an Epson V700 or V750-M flatbed both for those
prints and also for my 35mm slides and negatives (which I also print
in relatively small formats).
Sam
> Mark
>> possible.
2010-03-19 by Keith
> A perverse thought I keep having is that it might be possible to bleach the silver out of a neg & redevelop with something that can be scanned easily. Has anyone done this? A few of my scans are really terrible.<
In order to do Palladium prints from some of my 10x8 negs without having to make another higher contrast negative, I have used a rehalogising bleach, and then re-developed in a Pyrocatechol based developer. This is a staining developer but much cheaper to make up than a Pyro based one. I would however test it on a negative that is not important. Try Googling "Sandy King" he has a formula on his site.
Keith Dugdale.
