hello anton,
yes, you're right about that...
the a152 T & H outs only output cv's in a sequential
order. 8 cv's from its 8 T & H ouputs(assuming that it
will be receiving quantized cv signal via its T & H
input from the a156.)
so, if, say, someone, plays a few notes, then the 8
a152 T & H outputs will just keep on outputing
quantized note cv's but each of the a152's outputs
will NOT give only one specific note value's cv...
(hope this makes sense...)
apart from that, there is the multiple octaves notes
problem you mentioned too.
regards,
Bakis.
--- Dubshot <dubshot@xs4all.nl> wrote:
> Hi there Bakis,
> But how could you seperate the different note values
> in such a setup?
> You have e.g. 7 different values (not even 8) in
> most diatonic scales, but
> they go through at least 7 octaves, so how would you
> 'group' the common
> values from different octaves?
> I think it would be great if the AD/DA module could
> handle that task.
> Greetings
> Anton
> > hello anton,
> > thank you for the detailed explanation. i see that
> > such a module would be very usefull indeed.
> > something like this could be achived with the a152
> in
> > combination with the a156 and a155. ]
> > but, the a152 has 8 cv outputs and 8 gate outs,
> not 12
> > at least, as the module you suggested. (if you
> connect
> > a common clock to the a155 and a152 and then
> connect
> > the a156 quantized cv out to the T & H input of
> the
> > a152, then you have 8 quantized cv outputs plus 8
> gate
> > outputs from the a152). am i right?
> > regards,
> > Bakis.
> > --- Anton Coops <dubshot@xs4all.nl> wrote:
> >> Hi Bakis,
> >> Well, I guess that there are basically 2 uses for
> >> any quantizer
> >> (correct me if I'm wrong please)
> >> 1. correcting/tuning the output from a sequencer
> >> 2. deriving note-sequences (melodies, arpeggio's)
> >> from any voltage
> >> source, like an lfo, adsr, noise, complex
> envelopes
> >> etc. etc
> >> If Chuck sees no use for a 'breakout box' for
> >> individual note-values,
> >> my guess would be that he uses a quantizer
> primarily
> >> to tune a
> >> sequencer.
> >> But I think quite a few people on this list have
> >> allready asked for
> >> something a little more sophisticated than the
> >> a-156, to be able to
> >> customise or finetune the scales, melodies,
> >> arpeggio's or whatever it
> >> is they want to derive from some dynamic voltage
> >> source.
> >> I think a minimum option would be 12 cv-outputs
> for
> >> each of the 12
> >> values of the a-156, for building custom scales.
> >> Once you can get to
> >> these individual values, you could finetune them
> >> further with the high
> >> precision adder that's coming up? (Not sure about
> >> this) so that
> >> would even make it possible to create all kinds
> of
> >> tunings outside the
> >> 12-tone equal temperament tuning (allthough this
> >> might cost a lot of
> >> modules)
> >> But also extra functionality for arpeggio's would
> be
> >> nice (this
> >> probably means more cv-outputs) and perhaps even
> an
> >> individual
> >> gate-output for each cv-output (like Joost is
> >> suggesting?) which
> >> might be very handy for all kinds of extended
> uses.
> >> Greetings,
> >> Anton
> >> On 15 May 2006, at 14:33, Bakis Sirros wrote:
> >> > maybe Anton can enlighten us with more details
> >> about
> >> > this proposed module and it's possible uses?
> >> > regards,
> >> > Bakis.
> >> > --- unknown freak <vogelscheiss@gmail.com>
> wrote:
> >> > > I'm distinctly confused and dubious as to the
> >> > > utility value of such a
> >> > > module.
> >> > > --Chuck
> >> > > _____
> >> > > From: Doepfer_a100@yahoogroups.com
> >> > > [mailto:Doepfer_a100@yahoogroups.com]
> >> > > Sent: Monday, May 15, 2006 1:23 PM
> >> > > To: Doepfer_a100@yahoogroups.com
> >> > > Subject: [Doepfer_a100] New poll for
> >> Doepfer_a100
> >> > > Enter your vote today! A new poll has been
> >> created
> >> > > for the
> >> > > Doepfer_a100 group:
> >> > > Would you like Doepfer to release an
> Expansion
> >> > > module for all quantizers
> >> > > (hopefully including A-156)
> >> > > for creating scales and arpeggio's?
> >> > > [A module that would probably contain 24 or
> 32
> >> jack
> >> > > outputs (+ led's)
> >> > > that output only a certain step/value/note or
> >> > > whatever you want to
> >> > > call it in the current tuning, through all
> >> octaves.
> >> > > By selecting certain
> >> > > outputs you select steps/values in a scale.
> E.g.
> >> in
> >> > > 12-tet output 1
> >> > > only outputs c, output 2 only outputs c#,
> output
> >> 3
> >> > > only outputs d-
> >> > > values etc. Each individual step/value can
> now
> >> be
> >> > > further processed,
> >> > > or certain steps can be grouped using
> multiples
> >> etc.
> >> > > For simple tunings (say 5 steps in an octave)
> it
> >> > > should be possible to
> >> > > 'fill up' all the availabe outputs (all 24 or
> >> so) so
> >> > > you can even make
> >> > > different scales/pick out different
> combinations
> >> of
> >> > > notes in different
> >> > > octaves, which means you could do all kinds
> of
> >> > > arpeggio's, spanning
> >> > > perhaps 4-6 octaves.]
> >> > > o Yes!
> >> > > o maybe...
> >> > > o no.
=== message truncated ===
Bakis Sirros - Parallel Worlds
[Doepfer_a100] group owner
http://www.shimarecords.co.uk
http://www.rubber.gr
Athens-Greece
Do You Yahoo!?
Tired of spam? Yahoo! Mail has the best spam protection around
http://mail.yahoo.com
