Doepfer
Roland Sh-101 and Doepfer VCO sync
2006-07-22 by beatboxgestapo
Hello,
  Does anyone have any ideas about the best way to sync the VCO of a
Roland Sh-101 to the two A-110 VCOs of a Doepfer system?
Any input is much appreciated.
Thank you,
Beatboxgestapo
AW: [Doepfer_a100] Roland Sh-101 and Doepfer VCO sync
2006-07-24 by hardware@doepfer.de
This would require a hardware modification of the SH-101. I'd recommend this
only for users who are experienced with electronics and soldering. You have
to get the SH-101 schematics and find out the solder point of the SH-101
that has available the rectangle output of the VCO, and add a buffer and a
socket to your SH-101.
Best wishes
Dieter Doepfer
> [mailto:Doepfer_a100@yahoogroups.com]Im Auftrag von beatboxgestapo
> Gesendet: Sonntag, 23. Juli 2006 00:11
> Betreff: [Doepfer_a100] Roland Sh-101 and Doepfer VCO sync
> Hello,
> Thank you,
> Beatboxgestapo
Re: AW: [Doepfer_a100] Roland Sh-101 and Doepfer VCO sync
2006-07-24 by Florian Anwander
Hi Dieter
If I understand you right this is the description of a SH-101 as Sync
Master! This would be also possible with the plain line out of the
SH-101 (Osc to narrow pulse, no subosc, Cutoff 100%) and a A-119 (or
assumingly any buffer like module like A167,A175,...).
But as I understand the original poster asked for using the SH-101 as
Sync-Slave. This would really require modifying the SH-101.
Florian
> Best wishes
> Dieter Doepfer
>>Hello,
>>Thank you,
>>Beatboxgestapo
>>Yahoo! Groups Links
Florian Anwander                  |ConSol
Tel.   +49(89)45841-133           |Consulting&Solutions Software GmbH
Fax    +49(89)45841-111           |Franziskanerstr. 38, D-81669 München
email: florian.anwander@consol.de |http://www.consol.de
AW: AW: [Doepfer_a100] Roland Sh-101 and Doepfer VCO sync
Hi Florian,
yes that's possible on principle. But in this case the sync will work only
as long as a tone appears at the SH-101 audio output (i.e. as long as e.g. a
key is held down on the keyboard and the VCF, VCA and ADSR controls are set
to suitable values). As far as know the SH-101 has no offset control for the
final VCA to open the VCA but only an ADSR or gate mode for the VCA. I can't
remember if the 101 has a hold function that could be used instead of that.
Best wishes
Dieter Doepfer
> [mailto:Doepfer_a100@yahoogroups.com]Im Auftrag von Florian Anwander
> Gesendet: Montag, 24. Juli 2006 11:56
> Betreff: Re: AW: [Doepfer_a100] Roland Sh-101 and Doepfer VCO sync
> Hi Dieter
> recommend this
> soldering. You have
> buffer and a
> Florian
> > Best wishes
> > Dieter Doepfer
> >>Hello,
> >>Thank you,
> >>Beatboxgestapo
> >>Yahoo! Groups Links
> > Yahoo! Groups Links
Re: AW: AW: [Doepfer_a100] Roland Sh-101 and Doepfer VCO sync
2006-07-25 by Florian Anwander
Hello Dieter,
The SH101 has a hold function (without that the arpeggiator would be
worth only the half).
Florian
