Doepfer
a-188-1 question
a-188-1 question
2006-08-14 by deejayy_svenn
Hello
Im thinking of buying one of these to use as a regular VC analog delay
with VC of delaytime and feedb, sort of like the Blacet Time Machine.
I can see that the module has no antialiasing filter, does this means
that I need a vcf module as well ?
/DJS
Re: a-188-1 question
2006-08-14 by selfoscillate
hello,
the blacet time machine uses two internal filters, one at the
signal input (to get rid of aliasing) and one at the signal output
(to remove the clock noise). i believe that both of these
filters have a 30db lowpass response. so if you want to
get close to the time machine sound you would need the
a188/1d (4096 stages) and two lowpass vcf's (the steeper the better).
often the filter at the signal input can be omitted, because
it is a matter of taste (and how the input signal looks like)
if the aliasing is problematic or not. but you will for sure
want a filter at the bbd output to eliminate the clock noise
when using long delay times.
and of course you need a vca or vc-polarizer in the feedback
loop of the a188/1d to get voltage controlled feedback.
best wishes
ingo
--- In Doepfer_a100@yahoogroups.com, "deejayy_svenn"
<deejayy_svenn@...> wrote:
> Hello
> /DJS
