Doepfer
A module I would love to see...
2006-09-24 by James Husted
This module idea may have been posted before, if so here it is
again. I would love a CV to MIDI Note converter. I think the A-192
does a great job at providing continuous MIDI streams from CV but
what I would like is Note events. I see the module being very simple
in function. It would have a CV in for Pitch, Velocity, and
Modulation depth (almost all midi synths can handle these) and a Gate
in. When the module sees the rising edge of the gate it samples the
CV inputs and makes a Note ON MIDI message accordingly. When the gate
goes low it makes the correct Note OFF. The MIDI channel can be set
via a dip switch (either on the PCB inside or poking through the
panel - a cheap solution). The CV input ranges would be standard 1V/
Oct for pitch and full positive Doepfer range for the others (these
are commonly scalable on the MIDI module end). A added bonus input if
affordable would be a continuous CV in for MIDI channel volume but
this could be provided by patching the MIDI out into the MIDI in of a
A-192. This would be a MONO device and only do one note at a time. It
could have a MIDI in that could merge and allow multiple units to be
stacked for POLY functions. The most common use for me would be to
set it next to a A-155 (build your own MAQ)  or a LFO/A-148 (wild
appegios/scales). Anyway, I would love one or more in my rig to do
more CV control of my MIDI gear.
James Husted
The ErsatZ Planet Graphics and Sound
http://homepage.mac.com/ersatzplanet/
james.husted@mac.com
"Welcome to the first day of the rest of your money..."
Re: [Doepfer_a100] A module I would love to see...
2006-09-24 by Bakis Sirros
hello james,
i would really like such a module too.
it must not be any difficult for dieter to make and
really usefull!
maybe i should start a new poll about such a module,
dieter?
best regards,
bakis.
> so here it is
> think the A-192
> streams from CV but
> being very simple
> Velocity, and
> these) and a Gate
> it samples the
> channel can be set
> through the
> be standard 1V/
> the others (these
> channel volume but
> the MIDI in of a
> note at a time. It
> me would be to
> LFO/A-148 (wild
> in my rig to do
> James Husted
> money..."
Bakis Sirros - Parallel Worlds
[Doepfer_a100] group owner
http://www.shimarecords.co.uk
http://www.rubber.gr
Athens-Greece
Do You Yahoo!?
http://mail.yahoo.com
AW: [Doepfer_a100] A module I would love to see...
2006-09-26 by hardware@doepfer.de
Bakis,
yes, I'd recommend a poll. We considered several times to built such a
device but were not sure if there are sufficient inquiries. For us an
important part of the poll would be the type of construction (A-100 module
or stand alone device like MCV4).
Best wishes
Dieter Doepfer
> [mailto:Doepfer_a100@yahoogroups.com]Im Auftrag von Bakis Sirros
> Gesendet: Sonntag, 24. September 2006 23:48
> Betreff: Re: [Doepfer_a100] A module I would love to see...
> hello james,
> really usefull!
> dieter?
> best regards,
> bakis.
> > so here it is
> > think the A-192
> > streams from CV but
> > being very simple
> > Velocity, and
> > these) and a Gate
> > it samples the
> > channel can be set
> > through the
> > be standard 1V/
> > the others (these
> > channel volume but
> > the MIDI in of a
> > note at a time. It
> > me would be to
> > LFO/A-148 (wild
> > in my rig to do
> > James Husted
> > money..."
> Athens-Greece
> Do You Yahoo!?
2006-09-26 by Florian Anwander
Hi James
I think it should be a typical job for software. E.G apple/emagic-logic
can do such a conversion from controllers to note events in its
environment. I don't know whether other Sequencers offer similar features.
Florian
Re: AW: [Doepfer_a100] A module I would love to see...
2006-09-26 by Bakis Sirros
ok!
poll coming soon to a group near you!
Bakis.
--- hardware@doepfer.de wrote:
> Bakis,
> Best wishes
> Dieter Doepfer
> von Bakis Sirros
> to see...
> > hello james,
> and
> > really usefull!
> module,
> > dieter?
> > best regards,
> > bakis.
> if
> > > so here it is
> I
> > > think the A-192
> > > streams from CV but
> module
> > > being very simple
> > > Velocity, and
> handle
> > > these) and a Gate
> gate
> > > it samples the
> > > channel can be set
> poking
> > > through the
> would
> > > be standard 1V/
> for
> > > the others (these
> > > channel volume but
> into
> > > the MIDI in of a
> one
> > > note at a time. It
> for
> > > me would be to
> a
> > > LFO/A-148 (wild
> more
> > > in my rig to do
> > > James Husted
> > > money..."
> > Athens-Greece
> > Do You Yahoo!?
> protection around
> > Yahoo! Groups Links
Athens-Greece
Do You Yahoo!?
Hi Dieter
What about a case, that is able to contain a one or two modules and a
connector for external supply voltage? Could be used for any kind of
modules. I think many modules are very interesting as standalone
devices. The major problem might be the external +/-12V powersupply.
Florian
AW: AW: [Doepfer_a100] A module I would love to see...
Florian,
we are working on a small box that can be used in combination with the
miniature power supply/bus. We are waiting for a prototype from our case
manufacturer.
Best wishes
Dieter Doepfer
> [mailto:Doepfer_a100@yahoogroups.com]Im Auftrag von Florian Anwander
> Gesendet: Dienstag, 26. September 2006 14:10
> Betreff: Re: AW: [Doepfer_a100] A module I would love to see...
> Hi Dieter
> (A-100 module
> Florian
2006-09-26 by James Husted
Most sequencers can convert controller event to notes but the problem
is in the programming of the note on and off events which are not
included in the continuous MIDI stream provided by boxes like the
A-192.  I guess one could make the CC events go between a high level
to a very low one and have the MIDI sequencer ignore "note" values
below a certain level thus making a note off like event. Not as easy
as programming/jamming with a realtime sequencer and having
everything remembered by the computer - one of my goals.
James Husted
James.husted@mac.com
"Welcome to the first day of the rest of your money."
On Sep 26, 2006, at 4:07 AM, Florian Anwander wrote:
> Hi James
> logic
> features.
> Florian
This is a great Idea! Something like the cases that hold the stand
alone Oberheim SEM and Mini Sequencer. Just the power supply needed.
The metal work cold be made cheaply without the euro-rails and with
threaded holes instead to cut cost. Or even the sliding-bolt-in-the-
rail approach used in some euro-rack designs.
James Husted
On Sep 26, 2006, at 5:10 AM, Florian Anwander wrote:
> Hi Dieter
>> (A-100 module
> Florian
