Doepfer
Poll results for Doepfer_a100
2006-10-28 by Doepfer_a100@yahoogroups.com
The following Doepfer_a100 poll is now closed.  Here are the
final results:
POLL QUESTION: Would you like Doepfer to release a CV/Gate to Midi Notes device? [ It would have a CV in for Pitch, Velocity, and Modulation depth (almost all midi synths can handle
 these) and a Gate
in, plus a Midi Out of course. When the module sees the rising edge of the gate
it samples the
CV inputs and makes a Note ON MIDI message
accordingly. When the gate
goes low it makes the correct Note OFF. The MIDI
channel can be set
via a dip switch (either on the PCB inside or poking
through the
panel - a cheap solution). The CV input ranges would
be standard 1V/Oct for pitch and full positive Doepfer range for
the others (these
are commonly scalable on the MIDI module end). A
added bonus input if
affordable would be a continuous CV in for MIDI
channel volume but
this could be provided by patching the MIDI out into
the MIDI in of a
A-192. This would be a MONO device and only do one
note at a time. It
could have a MIDI in that could merge and allow
multiple units to be
stacked for POLY functions. The most common use for
me would be to connect it to an A-155 (build your own MAQ) or a
LFO/A-148 (wild
arpegios/scales)].
CHOICES AND RESULTS
- Yes! built in the form of an A100 module, 5 votes, 27.78%
- Maybe..., built in the form of an A100 module, 5 votes, 27.78%
- Yes! built as a stand-alone device, 2 votes, 11.11%
- Maybe..., built as a stand-alone device, 0 votes, 0.00%
- No., 6 votes, 33.33%
For more information about this group, please visit
http://groups.yahoo.com/group/Doepfer_a100
For help with Yahoo! Groups, please visit
http://help.yahoo.com/help/us/groups/
