Doepfer
voltage controllable hardware effects?
2006-11-15 by redsawcloud
I'm looking for effects units to voltage control with my Doepfer. Effects units that have a
voltage control input? (something like the ADA Flanger that has a Voltage Control input
jack) I like the idea of different kinds of equipment breathing voltages into one another.
I'm having a difficult time finding units on the web.
I'm curious how many people do this and what units are out there that allow it?
Thanks for your help,
Re: voltage controllable hardware effects?
2006-11-15 by djsoysos
I'm not sure what units are out there that have
this type of control imput. That's partly what got
me into the Doepfer A-100 system. I use my rack
mainly as a signal processor. So I can make what ever
crazy ass flanger I want with an A-188-1 1024
some LFO's and what ever else I feel like using.
Soy Sos
Re: [Doepfer_a100] voltage controllable hardware effects?
2006-11-15 by neil jendon
Without modding, I know the Big Briar MoogerFooger
pedals and the Frostwave effects both have CV ins.
You'll need 1/8" to 1/4" adapters.
> web.
Sponsored Link
Mortgage rates near 39yr lows.
$310k for $999/mo. Calculate new payment!
www.LowerMyBills.com/lre
2006-11-15 by John
Great question. I also think CV is a HUGE plus when shopping for
effects. Off the top of my head I can tell you that my MoogerFooger Delay
has CV inputs. I have a Korg Stage Echo 500 that has CV ins for various
functions. Also, most of the old Eventide line has CV control, like their
first Harmonizer. I own the Eventide Instant Flanger and you can add a CV In
to that. Marshall Time Modulator also has a CV Input. Basically almost any
effect made before 1983 has some sort of CV control.
    regards,
    John
> units that have a
> Control input
> one another.
> it?
2006-11-15 by Jay
I know the Hiwatt Tape Echo has an expression pedal input to control the
speed of the tape. I'm fairly certain that you can control it with CV.
http://www.hiwatt.com/data/HiwattFX.html
AW: [Doepfer_a100] voltage controllable hardware effects?
2006-11-16 by hardware@doepfer.de
> that allow it?
If the effects unit in question has no CV input the A-101-9 universal
vactrol module may solve the problem. It cannot be used in all cases. But if
there is a potentiometer in the effect unit that is used to control the
parameter in question it will work.
Best wishes
Dieter Doepfer
2006-11-16 by Florian Anwander
Hi
Paul already listed a lot.
I may add:
Vestakaza Dig420 (V/Octave playable Digital delay)
MXR Pitchtransposer (only V/Hz :-( )
Also nearly every analoge guitar stomp-box, which provides a Modulation
(Phasers/Flangers...) can be modded simply, because the Mod depth
potentiometer usally is the right point to insert an external CV.
Florian
Florian Anwander, Consulting&Solutions Software GmbH
Franziskanerstr. 38, D-81669 Muenchen, Tel. ++49(89)45841-133
http://www.consol.de
Re: AW: [Doepfer_a100] voltage controllable hardware effects?
2006-11-16 by Ross Goniakowski
i was thinking about that...i have an old Ross analog delay pedal (no relation) that has 3 chips in it marked "1024", my guess is they are daisey-chained, it has a max time of 500ms i believe, dry and wet out,  and i like the sound quite a bit....i'd like to add VC to it, do you think it possible? perhaps i could wire the A109 to a jack, add a jack to the Ross AD, and bypass the scratchy delay knob? it would be very cool...i have a Doepfer 2048 dealy also, btw...i figure i could use the Ross for longer dub delays, the Doepfer for slapback, ringing dealys, mod feedback madness....
  on the VC hardware tip: i have a Delatap Lab Effectron and a LoftSeries 450 delay...the Loft has a range of .5-20 ms and4-160 ms (flange or delay setting respectively, not even sure if it's digi or analog haha),  the Effectron has 6 range settings from 1-1024 ms, it's definately digi...the only thing that bugs be about it is if you grab a sample (infinite repeat), it doesn't seem to transpose  at  1v/oct as my  Roland  MPU 101 midi>cv box provides (and all my other analog gear uses)...andbody know what's with this? i have some thougts, but anyone have a sure-fire recipe for scaling cv at 1v/oct to "other"? i'm think a combo a a bias voltage and the cv in question thru a cv mixer or something?
  thanks,
  rg
> that allow it?
Best wishes
Dieter Doepfer
AW: AW: [Doepfer_a100] voltage controllable hardware effects?
I think this will work. But I'd connect the A-101-9 vactrol output in
parallel to the existing potentiometer. With this wiring you can use the
pedal as before. If you connect the additional socket of the pedal to the
A-101-9 you have to turn the knob on the pedal fully CCW or CM (maximim
delay time) and the A-101-9 has now the control. The knob can also be used
to limit the A-101-9 control to a desired delay time value.
Best wishes
Dieter Doepfer
