Doepfer
16 pin to 16 pin cable...
2007-04-11 by jeswa
The Analogue Haven description for the 16 pin to 16 pin cable reads:
"Make sure that the module in question uses all 16-pins on the PCB
side (such as the A-110, A-111, A-140, A-142 and others)"
Is there any harm in using these cables with a 10 pin bus connector,
assuming it's hooked up corectly?
Re: 16 pin to 16 pin cable...
2007-04-11 by ilanode
If hooked up correctly: No. Only diff. is that those modules are no
longer connected to the gate and cv signals on the bus board.
2007-04-12 by synthtrader
connector,
Right, no harm, it was an attempt to distinguish the two cables on our
webpage. Maybe I will edit the text when I find some time.
Shawn Cleary
www.analoguehaven.com
