Doepfer
Quantizer modification question
2007-07-08 by stuadh
  does anyone know how to mod the A-156 Quantizer to play the 4th
instead of the 6th?
Yours Aye
Stuadh
AW: [Doepfer_a100] Quantizer modification question
2007-07-09 by hardware@doepfer.de
> Hi,
> instead of the 6th?
> Yours Aye
> Stuadh
This would require a software modification of the microcontroller used in
the A-156. Christian Assall is on holiday at present and I can't ask him how
time-consuming such a modifiaction would be.
Best wishes
Dieter Doepfer
Re: Quantizer modification question
2007-07-09 by stuadh
Thank you.  I'm not in a hurry, but I'm definitely interested.
Yours Aye
Stuadh
used in
him how
> Best wishes
> Dieter Doepfer
AW: [Doepfer_a100] Re: Quantizer modification question
2007-10-15 by hardware@doepfer.de
> Would it be possible to make the A-156 to accept negative voltages too?
Not in an easy way. The A-156 was developed as an expansion module for the
A-155 which outputs only positive voltages. As the AD converter of the A-156
accepts only positive voltages you need an additional offset that shifts the
negative voltage into the positive range. One of the mixers A-138a/b/c, the
A-129-3 or the new precision adder A-185-2 can be used to obtain such a
positive offset.
Best wishes
Dieter Doepfer
