Doepfer
A-185-2 Precision CV Adder last minute comment
2007-07-29 by jalmari3
I can't figure the Yahoo mess, so I start a new topic. Sorry.
It is propably too late, but:
- Adding octave switch and/or offset knob to the A-185-2 could make it
a one stop pitch control center. My controllers and oscillators don't
have octave switches...
- I might prefer 3 non-inverted outputs and 1 inverted output instead
of 2 non-inverted outputs and 2 inverted outputs.
Best regards
Jari Jokinen
Re: A-185-2 Precision CV Adder last minute comment
2007-08-09 by jalmari3
No one agrees?
--- In Doepfer_a100@yahoogroups.com, "jalmari3" <jari.jokinen@...>
it
don't
instead
> Best regards
> Jari Jokinen
2007-08-09 by gabu_004
Yes that's a very good idea... this should be taken into
consideration!
g.
wrote:
> No one agrees?
> --- In Doepfer_a100@yahoogroups.com, "jalmari3" <jari.jokinen@>
make
> it
> don't
> instead
> > Best regards
> > Jari Jokinen
Re: [Doepfer_a100] Re: A-185-2 Precision CV Adder last minute comment
2007-08-09 by Silas Johansen
Good idea - I wouldn't like to have to use a voltage inverter to reinvert an
inverted voltage just to get an uninverted voltage. Much better to save my
inverter for inverting uninverted voltages in order to get inverted ones.
Also, when doing too many inversions you might inadvertently invert too few
or too many times, which may, in conclusion, cause confusion.
:-P
Silas
> consideration!
> g.
> --- In Doepfer_a100@yahoogroups.com <Doepfer_a100%40yahoogroups.com>,
> wrote:
> > No one agrees?
> make
> > it
> > don't
> > instead
> > > Best regards
> > > Jari Jokinen
2007-08-09 by Denis Gökdag
*grin*
The octave switch is a good idea.
Denis
> reinvert an
> save my
> ones.
> too few
> :-P
> Silas
> > consideration!
> > g.
> 40yahoogroups.com>,
> > wrote:
> > > No one agrees?
> 40yahoogroups.com>,
> > make
> > > it
> > > don't
> > > instead
> > > > Best regards
> > > > Jari Jokinen
AW: [Doepfer_a100] Re: A-185-2 Precision CV Adder last minute comment
2007-08-09 by hardware@doepfer.de
The production of the CV boards and the front panels for CV Adder should
start next week as there were no additional suggestions since the
announcement of the module in May 2007 and the polls for this module in June
2007. But I'll try to stop the production of the pc boards and front panels.
How about this simple solution: A default voltage of +1.00V is connected to
the switching contacts of the input socktes #1 and #2. This would add these
features:
As long as no cable is connected to input #1 it works as a manually
adjustable offset with up to +/- one octave.
As long as no cable is connected to input #2 it works as an octave switch
(+/- one octave).
With this solution one can decide if the inputs #1 and #2 can be used as
offset control and octave switch or as originally planned.
Best wishes
Dieter Doepfer
> -----Ursprungliche Nachricht-----
> [mailto:Doepfer_a100@yahoogroups.com]Im Auftrag von Denis Gokdag
> Gesendet: Donnerstag, 9. August 2007 15:38
> Betreff: Re: [Doepfer_a100] Re: A-185-2 Precision CV Adder last minute
> comment
> *grin*
> Cheers,
> Denis
> > reinvert an
> > save my
> > ones.
> > too few
> > :-P
> > Silas
> > > consideration!
> > > g.
> > 40yahoogroups.com>,
> > > wrote:
> > > > No one agrees?
> > 40yahoogroups.com>,
> > > make
> > > > it
> > > > don't
> > > > instead
> > > > > Best regards
> > > > > Jari Jokinen
Re: AW: [Doepfer_a100] Re: A-185-2 Precision CV Adder last minute comment
2007-08-10 by Bakis Sirros
hello list and Dieter,
i think that these suggestions of Dieter are great and
easy to implement, right?
although, for me, the octave switch feature is not
needed, as the doepfer vco's have octave switches. the
Analogue systems vco do not, but there is a dedicated
analogue systems module called octave controller for
this function.
but, anyway, the more features the A185-2 has, the
better...
best regards,
Bakis.
> for CV Adder should
> features:
> works as a manually
> (+/- one octave).
> planned.
> Best wishes
> Dieter Doepfer
> von Denis Gokdag
> > comment
> > *grin*
> > Cheers,
> > Denis
> voltage inverter to
> > > reinvert an
> > > save my
> > > ones.
> > > too few
> cause confusion.
> > > :-P
> > > Silas
> taken into
> > > > consideration!
> > > > g.
> <Doepfer_a100%
> > > 40yahoogroups.com>,
> > > > wrote:
> > > > > No one agrees?
> <Doepfer_a100%
> > > 40yahoogroups.com>,
> a new topic. Sorry.
> > > > make
> > > > > it
> > > > > don't
> > > > > instead
> outputs.
> > > > > > Best regards
> > > > > > Jari Jokinen
> removed]
> removed]
[Doepfer_a100] group owner
http://www.myspace.com/interconnectedmusic
http://www.myspace.com/memorygeist
http://www.DiN.org.uk
http://www.shimarecords.co.uk
http://www.rubber.gr
Athens-Greece
Be a better Globetrotter. Get better travel answers from someone who knows. Yahoo! Answers - Check it out.
http://answers.yahoo.com/dir/?link=list&sid=396545469
2007-08-10 by Florian Anwander
Hi
I'd only suggest, that inputs #7 and #8 get this voltage adder feature.
I think it is really useful in the adder, because you can't transpose
the complete setup of several VCOs and the VCF keyboard VC with the
transpose switch of a single VCO ;-) - no honestly: eg the MonoPoly has
exactly such a two octave transpose switch, and find it very very useful.
Also I could imagine that people who do not have hands with only five
left thumbs on each hand will be able to replace one input socket and
replace it by a switch.
Florian
ok, then.    :-)
--- Florian Anwander <Florian.Anwander@consol.de>
wrote:
> Hi
> and
> you can't transpose
> eg the MonoPoly has
> input socket and
> Florian
Athens-Greece
____________________________________________________________________________________Ready for the edge of your seat?
Check out tonight's top picks on Yahoo! TV.
http://tv.yahoo.com/
AW: AW: [Doepfer_a100] Re: A-185-2 Precision CV Adder last minute comment
2007-08-10 by hardware@doepfer.de
> Hi
> Florian
How about adding the 1.00 V default voltage to each of the inputs ? That way
each unused input can be used as +/-1 octave switch (even additive to obtain
e.g. +2 octaves).
And the right output sockets are manually wired. If desired we could connect
both to the non-inverting output thus obtaining three non-inverted and one
inverted output. We only have to change the front panel printing. Bakis: How
about a fast poll (should last not longer than one week as we want to go
into production).
Best wishes
Dieter Doepfer
Re: AW: AW: [Doepfer_a100] Re: A-185-2 Precision CV Adder last minute comment
> e.g. +2 octaves).
this would result in a steady 7 volts at the output (or did I
misunderstand you?). May be we should think about a real octave
switching module instead.
btw. is there a preliminary page for this module?
Florian
AW: AW: AW: [Doepfer_a100] Re: A-185-2 Precision CV Adder last minute comment
way
obtain
> > e.g. +2 octaves).
As we have only 4 inputs available the steady states could be in the
range -4V...+4V (with 1.00 voltage steps)
> May be we should think about a real octave switching module instead.
I think it's too late. We are about to start the production next week.
Yes, since ~ April or May 2007, e.g. via www(dot)doepfer(dot)com > PRODUCTS
> A-100 > FUTURE MODULES > A-185-2
A corresponding poll has been started on May 11, 2007 - followed by some
discussions.
happy holidays
Dieter
2007-08-10 by Denis Gökdag
I think this is a good solution.
Denis
>> inputs ? That way
>> to obtain
>> e.g. +2 octaves).
>> could connect
>> and one
>> Bakis: How
>> to go
>> into production).
>> Best wishes
>> Dieter Doepfer
2007-08-10 by bellenger_a
But Florian, Hello... I got confused too at some point because on that page of the 185-2...
it actually mentions A185-2 and 185-3.. But Dieter... Its actually all supposed to be one
module A185-2 correct? not two different versions A185-2 and 185-3?
And the version chosen through the poll is, so far, the one on the far right (4th one)?
Also me too i'm not too keen on two inverted outputs... one could do easily... and for the
rest... it seems that it doesnt change the basic concept of this module...
Best,
Alexandre
hello Dieter,
ok, please tell me the exact poll text and i'll create
it asap.
best regards,
Bakis.
> > Hi
> great and
> not
> switches.
> you can't transpose
> > Florian
> e.g. +2 octaves).
> into production).
> Best wishes
> Dieter Doepfer
Athens-Greece
Looking for a deal? Find great prices on flights and hotels with Yahoo! FareChase.
http://farechase.yahoo.com/
supposed to be one
Right. It's only typing error that occured during the front panel design.
All suggested panels should be labelled "A-185-2".
right (4th one)?
Yes, but we will probably have available three normal outputs and only one
inverted output. The printing of the front panel still has to be changed.
Have a nice weekend
Dieter Doepfer
P.S. Even the Manual Gate module has been revised a bit. Details on our
website: www(dot)doepfer(dot)com > PRODUCTS
> A-100 > FUTURE MODULES > A-164
> hello Dieter,
> it asap.
> best regards,
> Bakis.
Poll #1 (default voltage at the switching contacts of the sockets):
Do you want a +1.00 default voltage at the switching contacts of the input
sockets for usage of the control #1 and switch #1 as a common tuning knob
with polarity switch and usage of the switches of the other inputs as +/- 1
octave switches:
- input #1 only
- input #1 and #2
- input #1, #2 and #2
- all inputs
Poll #2 (output options):
- 2 non-inverting outputs, 2 inverting ouputs
- 3 non-inverting outputs, 1 inverting ouput
Thank you and have a nice weekend
Dieter
[Doepfer_a100] Re: A-185-2 Precision CV Adder latest Polls! VOTE!!!
hello list,
ok, latest Polls are up!
please vote!! you only have 7 days to do so!
best regards,
Bakis.
> > hello Dieter,
> create
> > it asap.
> > best regards,
> > Bakis.
> of the sockets):
> octave switches:
> - input #1 only
> - input #1 and #2
> - all inputs
> Dieter
Athens-Greece
2007-08-11 by bellenger_a
Dieter, do you think the first version was too narrow? a bit more space a bigger buttons
make it easier to use? or why that change?
otherwise... no difference in the functions right?
Best,
A
2007-08-12 by jalmari3
Could the extra space in the new 6HP design of A-164 be used for
something? For example: miniature multiple for each gate, (or)
inverted and non-inverted gate outs, (or) mute funtion for each
switch...
About A-185-2: Did I understand it right, that negative offset will
be possible? That would be practical IMO.
Best regards
Jari Jokinen
--- In Doepfer_a100@yahoogroups.com, "bellenger_a" <bellenger_a@...>
> Best,
> A
2007-08-13 by hardware@doepfer.de
> space a bigger buttons make it easier to use? or why that change?
> Best,
> A
You find all answers on the A-164-1 info page:
www(dot)doepfer(dot)de/a164.htm
Best wishes
Dieter Doepfer
> switch...
I will see if there is enough space to double the output sockets. Should be
possible.
Inverted gate outputs are not planned as there is no electronics available
on the module.
I dont't understand the function of a mute function. If you don't want a
gate simply do not operate the buttons.
Of course. The switches have three positions: left (voltage is subtracted),
center (no function), right (voltage is added).
If the share of the subtracted voltages is higher than the added voltages
the result is a negative output voltage.
Best wishes
Dieter Doepfer
2007-08-13 by jalmari3
> available on the module.
OK
> want a gate simply do not operate the buttons.
I was thinking the optional on/off function for external signals, as is
already planned for switch no 1 (referred as "kind of mute function" on
the A-164 page). I don't know, if this feature would be worth of having
for each three switches (rather than dual gate outputs).
Anyway, it is good to see some new utility modules appearing, as
sometimes it is tedious to do seemingly simple tasks. Although not
perfect for my personal needs, I will certainly get an A-185-2.
Best regards
Jari Jokinen
> subtracted),center (no function), right (voltage is added).
> voltages the result is a negative output voltage.
I wonder, if it would be stupid idea not to have +/-1V for every
switch: Perhaps for example +/- 1, 1, 2, 2 volts would be more
versatile (assuming all four switches will have offset function).
Best regards
Jari Jokinen
2007-08-15 by jalmari3
"I wonder, if it would be stupid idea not to have +/-1V for every
versatile (assuming all four switches will have offset function)."
Please, comment - It might be too late already.
Best regards
Jari Jokinen
