Doepfer
A143-1 problem
A143-1 problem
2007-10-24 by bellenger_a
Hello,
just got an A143-1 from MESI yesterday... trying it out this morning and from the MIX
OUTPUT I can only get the ENV1... not the other ones... It seems this module is defective?
should I just bring it back or is there anything simple I could check before that?
Thanks, best/a
Re: A143-1 problem
Florian, thanks for this quick answer...
SO... I think (well I hope so!) that I understood pretty well the functionning of the module
as everything seems to be working for me BUT EXCEPT from the MIX OUTPUT...
OR MAYBE I AM ALL MIXING IT UP
BASICALLY:
from the MIX OUTPUT should I not be get (lets say with nothing patched in... all in LFO
mod, and with all Mix Polarizer knobs at +2) all ENVELOPS mixed together?
My problem is that there is ONLY ENVELOP 1 which go to the MIX OUTPUT?
/alexandre/
--- In Doepfer_a100@yahoogroups.com, Florian Anwander <Florian.Anwander@...>
wrote:
> Hi
> you are aware, that Env2 to Env 4 are NOT triggered by the trigger-in by
> default but are connected to the comparator out?
> For testing set the "threshold" levels of Env1 to Env3 to at least 9
> o'clock position. If you want to use them as normal envelopes you have
> to connect the four Trigger Ins individually to the Gate from the
> MIDI-Interface or Keyboard.
> Florian
> bellenger_a wrote:
> > Hello,
defective?
> > Thanks, best/a
> > Yahoo! Groups Links
> Florian Anwander                  |ConSol
> Tel.   +49(89)45841-133           |Consulting&Solutions Software GmbH
> Fax    +49(89)45841-111           |Franziskanerstr. 38, D-81669 München
> email: florian.anwander@... |http://www.consol.de
Re: [Doepfer_a100] A143-1 problem
2007-10-24 by Florian Anwander
Hi
Florian
bellenger_a wrote:
> Hello,
> Thanks, best/a
email: florian.anwander@consol.de |http://www.consol.de
Re: A143-1 problem
> First of all please check if there are envelope signals for the outputs 2, 3
> and 4 (observable at the LEDs of the units 2, 3 and 4).
YES THEY ALL WORK... each envelop works and lits up OK...
>The solder point labelled "JP4" of
> all four boards (located behind the control "Mix Polarizer" at the edge of
> the board) should be connected with a blank wire. If this connection is
> missing only envelope output #1 appears at the mix output.
well there is some kinda thin metal bar (blank wire I guess as you said) joining all this JP4
points... and... in fact, I think maybe this blank wire isnt totally well soldered to the first
board in fact... which then might cause no contact... I dont know really if that is what's
wrong, I will bring back the module to MESI asap...
LAST MINUTE : well after I slightly touched the blank wire and plug the module back, its
now working... Dieter, would the guarantee goes off if I ask MESI to solder this again for
me?
thanks for yr attention,
/a/
> Best wishes
> Dieter Doepfer
AW: [Doepfer_a100] A143-1 problem
2007-10-24 by hardware@doepfer.de
> Hello,
from the MIX
before that?
and 4 (observable at the LEDs of the units 2, 3 and 4). If there are
envelope signals on all 4 outputs the module has to be sent in for repair if
only envelope 1 appears at the mix output. Maybe the manufacturer forgot to
connect the mix bus of all four boards. The solder point labelled "JP4" of
Best wishes
Dieter Doepfer
Re: [Doepfer_a100] Re: A143-1 problem
2007-10-24 by Bakis Sirros
have you set the "Mix Polarizer" knobs an all 4 env's
to the positive range (above zero)?
best regards,
Bakis.
> BASICALLY:
> to the MIX OUTPUT?
> /alexandre/
> wrote:
> > Hi
> Env3 to at least 9
> the Gate from the
> > Florian
> > bellenger_a wrote:
> > > Hello,
> defective?
> > > Thanks, best/a
> > > Yahoo! Groups Links
[Doepfer_a100] group owner
http://www.myspace.com/interconnectedmusic
http://www.myspace.com/memorygeist
http://www.DiN.org.uk
http://www.shimarecords.co.uk
http://www.rubber.gr
Athens-Greece
Do You Yahoo!?
http://mail.yahoo.com
AW: [Doepfer_a100] Re: A143-1 problem
> board in fact...
I suppose that the blank wire it was a bit bend during transportation and
this caused the interruption.
module back, its
> me?
No problem. We are not that nitpicking. Even if you are able to solder you
could do it yourself. I'm quite sure that it will solve the problem.
Best wishes
Dieter Doepfer
Re: A143-1 problem
2007-10-25 by bellenger_a
SUPER! GREAT!... I will sort this out... thanks you... btw... I SUPER LOVE THIS MODULE...
simple, efficient, intelligently made...
génial, merci beaucoup... also really waiting for these simple small 6HP serie to come up...
Good evening bye/+alexandre
