Doepfer
Re: [Doepfer_a100] a155 Grooves
2008-02-23 by Ross Goniakowski
i just happened to have an A-155 loop going when i read this post so i did a little test: i took one of the trigger outs on the A-155 to an A-140 ADSR, ran that into the A-101-9 Universal Vactrol mod (if you don't have one, get one), then i fed output to the Freq. jack i added to an A-145 LFO..works like a charm..i don't know if you are going to get drum machine style grooves or anything, but it messes up the timing pulse very nice!
rg
----- Original Message ----
Sent: Saturday, February 23, 2008 8:53:58 AM
Subject: [Doepfer_a100] a155 Grooves
hello Group
what methods you use to let the 155 play in swing or with a variable
pattern groove ?
for swing i found a clock synced triangle or saw down  lfo extremely
usefull,
but i would like to archieve something more complex.
Yahoo! Groups Links
2008-02-23 by dab
hello ross
what does the universal vactrol actually do in this patch ?
i dont have it but i would like to recreate your idea.
> rg
> From: dab <trafo-dab@gmx.de <mailto:trafo-dab%40gmx.de>>
> To: Doepfer_a100@yahoogroups.com <mailto:Doepfer_a100%40yahoogroups.com>
> hello Group
> pattern groove ?
> usefull,
> __________ NOD32 2897 (20080222) Information __________
> Diese E-Mail wurde vom NOD32 antivirus system geprüft
> http://www.nod32.com
