Re: [Doepfer_a100] A-125 phaser (noise issue)
2008-02-23 by Ross Goniakowski
i accidently deleted a reply to this post from Bakis, i believe he said an easy fix was to use a VCA after the phase shifter... i don't consider that a fix, i consider that a work-around...to fix the problem would be to reduce the noise level, not hide it...depending on the source material, that may or may not be an appropriate solution.... rg
----- Original Message ---- From: astroschnautzer <astroschnautzer@yahoo.com> To: Doepfer_a100@yahoogroups.com Sent: Saturday, February 23, 2008 8:46:52 AM Subject: [Doepfer_a100] A-125 phaser (noise issue) I just got this module ,seems to work ok besides its terribly noisy. My soundcards noisefloor is at about -90db withoout this plugged in whe i plug it in it shows -47db so over 40 db of noise... Is this normal for this module or should I send it back? [Non-text portions of this message have been removed]
