Doepfer
interfacing doepfer with dyn sync?
2008-03-20 by Carlos
whats the easies way to use a doepfer lfo or vco or other pulse
producing device to time somethign that takes dyn sync in?
I aquired a cyclodon sequencer recently and is a very cool little
sequencer, but the only way to clock it externally is with dyn sync...
I now that there is midi to dyn sync convertors, btu thats not what I
am looking for
Re: [Doepfer_a100] interfacing doepfer with dyn sync?
2008-03-21 by Florian Anwander
Hi Carlos
In principle very easy in fact very complicated.
Take an LFO at higher speed, use it as clock for the din-sync, and
divide it also down with an A160 to get 16th clock (or similar) for
usage as internal clock in the A-100. In fact the problem are the start
and stop signals for the sync and the synchronicity of the start signal
with the 16th clock.
I never use the internal clock of any instrument, but use a Masterclock
from an external device (my case a Roland SBX80).
Florian
RE: [Doepfer_a100] interfacing doepfer with dyn sync?
2008-03-21 by Anthony Rolando
Not sure what the PPQ on the technosaurus is, but on most Roland X0X stuff it is 24PPQ which cannot be achieved achieve with the 160. I was only able to achieve sync using a VCS as a variable divider and then syncing by ear. Perhaps I am doing something worng????
Tony
> To: Doepfer_a100@yahoogroups.com
> From: Florian.Anwander@consol.de
> Date: Fri, 21 Mar 2008 13:08:02 +0100
> Subject: Re: [Doepfer_a100] interfacing doepfer with dyn sync?
> Hi Carlos
> Florian
In a rush?  Get real-time answers with Windows Live Messenger.
http://www.windowslive.com/messenger/overview.html?ocid=TXT_TAGLM_WL_Refresh_realtime_042008
