Doepfer
Serge compatability ?
2008-05-13 by williambbaggett
Has anyone any experience with or ideas about the wisdom of
interfacing Doepfer modules with as Serge system ?
1. It seems that Doepfer audio modules run  at 5 volts peak to peak
(-2.5v to +2.5v ?) - like the Serge - and uses bananna plugs too, so
great, right?
2. How about Panel Size?
3. Power supply?
4. Any other problems anyone can forsee?
Finally, are ther other modular systems anyone is aware of that would
seem to be compaable with Serge?
Thanks for any response!
Billy
Re: [Doepfer_a100] Serge compatability ?
2008-05-13 by Guy D2
> great, right?
Doepfer uses 3mm (mini) phonejacks, not banana's.
Doepfer : 3U
Serge: 4U
Not really compatible, hardware-wise. Two different beasts...
> 3. Power supply?
Doepfer does both 115/230V AC
Doepfer DC rail: +/- 12V (opt: + 5V)
Don't know the electrical specs of the Serge systems,
but I'd look seriously into the gate/trigger voltages
before hooking both up.
Most current modulars are electrically compatible
(their CV/audio signals, and gates mostly too),
but not always 100%.
Often not a real problem, but be careful in some instances.
MetalBox, Cynthia and ModCan A series all use banana jacks,
and are more or less compatible with Serge. Buchla too...
I guess our list moderator (Bakis) can tell you all about this,
since he owns all of the modules of all of the systems... ;-)
Personally, when thinking about crossbreeding Doepfer with
othe modulars, Serge is not the first system coming to my mind...
On a sidenote:
I've been working on a complete list/database of current
modular systems compatibilities (both mechanical and electrical),
but didn't finish it yet... Maybe one day... Need some help here too.
-Guy
2008-05-13 by Bakis Sirros
so far, i didn't have any problems interfacing my
serge to any of the other modulars i have.
indeed, serge working voltages range is +/-5volts, so
it works fine with the doepfer, but as you would
expect, in some instances, the output voltage of the
doepfer modules will be partially unused from the
serge cv inputs (due to the difference of range).
but, i do not think that this causes any problem.
just use cv attenuators...
if you do not use attenuators, you will sometimes just
have 'peaking' behaviour of the doepfer cv's when
controling serge cv functions.
anyway, the doepfer cv's are mostly up to 8 volts,
IIRC, so there is not a big difference...
regarding syncing triggers/gates and such they seem to
work fine...
although i still have to work with them in combi more
months to really find out all aspects of their
cross-compatibility.
bottom line is: i think they'll work fine together.
you just need LOTS of banana's to minijack converter
panels (custom made for you).
the reason is that you DO HAVE TO HAVE common ground
between the serge and other (mini)jack modulars.
minijack cables 'carry the ground with them' but
banana's do not.
so, you have to use a converter panel that is grounded
to the serge psu when you convert from banana's to
minijacks and vice-versa, to connect the serge to
other jack modulars.
this banana to minijack panel can be easily made by a
tech for you. (and you can then mount it into your
euro rack, but you have to connect the ground pin of
the converter's minijacks to the ground of the euro
rack internally) and the serge psu must be grounded to
the eurorack psu.
i hope i'm right in all these, i'm no tech...
best regards,
Bakis.
> wisdom of
> volts peak to peak
> > great, right?
> Doepfer : 3U
> Serge: 4U
> beasts...
> > 3. Power supply?
> systems,
> voltages
> instances.
> aware of that would
> jacks,
> too...
> about this,
> systems... ;-)
> Doepfer with
> to my mind...
> On a sidenote:
> current
> electrical),
> some help here too.
> -Guy
[Doepfer_a100] group owner
www. parallel - worlds - music. com
www. myspace. com/ parallelworldsmusic
www. myspace. com/ interconnectedmusic
www. myspace. com/ memorygeist
www. DiN. org. uk
www. musicamaximamagnetica. com
www. shimarecords. co. uk
www. rubberrecords. gr
Athens - Greece
