Doepfer
Whats the smallest keyboard with CV Gate Outputs?
Re: [Doepfer_a100] Whats the smallest keyboard with CV Gate Outputs?
2008-06-19 by James Husted
You've seen this page? - http://www.doepfer.de/A100CGK.htm - scroll
to the bottom and you will see exactly what you want. I doubt you
will find a solution cheaper than the proposed price of the OEM kit.
The only other solution is a cheap MIDI controller (I got a roland
one built for PCs for $25 used) and a MIDI>CV converter (the modular
Doepfer A-190 or an external one) and come in cheaper. Not a cool
looking as the one shown under the suitcase.
Dieter - How about a road case version of the 3-octave one shown
under the P-cases? Since the P-cases are meant to be portable, why
not the keyboard too (I know, it's the cost).
-James
On Jun 19, 2008, at 12:10 PM, johnppp2 wrote:
> I'm looking for a small 1 or 2 octave keyboard with the above outputs
> to patner my suitcase> Any ideas??
RE: [Doepfer_a100] Whats the smallest keyboard with CV Gate Outputs?
2008-06-20 by David Salter
Alternatively seek out an cheap old synth with CV gate output.
I know that even a Roland SH101 or SH09 can be expensive when view as
just a keyboard but you also get the synth as well.
Lesser desirable makers are worth checking out like Teisco as they fall
under the collectors radar.
Rgds
David
David Salter
Head SSG Nordics & Baltic's
Thomson Reuters
O +44 (0)20 7542 2402X 52402
M 07990562402
david.salter@thomsonreuters.com
thomsonreuters.com <http://thomsonreuters.com/>
From: Doepfer_a100@yahoogroups.com [mailto:Doepfer_a100@yahoogroups.com]
On Behalf Of johnppp2
Sent: 19 June 2008 21:11
Subject: [Doepfer_a100] Whats the smallest keyboard with CV Gate
Outputs?
AW: [Doepfer_a100] Whats the smallest keyboard with CV Gate Outputs?
2008-06-20 by hardware@doepfer.de
> -James
I can ask our case manufacturer to built a P-case for any of the OEM
versions. But the cases will be very expensive as they have to be made as
custom single-unit production. I don't think that we will sell many of these
cases. But as a special design we could offer it.
At the moment we try to find a solution to built the A-100CGK (probably the
5 octaves version, maybe together the A-198 ribbon controller) into the top
cover of the A-100 monster base. But I can not yet confirm that it will
work.
Best wishes
Dieter Doepfer
Re: AW: [Doepfer_a100] Whats the smallest keyboard with CV Gate Outputs?
2008-06-20 by James Husted
I had imagined that it would cost a bunch. I have a couple of Anvil
Case briefcases laying around (they used to sell them as promo items)
and I could try to build a keyboard into one of them. I used to go to
pawn shops and look for old instrument cases and build electronics
into them. Sometimes you can find a old wooden instrument case that
is just the right dimensions to do the job. I had good success with
old clarinet and tenor saxophone cases - just the right size for
small projects after you ripped out the insides.
-James
>> -James
> made as
> of these
> (probably the
> the top
> will
> work.
> Best wishes
> Dieter Doepfer
2008-06-20 by Monroe Eskew
after you ripped out that pesky woodwind... hehe...
On Fri, Jun 20, 2008 at 8:02 AM, James Husted <the_ersatz_planet@mac.com>
> -James
> On Jun 20, 2008, at 2:35 AM, hardware@doepfer.de <hardware%40doepfer.de>wrote:
> >> -James
> > made as
> > of these
> > (probably the
> > the top
> > will
> > work.
> > Best wishes
> > Dieter Doepfer
> > Yahoo! Groups Links
I just had another idea that may offer a more elegant solution. You
could look into a variation of the P-cases with a deeper lid with the
keyboard built in already, or just sell a Keyboard Lid as a separate
piece. It could be designed so that the  P-case could sit on top of
the back half - I'm at work now so can't measure it to see how small
the space left for the keys would be - maybe it could work. It make
the P-case like a Synthi AKS, especially if a Touch Keyboard was used
(which would probably fit in the current lids without much
redesign).  just an Idea.
-James
>> -James
> made as
> of these
> (probably the
> the top
> will
> work.
> Best wishes
> Dieter Doepfer
