Doepfer
working on Euro-format tube modules for next year
2008-07-13 by metasonix2000
As you may have seen elsewhere, I'm working on making new tube modules
in Euro/Doepfer format, probably for introduction early 2009.
They will be mechanically similar to Cwejman, except with big fat
vacuum tubes poking out of holes in the front panel. Probably 28HP
size panels for most functions. They won't protrude more than about 1"
behind the panel, but those tubes will stick out as mucha s 2",
depending on the tube type (and they are allll over the place in
height--BN6 tubes are especially tall).
Power supplies will be an issue--most of the tubes I'm contemplating
will need +5v power at an amp or so per module, from an added supply
(the little +5 supplies that Doepfer sells will be hopelessly
inadequate). To run heaters. They suck a LOT of current.
A VCO is in the works--I have a new circuit that produces a really
nice sinewave, clippable to a square wave, with a very wide pitch
control range--much wider than the thyratron VCOs we've made to date.
Linearity looks good and it might have V/octave CV control (if I can
cram it onto that little board).
Same circuit can be modified slightly to be used as a bandpass filter.
Also plan eventual versions of the TM-6 filter, TM-1 waveshaper, a
VCA/distortion using remote-cutoff pentodes, and possibly other
things. No CV sources, just audio signal sources and processors. These
will be fairly simple designs, for obvious reasons....don't even think
about triangle waveforms or state-variable filters, such things can't
be made in practical form with tubes. Tube distortion, no problem!
Forgive me if some of you appearance-freaks don't like this, but I
wanted to make my panels really stand out. So I am leaning toward
Metasonix yellow.
I've asked about this on other forums, and the consensus was
95% for yellow panels:
https://www.blogger.com/comment.g?blogID=17775202&postID=7313555627935826490"
http://www.muffwiggler.com/forum/viewtopic.php?t=1198
Also asked on the "Modular Synth Panels" Yahoo group.
Reasonable opinions are welcome.
Re: working on Euro-format tube modules for next year
2008-07-14 by vcovcfvca
Hope you don't mind Eric, but I've bought the panel question up on
another forum:
http://www.modularsynth.net/viewtopic.php?t=1557
Not sure if we'll get any responses. We can create a poll there as
well if you want to see some actual votes.
Adam
> Metasonix yellow.
> what drugs did you give them before the consensus.:-)
> .....not sure about the yello thing but I am one who love the
silver
> faceplates.
> Im not big on different looking face plates :-(
modules
about 1"
contemplating
supply
date.
can
filter.
These
think
can't
> > Metasonix yellow.
> > <https://www.blogger.com/comment.g?
blogID=17775202&postID=7313555627935826490>"
> > <http://www.muffwiggler.com/forum/viewtopic.php?t=1198>
2008-07-14 by partlydrone
definitely yellow.
i need an envelope, and despite there being better facilities on one
from doepfer that suits my needs, i'm buying mfb because it's black.
nb i am a total whore for that kind of thing, and replace grey doepfer
knobs with more interesting ones, even though theyre then more cramped
and less usable.
Re: [Doepfer_a100] working on Euro-format tube modules for next year
2008-07-14 by amnesia
Metasonix yellow.
.....not sure about the yello thing but I am one who love the silver
faceplates.
> Metasonix yellow.
> <https://www.blogger.com/comment.g?blogID=17775202&postID=7313555627935826490>"
2008-07-14 by helitr0n
this is going to be soo cool - just cant wait to get my fingers burnt
on those tubes. and yes, yellow faceplates will for sure look cool and
stick out.
hope the 5V problem will be solved somehow, so that the modules can be
used with the doepfer powersupplies.
hel
> Metasonix yellow.
2008-07-14 by Chris Henkel
...that is great news!
2008/7/14 metasonix2000 <synth@metasonix.com>:
    in Euro/Doepfer format, probably for introduction early 2009. (...) So I
am leaning toward
    Metasonix yellow.
...any colour you think they should have! - my opinion on this topic
generally: I like it when the manufacturer shows its own character even on
the frontplate, and I dont think that making all panels look the same makes
it any better. Have Doepfer in silver, MFB in black, Cwejman is fine in
greenish-grey and now I am happy to hear that I'll get some yellow soon
also...
;o)
RE: [Doepfer_a100] working on Euro-format tube modules for next year
2008-07-14 by David Salter
What a wonderful idea.
And I think the yellow panels would be great.
Question,
with the tubes protruding from the panel are they running hot, enough to
either singe a hand or a patch cable?
Thanks
David
David Salter
Head SSG Nordics & Baltic's
Thomson Reuters
O +44 (0)20 7542 2402X 52402
M 07990562402
david.salter@thomsonreuters.com
thomsonreuters.com <http://thomsonreuters.com/>
From: Doepfer_a100@yahoogroups.com [mailto:Doepfer_a100@yahoogroups.com]
On Behalf Of metasonix2000
Sent: 13 July 2008 23:51
Subject: [Doepfer_a100] working on Euro-format tube modules for next
year
Metasonix yellow.
6490
26490> "
2008-07-14 by metasonix2000
> another forum:
Thanks! Yes, a poll would be ok.
> > Hello thing but I am one who love the
> silver
> > faceplates.
Well, sorry dude, you're in the minority....
Thanks all. Nice to see someone cares enough to answer.
No, the tubes won't get hot enough to melt patchcords or burn your
fingers.
At most, they will get a little too hot to hold with your fingers for
extended periods. So don't hold them.
Convective cooling is critical here, thus the exposure. If they were
enclosed in a cabinet they would run a lot hotter.
That VCO circuit is a really cute thing. I found it in a 1964
textbook. It was called a "tuneable amplifier", even though it doesn't
even provide any gain, in fact it attenuates the input signal a LOT.
Control it with a 5C3 Vactrol, and it makes a strangely linear
VCO.....I didn't expect that!
> We have about 100 +5V/2500mA supplies left which we add for free upon
> request to any other order. Details on our website in the Sonderliste
> (special list). But these supplies are suitable only for 230V mains
voltage
> Best wishes
> Dieter Doepfer
There, you see? It's not a big deal. Most of the Doepfer (and Analogue
Systems, and what-have-you) cabinets have plenty of space inside for
5v power supplies.
Thank you Dieter....
The hobbyist market abounds with cheap supplies.
For example, this one will run heaters for at least 3 tube modules:
http://www.mpja.com/prodinfo.asp?number=17430+PS
2008-07-14 by Bakis Sirros
great news about Metasonix stuff going euro, indeed!
i do not care about the yelow colour, btw...
[Doepfer_a100] group owner
www. parallel - worlds - music. com
www. myspace. com/ parallelworldsmusic
www. myspace. com/ interconnectedmusic
www. myspace. com/ memorygeist
www. DiN. org. uk
www. musicamaximamagnetica. com
www. shimarecords. co. uk
www. rubberrecords. gr
Athens - Greece
--- On Mon, 7/14/08, David Salter <david.salter@thomsonreuters.com> wrote:
From: David Salter <david.salter@thomsonreuters.com>
Subject: RE: [Doepfer_a100] working on Euro-format tube modules for next year
Date: Monday, July 14, 2008, 10:25 AM
Question,
Thanks
David
David Salter
Thomson Reuters
M 07990562402
david.salter@ thomsonreuters. com
thomsonreuters. com <http://thomsonreute rs.com/>
____________ _________ _________ __
From: Doepfer_a100@ yahoogroups. com [mailto:Doepfer_a100@ yahoogroups. com]
To: Doepfer_a100@ yahoogroups. com
year
will be fairly simple designs, for obvious reasons....don' t even think
Metasonix yellow.
https://www. blogger.com/ comment.g? blogID=17775202& postID=731355562 793582
6490
<https://www. blogger.com/ comment.g? blogID=17775202& postID=731355562 79358
26490> "
http://www.muffwigg ler.com/forum/ viewtopic. php?t=1198
<http://www.muffwigg ler.com/forum/ viewtopic. php?t=1198>
AW: [Doepfer_a100] Re: working on Euro-format tube modules for next year
2008-07-14 by hardware@doepfer.de
> stick out.
(special list). But these supplies are suitable only for 230V mains voltage
Best wishes
Dieter Doepfer
2008-07-14 by ilanode
You'll probably escape graphics like "anal probe" but Metsaonix is
going to stick to a panel colour which shall resemble to a body fluid.
Or am I mistaken on Eric's intention here? Best rgds, Ingo
--- In Doepfer_a100@yahoogroups.com, "Andreas- theCovertOperators.Org"
<a@...> wrote:
> Since you're asking our opinions, yellow is fine for me, I like
> different coloured panels, it's the
> "graphics" I personally shy away from. I might have bought metasonix a
> bit earlier if that department had been different. I still respect your
> "artistic" choice on the matter, I just choose to vote with my wallet
> there :)
> Well, I guess a cramped Euro with a huge tube in it won't leave much
> panel space left for anal probes and such?
> Andreas
Re: [Doepfer_a100] Re: working on Euro-format tube modules for next year
2008-07-14 by Andreas- theCovertOperators.Org
there :)
Andreas
2008-07-14 by thomasborax
i love this!  i can't wait.  it will be fun for me to attempt to DIY
a power supply like this to the doepfer busboard.  you'll use the
same ribbon connector?
i second the yellow, the goofier-looking i can get my system, the
better.  and tubes poking out...yes yes yes!  i'm for the distortion
type modules, please work on one or two of those.
-tom
upon
Sonderliste
mains
> voltage
> > Best wishes
> > Dieter Doepfer
Analogue
> 5v power supplies.
2008-07-14 by laryn91
From a business view, I'd go for the least common denominator.  Make your modules
compatible to existing systems as much as possible. And that includes making it not only
electrically, but also VISUALLY compatible.
Nobody's going to buy your modules because of piss-yellow panels and names like Anal
Probe. They're going to by it because you make great products. However, I can see some
potential customers being turned off with loud obnoxious colored panels in their Euro
systems. That negative could very well affect buying decisions.
On the other hand I really don't see people NOT buying you modules because it matches
the rest of their system. So there's really no business advantage to marginalizing your Euro
products by painting them yellow.
> > another forum:
> > silver
> > > faceplates.
No. It's a three pin DIN connector (as shown in the picture) that has
available GND, +5V/2500mA and -24V/50mA. You have to remove the DIN
connector and add a suitable connector for the A-100 bus (e.g. two 6.3 mm
flat connectors that fit to the corresponding terminals of the A-100 bus
board). The -24V are unused. Please do not connect the -24V to the A-100 bus
as this will damage modules !
Best wishes
Dieter Doepfer
2008-07-14 by James Husted
> Question,
> enough to
This and if they stick out too much they are a no-go for me - I have
the portable cabinets and the lids still have to fit.
-James
I use the portable doepfer cabinets - they will have to allow
clearance for the lids for them to work for me.
-James
>> enough to
> fingers.
--- In Doepfer_a100@yahoogroups.com, James Husted
Okay....just how much clearance is in the portable cabinet lids?
If it's at least 2 inches, no problem.
A new poll has been created on the following forum:
http://www.modularsynth.net/viewtopic.php?t=1567
It will run for 2 weeks. Tried to make it general, something that
could apply to any format/manufacturer.
The VCO you've mentioned sounds great. Looking forward to seeing some
designs.
Adam
on
> > another forum:
as
> > silver
> > > faceplates.
2008-07-15 by Carlos
I think you also need to find an all inclusive solution to the 5 volt
supply problem provided by you.
Most people don't have the time/don't feel like they know how to mess
around with DIY stuff/ 3rd party power supplies. If you don't is going
to tremendously knock down your customer base to a small percentage of
owners that are used to doing DIY.
enough to
> fingers.
2008-07-15 by gabu_004
Drugggsss are gooooooddddd......
;P
> Metasonix yellow.
> faceplates.
> > Metasonix yellow.
2008-07-15 by thomasborax
i don't currently use the 5v for any of my modules.  if my memory
serves correctly, there is one rail used by the full-sized 16-pin
(opposed to the 10 of 8 pin) connector that carries +5vDC as needed, yes?
so the trick would be to get +5DC onto that rail at several amperes
depending on which metasonix modules i want...yes?
so my question to eric is...how will the modules be designed to
recieve their +5v?  standard eurorack ribbon?  i think that makes the
most sense and next step after that would be how to get +5DC onto the
rail.  i'd be into DIY-ing it, but i would also need to figure out how
to get the 5v transformer to drink off the same mains that feeds the
+/-12v transformer i power my modules with.  having two main ins seems
gratuitous.
since harvestman recommends the 5v too, this may be something that
could benefit all eurorack users if there was a real easy DIY or
something.
please feel free anyone to correct my interpretation power rail
schematic.
-tom
6.3 mm
A-100 bus
> Best wishes
> Dieter Doepfer
Yes Eric!
Please keep the DIRTAAHHHH names and graphixxx... honnestly I like the yellow... But
silver and yellow, as I stated in Metasonix could be even cooler... and sneakier for the
eyes!
Can<t wait to see those there! Oh and are you going to have some stuff at Moog Audio
again in Montreal? "like back then"?
g.
> fingers.
2008-07-15 by Bakis Sirros
that's correct.
i cannot make, or connect, an extra 5volts psu to the doepfer rack in order to mount the metasonix modules.
i'd much prefer another solution, with which i can mount the metasonix modules right away to  my doepfer rack.
www. DiN. org. uk
Athens - Greece
--- On Tue, 7/15/08, Carlos <bushwick@gmail.com> wrote:
Subject: [Doepfer_a100] Re: working on Euro-format tube modules for next year
Date: Tuesday, July 15, 2008, 3:12 PM
enough to
> fingers.
2008-07-15 by Doug
Perhaps it would be best to offer a 6U Metasonix subrack that also
safely accomodates Doepfer, et al modules.
Beyond this, perhaps offing the power supply (and busboards?)
separately for retrofitting into Doepfer racks (or other DIY
applications) would be enough to make everyone happy.
Doug
2008-07-15 by metasonix2000
yes?
Right. However....if you mount 3 of these modules in a Doepfer
rack, that will add up to perhaps 1800 mA of load. That might
be better delivered by separate wiring, although I think the
existing 16-pin power busses should be able to handle a couple
tube modules.
NOW, do you see why there are no tube Euro modules?
It's POSSIBLE to use +-12v only. It requires the usage of
tubes with 12v or other "odd" heater voltages, which are
easy to get but not as commonplace as 6-volt heater versions.
(I'd like to use 6GH8s if at ALL possible. At one time,
the 6GH8 was the one tube in the world manufactured in
the largest quantities---
mainly because it was used in TV sets that ran them
very hard, and made for a short lifetime.
Lud Sibley of the Tube Collector's Association owns the
RCA corporate archive. He did the research in the files
and found that in 1960-61, RCA was making FOUR MILLION
6GH8s PER MONTH. By comparison, they made "only" about
100,000 12AX7s per month. So, leftover 6GH8s are
everywhere today.)
And the total power consumption will be the same anyway.
A typical two-tube module will use about 3-4 watts just
for tube heaters, regardless of where the power comes from.
So it's your choice:
1) get the cab modified to hold an extra +5v supply,
or
2) use large +-12 power supplies to run the tube load.
And there's another headache:
Want a Frac version of these modules? Well, Frac systems
usually have +-15v. No problem for the solid-state support
circuits. But the tube heaters will HAVE to have optional
dropping resistors to keep their voltages down.
More complexity, more PC board space.
2008-07-15 by laryn91
Here's an option: make a power connector on the panel FRONT and include a wall wart
that can supply the 6v (AC or DC) for the tube heaters.
The wall wart can be cheap since I assume it doesn't have to be regulated. You can still
provide internal connections for those willing to wire up another PS themselves. The front
panel can have an additional connection for daisy-chaining the heater voltage to
additional modules.
This option could now allow every Erro and Frac user to easily add your cool tube modules
to their systems.
> yes?
> tube modules.
> everywhere today.)
> or
a wall wart seems like a ok solution.  but what i'd like to do is run
the 5v transformer off of the same "mains-in" that the +/-12v runs off
of.  i think that's what most people with modulars would want to do.
since the rail already exists on the bus board for +5v, it's just a
matter of supplying the current needed to feed the thirsty tubes.
having separate power supplies for different modules would be kind of
like just buying the stomp-box type metasonix modules.  the pleasure
of euro-shaped metasonix would be that it's organized into your
system.  no adaptors, no wall warts.  just flip your system on and play.
i would happily DIY a transformer into my system, since it could also
help with my harvestman modules.  perhaps against better judgement
i've already done work with 120v circuits (and i'm no whiz by a
stretch - i write this as someone not dead or fried by voltages
alive).  but perhaps eric or someone else would be willing to sell
something that can get the high current DC5v down to the bus rail
through a standard female ribbon connector, using the same mains
on/off switch as the bipolar12v?
-t
include a wall wart
heater voltage to
> additional modules.
> to their systems.
> > yes?
> > tube modules.
> > everywhere today.)
> > or
How big do you suppose the market is for exotic analog synthesizer modules that require
major DIY power supply hacking just to get them to work.
And what retailer in their right mind would take a such a burden  to sell a product like
that. If it's not going to work out of the box, I'm guessing most people will pass.
> -t
> include a wall wart
> heater voltage to
> > additional modules.
> > to their systems.
> > > yes?
> > > tube modules.
> > > everywhere today.)
> > > or
2008-07-16 by hardware@doepfer.de
> [mailto:Doepfer_a100@yahoogroups.com]Im Auftrag von thomasborax
> Gesendet: Mittwoch, 16. Juli 2008 02:54
> Betreff: [Doepfer_a100] Re: working on Euro-format tube modules for next
> year
The A-100 power supplies have additional connectors that can be used to
connect the mains of another power supply (i.e. each of the mains connectors
is available twice). We use this connectors e.g. if a second power supply
has to be installed into a frame. You have to pay attention that the fuse
value in the mains inlet has to be adapted accordingly (e.g. doubled if two
A-100PSU2 are used).
These connectors can be used to drive e.g. a +5V supply. The GND and +5V of
the +5V supply have to be connected to the GND and +5V terminals of the bus
board. But the width and thickness of the +5V track of the bus board is not
suitable for high currents as required for Erics tube modules but only for a
few hundert mA. As suggested by Eric the +5V line of the bus board has to be
"thickened" (e.g. by soldering an additional blank wire across the +5V
track).
And I have to add this remark: As these works affects parts, pc boards and
cables that conduct mains voltage (230/115V) carrying out of these works is
allowed only for experts or authorized personnel who are familiar with all
valid safety rules.  Laymen are not allowed to carry out these works !
Danger to Life.
Best wishes
Dieter Doepfer
2008-07-16 by thomasborax
only for a
has to be
> track).
a-ha.  that was the one detail that left me a little curious. the
solution is not as simple as i thought. in that way, it almost seems
that these modules will require their own power supply, i.e. possibly
wall wart solution, in order to make it easy on users.
i'm personally interested in trying "modular mods" for posterity,
though.  if it comes to doing the extra work or using a wall wart, i
will do the work.
i'm curious to see how this pans out.  i think there is a solution
that will make users and designers happy and hope that eric sees this
project through, not discouraged by logistics.  having tube modules in
my system is really exciting.
-t
2008-07-16 by Doug
> will do the work.
Hopefully "wallwart" will fade away as a talking point. I think the
best solution is to offer a Metasonix subrack that is downwardly
compatible with other euro modules. This rack would contain a power
source and busboards that could also be sold separately for DIY'ers.
Of course it would be best if the power source and busboards just
happened to fit in as replacements in the standard Doepfer racks. I
envision simply swapping out a busboard and power supply in my G6
subrack, so Metasonix modules could be added to the row. Whether or
not the busboards are Doepfer or AS compatible (or both) is secondary,
as people are already capable of integrating AS modules into Doepfer
racks and vice versa. This being the Doepfer group, I would vote for
Doepfer compatible bus boards as the primary objective ;)
Doug
2008-07-16 by James Husted
The solution could be a 5V power supply module made like the Power
Supply module in the portable cases. It could be sold with a beefed
up buss board to replace the installed one (but then there would have
to be a AS and Doepfer versions) or it could just connect directly to
the modules with molex connectors (the classic PC power connectors
would work). It would plug into the additional AC connectors that
Dieter mentioned or in worse case scenario there would be a front
mounted IEC connector like the Portable cases. You would have to
mount it at the end of the row and the it would only want CV type
modules next to it but it would be the most elegant solution with the
least amount of user involvement (at least the direct connect - no
buss version).
-James
