Doepfer
hum problem with DIY Kit 2
2008-07-16 by pro2andrius
hallo friends
i experienced a low frequency hum with my new case including a DIY kit
2, even i tried to change the 12v power supplies but no success...
any suggestions?. better to put away the cheap solution and get a
standard a100 psu?
AW: [Doepfer_a100] hum problem with DIY Kit 2
2008-07-16 by hardware@doepfer.de
> hallo friends
> standard a100 psu?
Are you sure that you use stabilized 12V supplies. Unstabilized supplies
cause hum noise in audio generating and processing modules.
In general the low cost DIY kit 2 should be used not for high quality
applications as mentioned in the DIY kit 2 info. A very simple type of power
supply (two wall outlet supplies) is used in this kit.
Best wishes
Dieter Doepfer
