Doepfer
pads...pads...pads ...
2002-06-15 by modularplanet
Hi list,
there is only one (!) patch in the synth-pad area of the
Modular-Planet :-(
Do you have any ideas or suggestions?
Josef
www.Modular-Planet.de
Re: [Doepfer_a100] pads...pads...pads ...
2002-06-16 by bakis Sirros
hi josef,
yes i have an idea!...just wait till i make my a100
4-voice polyphonic!(when i buy the doepfer mcv24),then
i'll sent some pads pathes.
bakis.
--- modularplanet <webmaster@modular-planet.de> wrote:
> Hi list,
> the
> Modular-Planet :-(
> Josef
synthfreak(parallel worlds)
athens-greece
[Doepfer_a100] group owner-moderator
Do You Yahoo!?
Yahoo! - Official partner of 2002 FIFA World Cup
http://fifaworldcup.yahoo.com
Re: pads...pads...pads ...
2002-06-16 by ringmod45
hi bakis, before you go out and buy the MCV24, check out the Encore
Electronics Expressiont 2 that will be released very soon. it uses 16
bit dac's for all of the cv outputs. it has more lfo's and modulation
possibilities. the Expressionist 2 will be a smaller version with
different assignable channels.
i use the Expressionist 1 and have nothing but praise for the unit.i
use an MPC connected to the Expressionist to do those long notes
which none of the Doepfer boxes can do. it is very tight and precise.
the lfo's are are a charm to work with and you can use the
Expressionist to do Volts/hz and S-trig for yamaha, Korg and Moog. it
also has a variable rate dyn sync output for 24 ppq and 48 ppq clock
speeds.it seems to be the midi2cv of choice among the users of big
systems , i.e Serge, MOTM etc. here is the url.
http://www.encoreelectronics.com/cont_expres.html
the manual url is at this url.
http://www.encoreelectronics.com/exp01.pdf
they have one coolest and most functional modules designed in quite
some time. the Universal Event Generator. The UEG can be used as an
envelope generator, a complex LFO, or as a step sequencer. i know it
won't fit in a Doepfer rack but you could buy or make a rack. the
bonus is you could also buy the forthcoming Frequency Shifter, some
Oakley Systems' Wavefolder or MOTM's new CS80 inspired filter, etc.
ther CS80 filter will give you a nice sound shaping quality to do the
pads you are talking about. to hear what i am refering to, listen to
Brian Eno's track " Julie with..." on the Before and After Science
album  to get to the jist of it. a very strong album.
just more arsenal to bolster your modular capabilities.
hope this helps, they are worthy options to think about.
regards,
RM
--- In Doepfer_a100@y..., bakis Sirros <synth_freak_2000@y...> wrote:
> hi josef,
> bakis.
> --- modularplanet <webmaster@m...> wrote:
> > Hi list,
> > the
> > Modular-Planet :-(
> > Josef
> athens-greece
> Do You Yahoo!?
2002-06-16 by modularplanet
Hi Bakis,
> 4-voice polyphonic!
I hope for all A-100-Freaks it`s possible to patch it ;-)
(Perhaps there are simpler pad-patches...???)
Josef
> hi josef,
> bakis.
> > Hi list,
> > the
> > Modular-Planet :-(
> > Josef
> athens-greece
> Do You Yahoo!?
