Doepfer
PLL CV Question
PLL CV Question
2008-12-04 by Doug
Hi folks, I have an A-196 PLL, and I have a simple question. The
internal VCO seems to behave much better given the LPF input than an
external VCO. The LPF signal is typically way too jittery for an
external VCO. The only way I've been able to get an external VCO to
work is to patch the COMP output to a slew then to the external VCO.
Is there something wihtin the circuit between in the LPF output and
the VCO input? Or is the internal VCO special or slewy compared to
typical VCOs?
Doug
Re: [Doepfer_a100] PLL CV Question
2008-12-05 by Don Kim
You could send the internal VCO's signal into any oscillator's sync
input and the slave should follow the PLL's output signal.  That would
be probably the simplest way I could think of.
> typical VCOs?
> Thanks,
> Doug
Re: PLL CV Question
2008-12-05 by Doug
Hi don, I'm not necessarily interested in sync-ing oscillators as I
am using the PLL as a CV source for a variety of things. This is a
great idea though that I hadn't thought of. Thanks,
Doug
would
than an
to
VCO.
and
to
> > typical VCOs?
> > Thanks,
> > Doug
